At a time 2 printer
Dear Sir
We require following system--
We require to interface two parallel port printer (one printer near toPC and second printer distance from PC to printer 50mtr) to our PC(operating system windows 98) and
Application software is dos based, both the printer will work at a time (same page will be print on both the printer).
kindly reply us at your earliest.
with regards
ashok chuadhary
sonal electronics
sankaripukur, near DIB office
Burdwan 713 103, India
mob:919732048919
  • Emelio Navaja
    Emelio Navaja May 11, 2010
    is the two computer connected to the network?
    Genius:
  • 1,226 Answers
Hello! Please follow the solution of lenny297
in which i cannot give you further solution because you did not reply my requested info.
thanks, melnavz
Posted on Mar 08, 2008
  • 133 Answers
You need to contact any technicians near you and ask them for a device called called a spooler, it looks like a network hub but for pararel connection, they old technology if u can get it. Good Luck.
Posted on Mar 06, 2008
How to install my tvs msp 345 champion printer?
This is a dot matrix printer made by TVS Electronics of India. It used the older parallel port interface (and had an optional serial interface). To hook it up, you'll need a PC with a parallel port, a parallel port cable and drivers. Most PC's no longer have parallel ports, so you'd need to add a parallel port card or use a USB to parallel port adapter. See: http://tvs-msp-printer-driver.blogspot.com/2009/02/download-msp-345-champion-plus-driver.html?m=1
Dec 26, 2014 | Office Equipment & Supplies
Interfacing EPSON Stylus 440 to Pentium Dual Core CPU
Current printers no longer have the parallel port and neither do computers. The printer can be connected through USB, Ethernet or even Wireless. If the printer has a parallel printer port and none of the other means of communications you should look for an adapter USB-LPT.
Oct 25, 2013 | Epson Stylus Color 440 InkJet Printer
Error badint 0085ddc0
The 'badint' error on the T6100 indicates the printers firmware has for some reason 'crashed', this error should not be seen in normal operation of the printer.
One common cause of "BADINT" messages is the use of an external print server or host computer with incompatible parallel-port settings. If you have an external print server connected to the printer's parallel port there is a setting on the print parallel interface that may need changing, to change parallel interface setting. • Set the printer to Offline. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access On) • Press the Mode key: display will show Offline Normal. • Press any Arrow key until display shows Offline Config. • Press the Forms/1 key. • Press any Arrow key until display shows Config Paralel. • Press the CPI/2 key. • Press any Arrow key until display shows Paralel Bi-Dir. • Press the LPI/3 key. • Press any Arrow key until display shows Bi-Dir Off. • Press the Enter key and the interface will be set. • Press the Clear key. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access Off) On the external Print Server, you need to ensure that the unit is also set for Uni-directional working.
Nov 04, 2011 | Tally Line Matrix T6100 Printer
Sir, We have a Genicom 6312 L Line Printer. This printer is attached with UNIX (5.9) system. It was working fine till few days back. Recently we changed the Logic Card. After this the printer is not...
If the printer does not print from Unix via parallel interface, it may be nessesaey to set the BI-DIRECTIONAL setting within the Parallel interface settings to OFF.
Sep 21, 2011 | TallyGenicom 6312 Matrix Printer
Error lost cpu rest
This error on the T6125 may be caused by either a hardware fault with the printer, alternatively the problem may be caused by some sort of external influence on the printer. Passable resolution to the problem include;
Hardware Fault
Locate the main logic board, check the CPU to ensure all pins are soldered correctly on the PCB. Check there is no solder over spill shorting any of the pins.
There may be a fault with the main logic board which may require replacement.
External Influence
1) External Print Server
One of the most common causes for the LOST CPU error is the use of external print servers connected to the Parallel Interface.
These printers are not reliable if connected to external print servers unless the printer parallel interface has been set Uni-Directional. To do this, you need to follow these instructions.
Press any Arrow key until display shows Config Parallel.
Press any Arrow key until display shows Parallel Bi-Dir.
Electrical Interference
Check the area around the printer to ensure there is no external electrical interference eg Electric Motors, High Voltage Cables in near vicinity of the printer.
Feb 21, 2011 | Tally T6215 Matrix Printer
My HP LaserJet 2420 has disappeared from my "printers" control panel. The printer is connected via USB. I have swapped cables and have tried to install it on another computer with NO result. There are NO...
There might be a problem with your computer as well. Try printing with paralell cable to make sure the interface works at all. If the patalell-port works fine, try updating the printers firmware. Still problems ? Try with a different computer. If if works fine with another computer, then you know theres something wrong with your first computer. Good luck.
Aug 10, 2009 | HP Hewlett Packard LaserJet 2420 Printer
What do "ports" mean when adding printer?
An interface on a computer to which you can connect a device. Personal computers have various types of ports. Internally, there are several ports for connecting disk drives, display screens, and keyboards. Externally, personal computers have ports for connecting modems, printers, mice, and other peripheral devices.
Almost all personal computers come with a serial RS-232C port or RS-422 port for connecting a modem or mouse and a parallel port for connecting a printer.
On PCs, the parallel port is a Centronics interface that uses a 25-pin connector. SCSI (Small Computer System Interface) ports support higher transmission speeds than do conventional ports and enable you to attach up to seven devices to the same port.
In TCP/IP and UDP networks, an endpoint to a logical connection. The port number identifies what type of port it is. For example, port 80 is used for HTTP traffic.
Also see Well-Known TCP Port Numbers in the Quick Reference section of Webopedia.
Thanks for using FixYa - A FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 16, 2009 | Panasonic Toughbook CF-51 Notebook
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
What are the system requirements of the DiMAGE 5?
System RequirementsIBM PC/AT compatible computer with preinstalled Windows Me, Windows 2000, Windows 98*, or Windows 98 Second Edition* and with a built-in USB port as a standard interface.Power Mac G4 (includes dual processor G4 and G4 Cube) series, G3 (Blue and White) series, iMac series, iBook, or PowerBook G3 with preinstalled Mac OS 8.6** – 9.1 and with a built-in USB port as a standard interface. • Problems may be encountered depending on what other USB devices are being used in parallel with this product. • Only a built-in USB port is supported. Problems may be encountered when the camera is connected to a USB hub. • Normal operation may not be possible even when all the system requirements are met. * Users of the Windows 98 and Windows 98 Second Edition must install dedicated driver software included in the DiMAGE 5 and DiMAGE 5 package. ** Users of the Mac OS 8.6 must download free dedicated driver software from the Apple Computer web site and install it.System requirements are based on the latest information available at the time of printing and are subject to change without notice.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Open Questions:
k24674
jasbo
jasbo
Marvin
Marvin
