Question about Philips 60P8342 60" Rear Projection Television
Reaccuring problem I have a philips rear projection tv.The tv does not turn on, I tried changing out the 3 fuses but when i go to place or remove the third fuse I get a spark with the TV unplugged. The original fuse has stamped 5H 250V. The fuses they gave me at radio shack was stamped F500ma H 250V Grade A Buss.The ohm reading on the existing fuses is 000.The new fuses read 1 . With the new fuses in the TV turned on for a few seconds with no picture, then I heard a click and it shut off. would'nt turn back on! How can i trouble shoot this problem in sequence to resolve this issue, Please respond or call me if possible
  • Spytech Mar 06, 2008
    I replaced the fuses because 1 of them I tested was blown, so I replaced all 3 to be safe!
  • Anonymous Apr 02, 2008
    Where to get Fuses for a Norcent PM-4203A Television
  • 2,335 Answers
The main fuse, it should 5A/250V. The one you bought is 0.5A/250V and it will burn because it can not handle the amount of current that passes through it.
The other fuse that sparks even when the TV is unplug because is the charge of a capacitor that circulates when you place the fuse.
Just curious why you had to change the fuses?
Posted on Mar 06, 2008
Why does the power button blink on and off and the TV doesn't turn on?
There may be an open internal fuse or the power supply may have failed.
May 25, 2015 | Philips Televison & Video
RCA 61 INCH REAR PROJECTION MODEL # P61929 PUSH
The first place to start is the outlet and check to be sure it has power. The next is to check / replace the main internal (to the tv) fuse - it's a 5A 250V GMA fuse (google image of GMA fuse). To find the fuse, unplug the set and remove the back cover of the TV - follow the power cord to where it enters - the fuse is located to the right and slightly ahead of where the power cord is attached to the board.
Nov 08, 2009 | Televison & Video
Philips 51PW9363-17F - No picture but has sound
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Oct 12, 2008 | Philips 51PW9363 51" Rear Projection...
Magnavox rear projectin television
Check the fuse first, if you are luck, probably you only need to change the fuse otherwise you probably need a new TV.
Turn off home electrity power or unplug all the expensive units when it is lighting to protect them.
Jul 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Turns on but no picture or sound.
please check the connection wire/cable that gives power to your tv. if no fuses are blown. it may be a capacitor problem.
Mar 30, 2008 | Philips 50P8341 50" Rear Projection...
I have a problem
You have a power supply problem. What is the chassis number of your set? Let me know the chassis and I may be able to help you out.
Mar 02, 2008 | Philips 60P8342 60" Rear Projection...
Fix it
Yes, there are many fuses in this set some looks like the regular fuse, others are small pica-fuses. Look for 25-2600, 1801, 1300, 2000-1 these are some numbers you can look for to see if open.
Dec 05, 2007 | Philips 60PP9352 60" Rear Projection...
My tv
may bethe capcitors get burned off . caheck ur main board with adeqaute saftey procedures
Dec 03, 2007 | Philips Magnavox 51MP392H Rear Projection...
Tv power button flashing no picture or sound
Short in powersupply check secondary fuse and all other fuses too. Were there a color problem before this/ Because most of these set have convergence problems. The amps May need to be changed and resistors around them.
Aug 25, 2007 | Philips 60P8341 60" Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
189 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
