Question about Insignia NS- 27" TV27 TV
My parental control lock is on my insignia tv buttons wore off :(
Model number istvca102212
can u help me please?
To Fix my problem I called Insignia and All I Had to do was hold down the display button for 5 seconds? Thanks for the help but looks like I saved $20 Bux.
Posted on Mar 27, 2008
How to use parental control
You can enable customize Parental Controls via your TV's on screen menu. If you have previously set a password, you will need to re-enter your password to begin. If you have forgotten your password, try 0000 (four zeros) or 3448 (the default password may vary by TV model, so consult your User Manual for details). You can find detailed instructions for using the parental controls in your TV User Manual, available for download at InsigniaProducts.com. Just search for your TV model number and click on the Support/Download tab. I hope this helps.
Nov 23, 2011 | Insignia Televison & Video
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
How to disable the parental control lock for Insignia NS-Lcd19? I never enabled the pc and have not had this problem before-tv 3yrs old. Please help. I checked the manual and followed the instructions...
If you have never set a password for the Parental Controls, enter 0000 (four zeros). If you set a password (or believe one was set accidentally), use password 3448. You should then be able to change or disable the controls. If these steps do not work as your message indicates, your TV may require repairs. Service can be obtained by carrying the unit in to the place of purchase.
Nov 09, 2011 | Insignia NS-LCD19 19 in. LCD TV
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
Our kitchen tv is lock on Child, we didn't knowingly do this our children are over 35, it wants a password which we also have never given our tv's a password. How can I get this undone. Judy
Hello there,
If you didn't set any password, the default password for most Insignia TVs is 0000. If this doesn't work, you should be able to use 9999 to override or reset the password. After unlocking the TV you may also need to switch off the parental control (V-Chip) feature from withing the on-screen menus
If these numbers don't work or you need assistance with switching off the parental control feature, please reply to me with the model number of the TV.
Regards,
BElectric
Mar 18, 2011 | Insignia NS-LCD19 19 in. LCD TV
Need to know how to reset the password forgot the original password to unblock channels
You didn't specify the model number of the TV but many Insignia's TVs use 9999 as a master password which you can use to unblock channels or reset the password if you forget the one you set. 0000 is the default password, but this can't be used after setting your own.
Please try the 2 passwords above. If you are still unable to unlock the TV or need help with changing the password, or parental control settings, please post back with the full model number of your TV for further assistance.
Hope this helps.
Regards,
BElectric
Mar 05, 2011 | Insignia 42" LCD Flat-Panel HDTV
I bought an insignia tv at my local Future Shop as an out of box item. My problem is that is didn't have a hand held remote and there is a parental lock in place that will not allow me to watch 14+...
Acessing personal secrect codes is not possible,could be anythings,tries call Insignia tv customer service 1-800... telephone line in ur manual ask them how to reset personal screct codes.Must have the original tv remote to do this,like entering numbers.Try website like Remotes.com to buy an exact remote to ur original tv remote.
Nov 15, 2010 | Insignia Televison & Video
Locking Controls of Insignia 40'' LCD TV
Alas, I have been through this with my children and unfortunately outside of a Parental Channel lock, I have not heard of a vendor who has created the capability of locking the set controls. It's just the unfortunate case that the controls are accessible to the child (I have another TV where they are on top and even my 9 yr old can't reach them - ha ha).Sorry my friend.
Jul 24, 2010 | Insignia 42" LCD Flat-Panel HDTV
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Parental controls
wuts the model # on the television
Nov 03, 2007 | Insignia IS 20" TV040919 TV
Insignia NS- 27" TV27 TV Logo
639 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
