Question about Lexmark X5150 All-In-One InkJet Printer
My lexmark printer will not power up.
Is there a fuse in this unit
Nothere is not
my printer says its a z515
Posted on Mar 06, 2008
My printer doesnt work it doenst switch on at all
If printer doesn't work and it doesn't switch on, I assumed that there is no power at all on the printer. Check the AC line voltage if it is correct.
Unplug the printer. Remove the LVPS/HVPS, and check the fuses for continuity.
• If open, then replace the LVPS/HVPS.
• If not open, then check the switch continuity across its conductors with the switch on.
Turn the switch off. Plug the AC line into the LVPS/HVPS, and switch unit on.
Please try reseat power cable. If this does not resolve the issue, you may need to replace the LVPS (Low voltage power supply) on your printer.
For further assistance, please contact Lexmark Technical Support
Feb 07, 2011 | Lexmark E260 Laser Printer
H2 service call fuser unit
I had this error, bought a new fuser unit (1/2 price of printer) dd not fix problem. Placed service call with Lexmark, who qote around $900AU to replace power supply. No more lexmark for me.
Oct 09, 2010 | Lexmark X502N COLOUR LASER MFP All-In-One...
My printer is not working
Possible failure of the power supply unit. open and check for a fuse , if the fuse blows off then the SM driver , capacitor may be faulty , you can repair or replace.
However if power comes on then uninstall and reinstall the printer after disconnecting and try.
Helpful?
Aug 20, 2010 | Lexmark Office Equipment & Supplies
Lost our power and now it won't turn on.
Yes , usually you will need the manual to know how to replace it
In my experience the fuse blow due to something that is electrically faulty in the unit and changing the fuse does not remedy the issue. You may have a power supply issue that a reputable service tech will have to determine if it is malfunctioning in this area.
Jun 18, 2010 | Lexmark X2500 All-In-One Printer
Says 122.05 Service fuser error on screen
A 122.05 or 122.06 Fuser error indicates that the printer/MFP has detected a problem with the fuser unit. A service call will probably be required to solve this issue. However, certain rare occurrences, such as a power fluctuation or a static discharge in the vicinity of the printer/MFP, can cause a false 122.05 or 122.06 error message to appear. In such cases, the error is only temporary and can be easily resolved without service.
Lets assume this is a power problem, do you have a digital or remote phone unit close to the printer or your computer,a) try moving it for a day or so to test to see if that is the problem b) is it connected to a power surge unit (if so take it out and plug directly into the outlet) power surge strips or units have fuses in them it may be going also.always remember shut down units properly for these test
shut down machine, then power up so the computer and the printer are reading eachother properly. if not go to http://support.lexmark.com/index?page=content&id=SO4745&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=&searchid=1275926294153
Jun 07, 2010 | Lexmark C544dn Laser Printer
Power failure
Unplug the power supply(the black box behind the printer where the power cord is attached) from the printer. With the power cord plugged in to a known working power outlet in the wall and the other end securely plugged in to the power supply, check for voltage output. If still none, Lexmark may be able to send you a new power supply for free. You can contact Lexmark at 1-800-LEXMARK(1-800-539-6275).
Apr 28, 2010 | Lexmark X1290 All-In-One InkJet Printer
No power to the unit does this have a fuse inside?
I consider not to do anything to your printer for there is no serviceable parts inside. If you done all the things to your printer like checking the power connections, then you must bring it to the nearest printer repair center in your place.
Nov 03, 2009 | Lexmark X2470 All-In-One InkJet Printer
Error 2200
Step Action
1 Power off the printer and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the printer on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the printer and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the printer on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the printer.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the printer on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Sep 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark printer error at power up
pc stands for photoconductor or print cartridge or in layman's term toner
the toner has reached its expected life or toner has ran out
Oct 03, 2007 | Lexmark Optra SC 1275 Laser Printer
Lexmark X5150 All-In-One InkJet Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
