Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Won't stay on , not very consistent
My heater will sometimes stay on for several minutes . but then it shuts down for no reason , I let it stay off for a minute and turn on it starts up and then it might run it might not for very long.
and what are the two adjustments screw heads on the back of heater .
  • 232 Answers
You don't state whether this heater has the old style spark plug technology or the newer Hot Surface Ignitor technology. Troubleshooting will be different, depending on the style of heater, because the electronics are different.
You ask "what are the two adjustments screw heads on the back of heater". As stated by tros1 these are A. an air pump adjustment screw, and B. a pressure relief valve.
Both technologies require correct pump pressure in order to deliver the fuel at the proper rate. For a pressure setting video
http://youtube.com/watch?v=NeM3Yi9Y1oE
Reply with the model number and/or the specific ignition technology and maybe we can help.
Posted on Jun 09, 2008
    Problem Solver:
  • 19 Answers
First clean the filters and the nozzle.
One of the screw heads is a plug to install a pressure guage.
The other is the fuel pressure adjusting screw.
Posted on Mar 06, 2008
Recently our laptop (4yo) shut down unexpectedly after being used for 45min to 1 hour! I was wondering what the issue is? Is there anything which can be done by us? We are out of warranty.
things that happen to older laptops are that over time there tiny processor power supplies build up with lint from the air that is passed thru them sometimes even making the tiny cooling fans in there stop , then its only a matter of a few minutes and it overheats and shuts off , after several hours cool own it will restart , but wont stay on long , then the cycle repeats . if its caught in time and no power supply parts are ruined sometimes a Pc repair shop can dismantle one and clean it
Dec 03, 2015 | Samsung RV520 Laptop
My fireplace lights but shuts down within a minute and pilot goes out. Pilot will relight but Fireplace will not relight for a while. Keeps doing this, will sometimes stay on. Does this describe enoug
Sounds like a sensor problem or a gas blockage. Get a gas expert to look at it. Gas is dangerous and can cause severe burns or explosions resulting in loss of life and property.
Oct 03, 2014 | Heating & Cooling
What Could Cause My Computer To Shut Down For No Reason?
What brand of pc is this? Download a diagnostic program to test internal functions. Sounds like maybe a motherboard or power supply issue.
Jul 28, 2014 | Dell Inspiron 530s Desktop Computer
Frigidaire model PHS69EJSS0 water leaking in ice makier freezing up evaporator fan
That might be a bad drain. Thaw her out. Clear the drain with hot water or blow it out best ya can and see if that fixes it. That is what you try first. If the problem still there ya might have a defrost problem. The defrost circuit consists of a heater a heater termination thermostat and a timer or defrost control. Every 8 hours or so the defrost control powers up the heater for 21 minutes or longer AND shuts down the compressor and fans.if the heater was to stay on for 21 minutes or longer it would melt the plastic ling and cook the frozen food because it is a calrod heater just like an oven element. The heater must shut down to prevent harm to the ice box so they install a small thermostat that shuts off power to the heater when the temp inside the evaporator sector is warm enuff ta melt frost. Most times the heater does not go bad if it is a metal calrod style, glass heaters do go out quite frequently however. The most likely candidate to fail in the defrost circuit is gonna be the termination thermostat. When that puppy fails the evaporator does not get the heat from heater and frost begins to build. It takes several weeks to get to the point that ice has dammed up into the evap fan and caused it to malfunction. The cheapest part is the defrost thermostat so if the heater is fine replace the stat and see if that fixes it. Other thangs to check for is loose or worn out door gasget and improper sealing doors. To make a door close tighter raise the support legs in front slightly to throw the doors tighter against the frame. That's all the smart pills I has for today. -PawPaw
Dec 26, 2013 | Refrigerators
Water heater pilot light will not stay lit. changed the thermocouple, and still won't stay lit.
Hold the pilot button down for a full minute after it lights, then release. If this does not work then the thermocouple is not adjusted where the flame is heating it or you just have a faulty new thermocouple.
Sep 06, 2011 | Heating & Cooling
Laars LX 250-L won't fire up
It was the water flow swith not making all the way. I temporarily jumped it out until I get a new one.
Thanks Ron
Jun 13, 2009 | Heating & Cooling
Stays lit for 25 minutes and shuts off
How large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
Jan 19, 2009 | Mr. Heater (F274825)
Samsung HLP6163wx
when is the last time you changed the lamp ?  are the fans clean
Oct 15, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
186 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
