Question about Mitsubishi VS-45607 45" Rear Projection Television
Blue Convergence For about six months now my tv will have a blue shadow on everything for long periods of time. Once in a while I can fix it when I use the blue convergence function in the menu. I haven't been able to fix it for quite some time now and I was wondering if there is something that I can do to fix this problem so I can finally get rid of this blue shadow. Thanks so for much for any helpful suggestions..
  • etr140 Mar 16, 2008
    Convergence problem with Mitsubishi VS-45609. Can adjust red. But blue can adjust most of horizinal lines. But can fix vertical on right side from middle of grid, no luck on left of grid?
  • Mitsubishi Master
  • 8,617 Answers
You will need to change the convergence amp ICs there are 2 of them they cost around 12 dollars each.
Posted on Mar 06, 2008
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi RPTV has a blue shadow/image alignment problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 23, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I have a sony kp 48s and there seems to be a blue shadow on the picture?? i've tried everything in the settings to fix it but it just seems like a manufacture malfunction?
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 28, 2010 | Sony Televison & Video
Picture has red and blue shadow images
thats a fairly easy fix. You need the DPTV305-DPTV345 convergence repair kit available at the following link.
http://servicemanuals.vstore.ca/
The kit contains the parts and the CD with instructions
Sep 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue Shadows
You need to install a convergence repair kit. The PT47WX42 Convergence repair kit at the following link is the correct one for your model. The kit contains both Convergence ICs and the six feed resistors, Plus the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 20, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Blue Convergence
Hello All Above,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Mar 11, 2008 | Samsung HCN653W 65" Rear Projection...
Blue Shadowing
Yes it sounds like convergence ic's
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 29, 2008 | Hitachi 50UX57B 50" Rear Projection...
Blue shadow
If the blue shadow is convergence you should have an option for convergence adjustment via the remote control to converge the blue onto the green. If it doesnt move then its probaly a IC problem. What make and model set do you have?
Jan 02, 2008 | Televison & Video
Mitsubishi VS-45607 45" Rear Projection Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
