Question about LG WM-0532HW Front Load Washer
How to clean out drain hose
No water comes out of the lower drain plug hose...full of "gunk" The drain pump filter had money and water drains from it instead. How to dean out drain hose?
  • 1 more comment
  • gmjmom Mar 09, 2008
    I was told by the company that sold me my machine that I did not need to worry about the "door" on the front of my machine and that it is used when the machine needs to be serviced. I was happy that a few of my neighbors have this same machine (new models) and told me that they clean this hose out a few times a month or more. I have had my machine 4 years and this was the first time I tried to clean it out. Beware...if you have this machine I would recommend draining the hose and cleaning out the drain pump filter often especially if you are going on vacation. Also, use only the recommended amount of detergent and very little fabric softener diluted with water....to help prevent this "gunk" in your machine. These tips saved me from a service call.
  • Anonymous Mar 19, 2014
    when we fill water and drain hose we put on the floor all water is coming out
  • Anonymous Mar 29, 2014
    Water not draining out. Where to locate drain to clean
Believe it or not...I think it is fixed. I used a coat hanger to try to take out as much "gunk" as I could from the drain plug hose. I added warm water and then vinegar to the hose with a medicine dropper to help loosen the "gunk" I also forced air with the medicine dropper and I could hear it in the tub from the pump. Then I knew it was free of "gunk." I ran 3 hot cycles 2 with 1/2 gallon each of vinegar and one plain water cycle. Between each cycle I emptied the drain plug hose and drain pump filter. After the three cycles the water came out clean and not muddy. I also took a spray bottle of hot water and sprayed the "gunk" from around the seal to release it and out of the washer. I alternated with the spray bottle of water and vinegar applied with a small paint brush. I also noticed this "gunk on the stainless steel tub as well. I used the paint brush and painted vinegar on that and sprayed down with the hot water. I then did a load of towels and this morning my washer does not smell and is clean as can be...no more "gunk." what is that stuff anyway? Too much soap or softener? Anyone else have this problem? I was told by the service tech a few years ago that I didn't need to open that door because that is where they service the machine from.....wrong....I was to empty that drain hose from time to time. That was the first time I opened that door and the machine is 4 years old....
Posted on Mar 06, 2008
I was actually able to fix this problem by blowing out the drain hose with an air compressor. The drain hose was full of beach sand.
Posted on Sep 16, 2008
My hotpoint washing machine is showing error code F05
Hi
Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer. Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved.
Hope this helps... Please post back for further assistance.
Daniel
Apr 18, 2011 | Hotpoint Washing Machines
The front drain pump filter is plugged with sand and other build up. and then i'm getting a grey gunk in the washing drum, i'm assuming it is b/c the drain pump is blocked and it is coming back in the...
the best way to drain the machane is to lean the machine back prop something under it and then using a bucket take the drain hose out an bring it as low as you can to the floor. This will make it easer for you to open the front at the bottom an clean the drain trap ,it is possible that there will be a little water left in there good luck
Apr 13, 2011 | LG WM2487H Front Load Washer
Water will not drain cannot open door
The possible problems here are blockages or pump failure. Blockages are the more likely explanation but pumps can fail. If the washing machine will not empty the water out you may also not be able to open the door on some washing machines although these days it's much rarer to have a pneumatic lock on the door due to cost cutting (if a washing machine has a pneumatic door safety lock a rubber hose is connected to the door interlock from the pressure chamber bottle on the tub - water in the tub forces air up this tube and locks the door, which is released when the water is pumped out and the air pressure drops).
Some washing machines have a filter at the front of the machine that can be checked for blockages. Sometimes the filter is hidden behind a removable trim or panel at the base of the front panel. If your washing machine has a water pump filter and a filter drain hose you should be able to drain the water from the washing machine into a bowl without moving the washing machine. Open the pump filter flap and pull the small drain hose forward. Take the bung out and drain into a bowl. It's likely to be painstakingly slow but at least you don't have to try and pull out a heavy washing machine full of washing and water.
If your washing machine doesn't have a pump filter, or it has a pump filter but no draining hose then it's a bit trickier. To drain the washing machine, you will need to remove the drain hose from the drain pipe at the back of the washing machine, and lower it into a bowl or bucket. Many plumbers now plumb the drain hose into the U bend directly under the sink instead of a separate waste pipe at the back of the washer. If yours is connected directly to the u-bend, you can usually unscrew it easily. Remember though, that with the pipe disconnected from the U bend, any water poured down the sink will flood out into the cupboard until the hose is reconnected.
Once you have drained the water, you need to check for blockages in the pump by unscrewing the pump filter. If none is found, sometimes a blockage can occur in the plastic connector that the drain hose is connected to at the sink end (if connected this way)
Once you have the drain hose disconnected and lowered into a bowl or bucket the water should siphon out as long as the pipe is low enough. You are likely to get several bowls full of water from the washing machine. If little or no water comes out then it may be blocked by an item of clothing like a sock and it won't be possible to empty the machine this way or it is going to be a long process.
Once the last bit of water has drained out, the washing machine may now spin as the safety system for preventing a spin while water is in the machine will now recognize the water has gone and allow a spin. Keep the pipe low down and in the bowl or bucket and put the washing machine on a spin only program. Note, this last step is not strictly necessary as once drained, the door should open. However, you might prefer to try to spin a few more bowls of water out.
Clearly if you put more water into the machine it is likely to fail again until the fault is rectified but these instructions should at least get the clothes out.
Other possible obstructions could be inside the sump hose leading to the water pump. Many Hotpoint washing machines have a filter inside the sump hose which gets blocked. Finally, the pump itself can be faulty.
Dec 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Clogged up. Washed rubber backed rugs and the rubber shredded. It wont drain. How do I clean it out?
¡æThe drain pump filter
The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Dec 20, 2010 | LG WM-2277HW Front Load Washer
Hi got hotpoint aquarious wmf740. all lights flashing f-05 ? wont spin or drain. please help
Hi
Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved. Please post back for further assistance. Hope this helps...
Daniel
Aug 30, 2010 | Washing Machines
My lg washing machine is a semi automatic model 6.2 kg . water is not getting drained don't know why?
Sounds like a pump or drain hose blockage.. Check filter. Could also be the pump motor. The more resent synchronous pump motors get detritus inside them and gradually 'gunk up'. You may be able to drain the machine by lowering the drain hose and allowing gravity to help. this won't work if the drain hose is mounted high at rear of machine......Nomess
Apr 09, 2010 | LG Washing Machines
Stops during rinse cycle and water will not empty out of tub. ? switch to pump??? Now I have a tub full of dirty water that won't drain
Model may vary, but this could be helpful for sure.
1. Unplug machine. Drain out maximum water by lowering the drain pipe into bucket or lower drain.
2. Remove the lower kick plate under the door. There will be a screws in the bottom corners of the panel holding it on.
3. Find the drain pump. It will be on the right-hand side and is
usually white in color. The drain hose from the bottom of the tub
will be connected to it.
4. Remove drain hose from standpipe and connect a wet/dry shop vac (if you have one) to the end of it.
5. Turn vacuum on and watch the drain hoses from the tub and from the pump. If the hoses collapse, you have a clog somewhere.
6. Remove the drain hose leading to the pump. Check the impeller area of the pump for debris. This is usually where coins, clothing labels and other items get caught.
7. Clean out the pump and drain hoses. Located in the hose coming down from the tub is the filter, check this out for cleaning.
8. When finished, reconnect any drain hoses that you previously removed making sure you get a good seal with the hose clamp BEFORE you fill the machine. If you notice a leak during fill, hit the "cancel" button to stop. Make sure you place the drain hose back in the standpipe too.
Mar 19, 2009 | Kenmore Washing Machines
LG WM2016CW won't drain
The impeller may have come off the pump motor shaft. Generally, you will notice a louder sound when the pump runs if this happened.
Unplug the machine. Remove the filter recess by removing the one screw inside and using a putty knife at the left and / or right edge and popping it out. Pull the machine out about 18 inches and tip it back, resting it against the wall. Remove two more screws behind where the recess was holding the pump housing on. Reach under the machine and remove pump. There is a tab to depress under the pump housing to release it from the base. The pump motor is held onto the housing by three screws. Remove them and inspect the impeller to see if it has come off the shaft. If it has, pushing it back on will not solve the problem, as it will come off again. Install new pump motor and reassemble. Clean washer tub with the longest, hottest cycle and three Ah-fresh tablets, Whirlaway hot tub cleaner, Smellywasher cleaner (smellywashercleaner.com) or Tide washer cleaner. Repeat. From now on, use only 1 tablespoon of HE laundry detergent per load (1/2 T if 2X concentrate) and only 1 teaspoon of fabric softener per load if you use it. (these machines use very little water, and thus require reduced amounts of additives to work properly)
Feb 08, 2009 | LG WM-2277HW Front Load Washer
Bosch WFMC 3200 Front Load will not pump water out
the pump gears could be stripped or clogged with soap residue including the line from the pump to include the drain hose itself. I took the back of my machine off after cleaning the pump twice to find the reservoir full of a brown soap gunk/sludge. there is also a small rubber tube that runs from this reservoir back into the drum which was plugged shut with the same gunk. this thick soap residue can damage the pump motor or slow the drainage system to get the E 04 warning. I cleaned the gray drain hose out with the garden hose and was amazed at the sludge that game out. When the machine would run on the drain cycle we would also get a sewage smell that I thought was coming form the drain trap but turned out to be caused by the sludge in the pump. After cleaning the system and now using no more that a tablespoon of soap it works great & the cloths are clean.
Dec 18, 2008 | Bosch WFMC 3200 Front Load Washer
0E error
Product Laundry Washer
Symptom Error Codes
Sub Symptom OE error
Question Drain Problem Error.
Answer
Make sure that drain hose and drain filter are not bent or clogged. In case of there are objects in the drain filter, It might drain to slow or not at all. HOW TO CLEAN THE DRAIN FILTER 1. Allow the washer to cool down before cleaning the drain pump filter. 2. Open the lower cover cap with a tool such as coin. 3. At this time use a catch pan to prevent water from flowing onto the floor. Unplug the drain plug, allowing the water to flow out. When water does not flow any more, turn the pump filter open to the left. 4. Remove any foreign objects from the pump filter. After cleaning, turn the pump filter clockwise and insert the drain plug to the original place. Close the lower cover cap. If the drain filter is not clogged, you will need to call LG Customer Service at 800-243-0000.
Aug 18, 2008 | LG Washing Machines
Washing Machines Logo
5,759 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
