Question about Sony XPLOD CDX-GT200 CD Player
No AM or FM yet cd player works
HI there.
My sony Xplod shows that I am receiving signal on am and fm radio however no sound comes out, not even any sounds of distortion, its just blank, however if I play my cd player it works like a charm.
I was wondering if there is a fuse on the stereo strictly for am/fm functionality?
  • abhi1308 Jul 01, 2008
    My sony xplod recieves am signal . However no FM. It just stopped . also I wud like to mention that i have an internal antennae . Am sure if the AM signal is recieved so shud the FM as it used to earlier. What cud be the issue..Cant tune in to other FM channels, inspite of following the manual.
    Cd plays perfectly,
  • 129 Answers
Friend,
Maybe, there is a problem from the detector of you radio function to the amplifier. Try to check on it first or try resoldering from the detector section
Posted on Mar 10, 2008
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory » FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
My phone cant pick up the bluetooth signal from sonyt xplod headunit even with bluetooth symbol showing?
Try reseting,turn the phone off and back on,then reset the head set. Follow the manufacturers instructions for setting the unit in pairing mode
Nov 23, 2014 | Sony Xplod Cdx-gt540ui Head Unit Faceplate...
No Sound on AM or SW
Hello
If the set receives FM signals without any problem, and only fails to receive AM signals, the IC [integrated circuit] used in it is faulty. The number of the IC used with your radio is CXA 1376AS. It is a replacable type IC, and can be bought from most of the electronic spare part shops at your town. If you want further details about its service manual, get me by Fixya. OK.
Nov 11, 2011 | Sony ICFSW7600GR FM Stereo World Band...
Where does the remote wire for amp go to on sony xplod cdx gt520
their should be a blue white wire on the back of the radio. this wire is called the amp turn on wire connecting to this wire will provided 12 volts when the xplod cdx gt520 is turned on but if you press the off button on the radio the 12 volts will drop to 0 volts but when the radio is turned on the 12 volts will come back.
Aug 01, 2011 | Sony CDX-GT520 FM / AM Receiver
Lost the FM signal this morning, AM still works fine. all I get is static on FM with some intermittent what sounds like CB radio.
hello please check the rear of the radio as antenna could have come away from it hearing sounds like cb radio do you mean transmissions can you hear someone talking ,its probably someone near you that you are picking up
Mar 17, 2011 | Sony CDX-CA750X CD Player
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Sony cdx-gt50w
go over this detailed wiring instruction, make sure your memory wire is attache to a constant power source.
http://www.ehow.com/how_5829_wire-car-stereo.html
Feb 20, 2008 | Sony Xplod CD Player w/MP3 Playback...
Sony Xplod no radio in 2000 Ranger
if you have lost am and fm it sounds like the antenna connector on the back of the radio has come off, if you find that is the case put it back on and secure it with a strip of tape
Dec 04, 2007 | Sony XPLOD CDX-GT200 CD Player
Sony XPLOD CDX-GT200 CD Player Logo
591 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
