Question about Daewoo DV-6T955B DVD Player/VCR
Daewoo DV-6T955B DVD Player Problem
My name is Kate and am having problems with the DVD player of the DV-6T955B product. The TV is on and after I load the machine it reads "no Disk." It won't play. The problem is that there is a disk in the machine. What am I doing wrong? Did I break it? Your advice would be great. Any free advice would be appreciated
Thanks,
Kate
sstani3@gmail.com
  • workingoutK Mar 07, 2008
    Hello
    Thank you for getting back in a prompt manner. Yes I played other DVDs they seem to work. Two thousand and seven would be the date of the player. Maybe it is the disk that is causing a problem, I will get back to you again when I have a little more time.
    My reguards,
    K.
  • Jaime Hernandez May 11, 2010
    How old is the DVD player?
    Have you tried to play different DVDs you know they are good?
  • 3 Answers
This DVD/VCR combo unit must have a weak laser, because I have the same issue. We have another DVD player in the house, and that machine plays DVDs way better than our Daewoo plays them. If there are ANY marks, finger prints, scratches, smudges -- whatever -- it does one of 3 things: 1) plays with many skips or long pauses and jumps, 2) refuses to play at all, or 3) refuses to even see the disc.
I clean the disc with a VERY, VERY soft cloth & rubbing alcohol. Also, got one of those CD/DVD player cleaner discs for the machine too. If you rent the DVD, ask if the store can PROFESSIONALLY repair the disc (if it has scratches) before you take the disc home to your machine. Don't bother buying those home repair machines, trust me; they are a ripoff.
OH yeah! Almost forgot to tell you -- make sure that you don't cover up the air holes of the outer case. The machine will heat up way too fast, then it won't play anything at all (including VHS tapes), if these air holes are covered up. The air holes are on the top and both sides.
Of course you know that this machine is limited to only playing these formats: CD-R, CD-RW, DVD+/-R, DVD+/-RW, VCD (Video CD), and SVCD (Super Video CD). This machine was not built to play DIVX or XVID formatted CD/DVDs, therefore it will not see them either.
Posted on Jan 22, 2009
  • 3 Answers
I have the same model and i can put a disk in and it will read it then the next time he same disc and it says no disc. when this happens I use a dvd cleaner disc, ( its a DVD with a little brush glued to it) it seems to help. and I know this goes against everything you have ever learned about discs. but sometimes I find if the disc is to clean and shiny, the 6t955b has trbl reading it, rub the disc on your shirt or pants and make some lite swirl marks on it. not sure why but it works
Posted on Apr 20, 2008
I need the manual of dvd daewoo dvd 6t955b, please send it to irra1959@yahoo.es
Rafael
Posted on Mar 11, 2008
  • 2,326 Answers
If your DVD is less than a year old, still under manufacturers warranty.
The problem you have "no Disk" is because the laser is not reading the DVDs.
Call the Main support number at 800-323-9668
Support FAX 973-384-9250
Email support service@e-daewoo.com
Posted on Mar 08, 2008
Daewoo DVD-T "copy not possible - this media cannot be copied" when trying to copy from VHS (tape is not copy protected) to blank DVD-R and +R media. Same problem with all DVDs and VHS tapes
You can only copy non-commercial VHS tapes that you have recorded yourself to DVD. You can\'t make copies of most commercially made VHS movies due to copy-protection.
Dec 29, 2013 | Daewoo DV-6T955B DVD Player/VCR
Dvd not reading making alot of noise
Clean the DVD player. I think lot of dust and foreign particles must have been settled in.
Oct 29, 2012 | Daewoo DV-6T955B DVD Player/VCR
Misplaced remote control need a remote control
Hi, buy it here on Ebay:
http://cgi.ebay.com/Original-Daewoo-DVD-VCR-Remote-97P1RA2BA5-97P1RA2BA1-/400160550410?pt=LH_DefaultDomain_0&hash=item5d2b6d6e0a
Good luck
Nov 29, 2010 | Daewoo DV-6T955B DVD Player/VCR
Connecting a Dvd dawoo Model DV6T844B to the TV
Easiest way is to use a SCART connector from AV1 to the TV
Jan 30, 2010 | Daewoo DV-6T955B DVD Player/VCR
Cannot get any info on tv screen
Hi there?
May I know what exactly the main problem, "cannot get any info on tv screen". I f you mean that there was no output or your device was not displaying video to your tv.
First check;
wire
  • (if it has damaged or have a worn part).
connection
  • check if you have properly connect each connection firmly into the inputs.
  • check if you have interchange the I/O Audio to Video.
mode
  • check the if you have set the correct video mode, some sets has 1 & 2 video inputs mode.
power
  • see if there was a power coming on your player, or it has a power.
Hope this helps.
Aug 08, 2009 | Daewoo DV-6T955B DVD Player/VCR
CHANGE ZONE 0
1. Open DVD tray.
2. Entre 0520 using remote.
3. Press keys in this order: UP, DOWN, LEFT, RIGHT.
4. Enter region code, 0 for complete code free.
5. Close DVD tray.
May 26, 2008 | Daewoo DV-6T955B DVD Player/VCR
Daewoo DV-6T955B VHS/DVD player problem
It's likely the spindle motor needs to be replaced. You can sometimes get a bit more mileage out of them by placing a tiny drop of WD40 down onto the shaft below the table and working that into the motor.
Bill
Mar 02, 2008 | Daewoo DV-6T955B DVD Player/VCR
Parental block password
Hi.
Providing you never put one in of your own The default password is 0000
http://dysonmanuals.llc.nu/
Chris.
Feb 20, 2008 | Daewoo DV-6T955B DVD Player/VCR
Daewoo DV-6T955B DVD Player/VCR Logo
349 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
