Question about MTX Ford Explorer/Mercury Mountaineer/Mazda Navajo 1991-2001 Thunderform Loaded with 10 Inch Woofer and ... Car Speaker
Power windows all of my power windos will not go up or down they worked for a while and now they are stuck down
    Scholar:
  • 52 Answers
Have you checked the fuse and the relay?
Keever
Posted on Mar 06, 2008
97 ford expeditions front power windows do not go down when vehical is running. They sometimes will work if you push the back window up button and the front windoe down button at the same time. They also...
Sounds like window regulator switch is bad or contacts need cleaned. If they are intermittent then it is likely a wiring or switch contact issue
Sep 24, 2013 | 1997 Ford Expedition
Stuck Computer System
It might be something as simple as a hung update. Hold the power button down until it powers down and turn it back on again. It will prompt you asking how you want to start Windows. Just choose "Start Windos Normally". If that does not work then then power down again and the next time choose "Last know good config".
Oct 22, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
All four windows wont work
look at fuse relay if goog it may be the power windo master controle.it is the one on drivers door that works all the windos all the windo power gos out of it
Apr 11, 2012 | 2000 Buick LeSabre
The power windos are repeatedly going down by themselves with the engine off.
you might have a faulty key remote. when u hold down the unlock button on the remote long enough the windows will come down without the engine being on. check if the button maybe stuck.
May 31, 2011 | 2004 Nissan Maxima
Power windos stoped working
if they all stopped working at the same time, I would suspect a fuse has blown. Look in your owners manual to see which fuse affects the power windows
Mar 26, 2011 | Ford Mustang Cars & Trucks
The driver side power window is down and wont close the motor turns but the windoe dosent move.
sounds like you need a new power window regulator (the mechanism that moves window up and down)
Jan 29, 2010 | 2001 Hyundai Tiburon
Have a 1999 alero-driver side windo quit working --took panel off motor works but cant see how any thing hooks on windoe--2.4-olds alero
IF WINDOW MOTOR WORKS FROM SWITCH.THE WINDOW REGULATOR IS CAUSING WINDOW TO BIND.CHECK REGULATOR FOR BINDING BY DISCONNECTING GLASS FROM IT.MOVE WINDOW UP AND DOWN BY HAND.IT SHOULD MOVE FREELY AND SMOOTHLY.IF NOT REPLACE DAMAGE REGULATOR REPLACE.LUBRICATE NEW PARTS.
Nov 07, 2009 | 1999 Oldsmobile Alero
Driver's side power window grinding noise, not working
window is off its track with probably some broken guides...cheap to fix. Pull the door panel with the window all the way down remove the weather guard wrapping and roll windo up Identifying the problems aas you roll it up. Fix and replace and lube those parts theen reinstall.
Oct 13, 2009 | 1993 Acura Integra Hatchback
Where is the fuse for the power windows on my 2000 Dodge Durango?
i pretty shore they do not have a power relay .see fi you have power to your windo switch . if you do and your windo still duse not work then its your switch ok have a great day
Mar 29, 2009 | 2000 Dodge Durango
Car Audio & Video Logo
82 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
