Question about Xerox Phaser 7750B Laser Printer
Xerox phaser 7400
Hi, i have a printer 7400 xerox and i want know how reset the unit transfer counter and date of installation. I want change this with other unit from equal model with more life time of unit. Thanks
    President:
  • 2,072 Answers
There really isnt an easy way to do that.
The transfer belt assembly starts off with a fuse on it to blow immediatly on install, and a counter that is internal so that it will end of life and have to be replaced. It's really not a convience counter but an obsolence counter.
Posted on Mar 06, 2008
Why is my Phaser 7400 printing a solid pink page? The Transfer unit is half pink. Is this why?
This may be a high voltage problem.
Am not familiar with this machine but is a generic fault.
Ensure contacts to drum/cartridge are clean.
Next
If possible, unplug machine, open up and ensure all high voltage connections are good.
Good luck.
Jul 24, 2015 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400, lines on solid colours
Are the streaks evident when printing actual images? I was told by an experienced Xerox service tech that those solid-fill test pages can be misleading -- mine does the same but prints photos beautifully. I suggest printing some full page photos, check for the streaks. You've already done just about all you can.
Jun 19, 2014 | Xerox Phaser 7400DN Laser Printer
I have tried using a new fuse to cause an imaging unit to reset on a Phaser 7400 but the fuse will not blow.
If the unit is remanufactured or if you know how, you will have to disassembly the imaging unit and replace the fuser that blowns or simply just solder it. http://www.uninetimaging.com/downloads/technical/xerox/english/Xerox_Phaser_7400_Reman_Eng.pdf
Graphic 27.
Mar 30, 2014 | Xerox Phaser 7400/DXF Laser Printer
On power up the xerox phaser 7400 displayed.
HI there check the fuse on the xerox machine and let me know its ok or not.
Jan 24, 2011 | Xerox Phaser 7400/N Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox phaser 7400 replaced yellow toner, but still getting replace toner error. I've reseated it twice, reseated the imagining unit and tried turning it off.
You can try do a NVRAM reset. If after that you still have the error message then I would tell you to contact the Xerox team as you might have a wrong consumable (defected/wrong CRUM) information.
NVRAM reset: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=36,E=0000000002092637520,K=9394,Sxi=5,Case=obj(3085)
May 16, 2010 | Xerox Phaser 7400/N Printer
Xerox phaser 7400 I'm getting large black streaks that get larger as the print job continues. Is this the FUSER? or the TRANSFER UNIT?
That would be the drum 99% of the time. A fuser is what heats up the paper and the toner so it will stick properly. If it is "smudging" then its the fuser. But is it is lines sometimes with dots in them that is a bad drum.
Mar 09, 2010 | Xerox Phaser 7400/N Printer
Xerox 7400 error 917
From Google: Error in the Transfer Unit Belt. The Belt Rotation Sensor indicates an error.
May 25, 2009 | Xerox Phaser 7400/DT Laser Printer
Xerox Phaser 7300DN Laser - Transfer Unit issue
Hold down Back and Information and turn on the printer. You enter in service mode. Then you can reset CRU counters.
Jun 19, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7750B Laser Printer Logo
408 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
