Back to:
Tags:
Print Servers
Generic problem for all Print Servers
Dvd burner
posted by freedom1916 on Mar 06, 2008
hey i bought a dvd burner at best buy the guy told me that this would work in my computer ,i lost my manul and cant figure out how to install it in the slot
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 12, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
english manual for pixma mp140 (canon)
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on dvd burner:
I don't want to Accept this solution
Solution #2
posted on Mar 20, 2008
Not Rated (0)
peglegcards
Rank:Wiz Wiz
Rating: 85%, 64 votes
Hello, You'll need to remove side panels and front cover. CD ROM will slide in from the front. you'll see 2 screw holes on each side of drive and slots in housing of computer. Install 4 screwws. There are 2 cables to attach, power and data. If it is a Serial ATA(SATA) you'll need to use a serial data cable. Power can be either serial or 4 pin Molex cable(from power supply). If it is IDE ATA drive you'll need to use a ribbon cable for data and 4 pin molex for power.. It is a simple procedure. Once hardware is installed, reattached front cover and side panels. Boot computer, it will detect new hardware and ask to install from disk. Insert disk and follow directions. Hope this helps.
Thank You!
Can you Help with these Print Servers problems?
Sharp Printer Extended Kit (AL-11PK) Print...
Sharp AL121E copier with AL-11PK printer upgrade Kit...
Print Servers
examples of graphs of the fundamental functions and...
Lexmark Refurbished MARKNET X2000 SERIES...
I have just purchased this device and have rest the IP...
D-Link DPR1260 Rangebooster G Multifunction...
I have a problem to use with my printer server DPR1260. I...
Canon CANON COMPUTERS SYSTEMS BLUETOOTH...
how do I bluetooth enable my canon printer so I can beam...
Loading problems.
Repair Service
Find Print Server Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
