Question about Microwave Ovens
I HAVE A COUNTER TOP MICROWAVE MODEL #KOR611Q, AND EVERY TIME I PLUG IT IN IT BLOWS THE FUSE. I HAVE CHECKED ALL THE RECEPTICLES ON THIS CIRCUIT WITH A RECEPTICAL TESTER, EVERYTHING ON THIS CIRCUIT WORKS PROPERLY. THE ONLY THING I CAN THINK OF NOW IS TO CHECK TO SEE IF THE BULB IS BACK FEEDING, ALSO IT DOES NOT THROW THE BREAKER.I'M NOT SURE THATS THE WAY TO WORD WHAT THE BULB CAN CAUSE.I HAVE PLUGGED THIS MICRO IN EVERY RECEPT. AND IT DOES THE SAME THING
  • FOX667 Mar 06, 2008
    my problem is i can't figure if the bulb is a slip in bulb or a screw in bulb, i have tried both ways and neither seems to come out successfuly. if i break the bulb then i have bigger problems. i have tried for an hour. thank u for helping
Didn't solve the problem, but not for lack of your help. appliance just dead.... THANK YOU
Posted on Mar 06, 2008
    Scholar:
  • 104 Answers
Remove the light bulb, if it still blows the fuse then it's not a bulb problem. More than likely the Magnetron has gone bad and is shorting. Be extremely carefull working inside any Microwave, it can be very dangerous! Sorry to say, but it sounds like it would be an expensive repair compared to a new (or used) oven.
  • Barry Gardner
    Barry Gardner Mar 06, 2008
    If the base of the bulb is about an inch across it is probably
    threaded. A smaller bulb is probably a bi-pin twist in like an
    automotive lamp, but could also be threaded. In either case it turns
    left (counterclockwise) to release. If the lamp does break you can
    still remove the base by inserting (with the unit unplugged of course
    :) a flat tool a little smaller than the diameter of the base, pushing
    hard and twisting. Sometimes it is easier to remove the broken base
    than getting the whole lamp out. Be careful not to cut yourself on the
    edges of the broken glass!
The unit shut down when I attempted to heat some food.The circuit was blown and had to be reset.Did it blow a fuse and if so can I change it.
Is it a built in or counter top model? If countertop
, check gfci.
Do the lights/ panel work? If so, could be many things including door switch, fuse etc.
Oct 12, 2015 | Microwave Ovens
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
Internal fuse
Is this an over-the-range (OTR) microwave oven or a counter-top model? Assuming it is an OTR model, your can get to the fuse by first unplugging the microwave, then removing 2 to 4 screws over the grille vent. Remove the grille vent. Depending on the model, you either slide it to the left a little bit (1/4 inch) then pull it out, OR tilt out the top of it followed by the bottom. Now you should see 1 screw that hold the top of the control console in place. Remove it, then lift up on the control console to get past the tabs, and tilt out the top. Now, depending on the model, you may see the fuse behind the control console, or if it's not there, then remove the 1 or 2 screws that hold the metal grill vent that's located above the control console. Remove that metal grill, and your should see the fuse behind it. Sometimes that fuse blows for no good reason, other times it blows because you have a shorted high-voltage capacitor, or you may have a sticking "monitor" door switch.
Aug 31, 2014 | Whirlpool Microwave Ovens
Where is the fuse on kenmore microwave
Jun 25, 2014 | Kenmore 63252 Microwave Oven
Hi, we have a Bosch HMT8656GB built-in microwave, and the other night (shortly after microwaving several potatoes), it shorted out and tripped the main fuse for the kitchen sockets. We've isolated it to...
Confirm that the receptacle where the microwave is plugged in is not faulty by plugging something else in the recepticle and seeing if it works or if the fuse blows. Check the power cord of the microwave for broken, frayed wires. Also check the bulb socket for broken wires. It may or may not be worth the cost of repair, depending on the repair cost verses a new microwave. There are repair parts available.
May 08, 2014 | Bosch HMT8656GB Microwave Oven
Whirlpool microwave fuse has blown multiple times
It depends on which fuse and when it blows. Wish you had mentioned that.
But usually it's a defective door switch or door switch mount.
If the fuse blows at random times while it's cooking, it may just be a loose fuse holder. Those have to be replaced due to metal fatigue, not just squeezed tight with pliers.
If it blows as soon as you hit "Start" to begin cooking, you have a shorting high voltage capacitor.
If it blows when you open or close the door, you have a loose or defective door switch or latch.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Nov 21, 2012 | Microwave Ovens
No power to clock or microwave. Have checked breakers.
The main fuse in the microwave oven has probably blown, caused by a defective door.
Feb 07, 2011 | Jenn-Air JMC7000 Microwave Oven
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
I pluged the microwave in it was working and when I pushed it back and when I looked at it it waqs not working any moren mdl # is 87449 kenmore counter top microwave
Check the outlet it is plugged into. Remove the microwave plug. If you don't have a voltage meter handly to test the voltage at the outlet or the continuity of the microwave plug, I would suggest you plug in a lamp from your living room into the outlet. If it doesn't work, either the outlet is a tripped (GFIC) Ground Fault Interuption Circuit outlet or the circuit breaker tripped in your electrical panel box or the microwave cord is damaged and caused a short and blew the fuse. To check these I would try plugging the light in and press the red reset button located on the wall outlet or flip tripped circuit breaker in panel. If it's a damaged cord or fuse, you can visit this web site for Sears parts www.searspartsdirect.com If you found any of these suggestions helpful, please rate my solutions. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
Sharp half pint
The fuse should be located on an input line filter board INSIDE the microwave. You will need to unplug and remove the outside case to get to it. Simply follow where the power cord comes in and you should see a fuse mounted on a small circuit board somewhere. This is the line filter. The fuse should be a 20 amp appliance fuse that you can purchase at any hardware store. DO NOT attempt to re-energize the oven with the cover removed. There are dangerous voltages present in the high voltage circuit (about 13,000 - 14,000 VAC). Put the outside case back on before trying an op test. Let me know if this helps.
Aug 11, 2007 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
