Question about Dishwashers
Dishwasher malfunction The Normal Cycle light is blinking red and won't quit. None of the other cycle lights will light up and it won't start.
  • dlouise Mar 06, 2008
    My model is Kenmore Ultra Wash Quiet Guard 4 model number 665.16032.401
  • dlouise Mar 07, 2008
    Okay...the red blinking light stopped just after I sent my first e-mail to you! And I have run a Normal Cycle with a full load. Do you still think there's a short? Can a handy man (read boyfriend/master carpenter) replace the panel if it is shorted out?
  • 19,396 Answers
Which is your brand and model?
Posted on Mar 06, 2008
  • Ginko
    Ginko Mar 06, 2008
    Your control panel keypad has shorted out, it will need to be replaced.
    here is link to black one
    here is white one.
    regards
  • Ginko
    Ginko Mar 08, 2008
    It was not necessarily a short, could have been one chip in control board going crazy for a while. Wait and see if problem restart before calling service.
    regards
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
MDB7749AWB
Hello I had the same issue the sequence for resetting the panel is;
heated dry...normal...heated dry...normal
all the lights will go on then off. on my machine it started the normal wash cycle. I let it run normally so far this worked.
Hope this helps.
Dec 30, 2011 | Maytag MDB7749AWB Builtin Dishwasher
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Start / resume light blinks. dishwasher won't cycle
my dishwasher runs through the cycle as normal for 20mins and then starts bleeping nonstop. opening the door the start light flashes without any pauses and the light above prewash is on. my engineer cnat figure this out as the flashing has no pauses. help.
Jul 02, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
206 people viewed this question
Top Dishwashers Experts
