Question about Adobe Photoshop 7.0 for PC
In design CS3
From yesterday to today my In Design programme will not allow me to export to a PDF file, will not let me save or import graphics, the little coloured wheel just keeps turning, and then it quits programme, have a lot of work to do and is very frustrating.
    Genius:
  • 1,226 Answers
Hello!
Try unistalling the indesign and restart the computer. after restarting install back the indesign to resolve the problems.
hope this help, melnavz
Posted on Mar 06, 2008
Www ehow com
Use a PDF maker, like Adobe Acrobat Pro. I assume the psd file is an Adobe Photoshop file. Perhaps there are even other "free" PDF program m's.
The best way would be to save the psd files in Photoshop as a jpeg first, because lots of other programs could convert this to PDFs.
Aug 18, 2014 | Adobe Computers & Internet
How to save as pdf?
have you tried save as, export? Some programs will not let you save the file in pdf format using the save selection. Sometimes you have to use a save as, or save copy, or export before the pdf option will be available. Sorry im a Illustrator user I didn't care much for corel.
Mar 18, 2014 | Corel Draw 8
Corel draw 8 is not save as pdf?
It's been so long since I've udes CD8 but I would say it won't support exporting pdf. If I don't remember wrong I exported file as postscript file (*.ps) and then used Adobe Distiller to create pdf-files. But there might have been a trick or a two to notice for correct output :)
Adobe acrobat .pdf
you have to export that file to .pdf
and only the acrobat reader 5.0 is not sufficient for write the file to pdf
you need acrobat reader for doing so.
Jan 03, 2010 | Adobe PageMaker 7.0 for PC
Encore CS3
If the audio is multiplexed into the same file as the video, and the audio needs to be transcoded, then Encore has to transcode the entire file.
Try splitting the video and audio into separate files (demuxing) when you create your assets for import into Encore.
do it ............now
Oct 14, 2008 | Computers & Internet
Photoshop cs3 error
You have to 'Export' the file. You'll be offered Quark 7 or 6 for file type.
Jul 15, 2008 | Adobe Computers & Internet
Rendering problem in Premiere Pro CS3
I would suggest u to reinstall the software. after this it should work
Jun 26, 2008 | Adobe Photoshop 7.0 for PC
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Thanks,
Lee
Jun 18, 2008 | Adobe Photoshop 7.0 for PC
Photoshop CS3 Error
I've never heard of this, unless the user is saving to a PDF format. Have you tried saving a Photoshop document in a different format? Photoshop files are: PSD's or PDD's. I have only ever seen 'presets' in PDF format. In CS3, these are set by selecting: Edit> Adobe PDF Presets.
Apr 23, 2008 | Adobe Computers & Internet
Adobe Photoshop 7.0 for PC Logo
53 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
