Question about Sony KV-20M20 20" TV
Sound but no picture
Hey u guys .I have a sony television Model KV20M20 that has an problem.I am geting sound but no picture , a blueish back ground and line.Any help or opinion would be greatly appreciated soon . thank you.
  • 2 more comments
  • deolall Mar 07, 2008
    hey thank you for your help .I will try this repair and let you know soon. O i am a tech as well but i never work on a sony television.
  • deolall Mar 09, 2008
    hi,
       The problem i am getting no raster but there is sound.a plain screen with lines about 1'' from top to bottom. only when i turn up the flyback screen volt.
  • deolall Mar 11, 2008
    hi there again , I still not getting true with this problem.I am having sound but no raster only when i turn up the screen
     volt on the flyback transformer there is a plain blue screen with line.
  • deolall Mar 14, 2008
    Hey,
    I have a Panasonic 5 cd changer CD stereo system SA-AK240.
    I plug in the ac cord in the 110 volt outlet and the display showing
    me F61 . can you help to solve this problem .thank you.
    Brigadier General:
  • 6,966 Answers
I suspect a Vertical failure in your Sony TV. This problem is pretty common and is relatively easy to repair. Often, this involves replacing the Vertical IC which is not that expensive. Basic knowledge of electronic circuitry and components, use of a soldering iron and an electronics part shop near you is all that is required. Of course standard safety precautions apply when working with HV such as in your TV.
Should you not be comfortable performing a do-it-yourself, perhaps you may need to seek the services of a qualified professional.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 06, 2008
  • 2 more comments
  • Louie  Role
    Louie Role Mar 06, 2008
    Hi again,
    If I may add, there are instances that the coupling capacitor also goes bad. This is also normal after some time due to heat buildup. Being not that expensive (a couple of dollars), it may also be worth your while to similarly replace while the set is open. This capacitor would be relatively bigger than the others in the vertical circuit and is commonly located physically near the vertical IC.
    Cheers.
  • Louie  Role
    Louie Role Mar 10, 2008
    Copy your last post/update.
    That being the case, then it is not a vertical problem but a probable short/leak in the collector to emitter of the blue drive transistor. They normally can be fount in the small squarish PCB connected at the rear end of the CRT. There would be 3 of them (red, blue & green) You would need to remove the blue one and check for forward and reverse bias. At times, it could also only be a case of cold solder on the b-c-e- terminals.
  • Louie  Role
    Louie Role Mar 12, 2008
    Have you checked the 3 transistors at the small PCB? It could also be a resistor that opened. Usually it is either the one supplying the color drive transistors B+ or the G2 supply. All of then would be there likewise in the small PCB.
  • thefaster Mar 05, 2011
    CAN YOU POST SOME PICS OF THE COUPLING CAP PLEASE THANK YOU
I have a Sony KDL-46XBR8 Television and it intermittently has vertical lines on the display.
Below is a youtube video I guy did to address that problem. Sony provides a troubleshooting guide at this place, it may be similar to your Vizio model and help you.
http://techin.oureverydaylife.com/sony-lcd-tv-troubleshooting-vertical-lines-screen-35117.html
Nov 17, 2016 | Sony Televison & Video
Tv picture is pink with vertical lines sony bravia 32 inch XBR
it sounds like a bad t-con board. this board my not be sold without geting the whole screen. the t-con borad is at the top of the screen and connects to your main board
Apr 15, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Picture horizontal lines!!
try call sony get one time warranty.maybe lcd panel bad or call bestbuy in home service
Aug 14, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony KDF-50WE655 Screen has a blueish white area down left side
Your light engine is going bad
sony has an extended warranty for Sony Grand Wega 50" Televisions
contact sony and they will fix it
Apr 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Bad Picture Blueish picture
If the red gun stops working it could make the picture very blue-greenish. This could be caused by a number of problems, including a coolant leak, but it's most likely a bad electrical connection somewhere in the set.
Best left to a professional repair guy, frankly.
Mar 19, 2008 | Samsung HCM5525W 55" Rear Projection...
Toshiba 43H70 Picture Problem
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Toshiba 43H70 43" Rear Projection...
SONY KP57WV600-Turns Blue
yes ,it sounds like screen adjustment or focus block, should be around $200- $325 to repair.
Sep 08, 2007 | Sony KP-57HW40 57" Rear Projection...
I believe the cable guy is correct and I will suggest you call for professional help now,if you try to use it like this the problem might become expensive.
Sep 23, 2006 | Sony KV-35S66 35" TV
Televison & Video Logo
107 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
