Question about Vicks Ultrasonic V5100 Humidifier
Vicks 5100 humidifer need help filling and operating
How to operate the vicks5100 humidifer, cannot find manual is there a fill lins
  • zehn Mar 06, 2008
    need help with the vicks ultrasonic humidifier, is there a fill line and do i replace the blue filter box, also how to operate
    needhelp
    President:
  • 2,351 Answers
You can down load the manual in pdf format from this site:
http://www.amazon.com/Honeywell-V5100N-Ultrasonic-Humidifier/dp/B000056HL5
Scroll down to Product Manual [205kb PDF] & download.
If you do not have Adobe Reader which is used to read the pdf file you can download that from this link for free:
http://www.download.com/Adobe-Acrobat-Reader/3000-2378_4-10000062.html
I believe the manual will answer all of your questions..
Good Luck & Best Regards.
please vote...
Posted on Mar 06, 2008
My air innovations keeps on beeping when the reservoir is filled
Hello... this humidifier uses timer? then, some humidity has damaged the circuitry. Try to disassemble as far as your skills permit; then put the unit outside of home in a place where the sun and wind can dry this device. And try to use destiled water if is not expensive in your area.
Aug 10, 2014 | Air Innovations Ultrasonic Digital...
How do I clean this humidifer? I have the sesame street elmo and friends cool mist humidifier and I cannot find the manual for cleaning instructions. thank you
The outside you can clean with warm soapy water. The inside can be flushed with a 50/50 solution of White Vinegar and Bottled Distilled Water. Fill the tank and run the unit until the tank is almost empty. Pour out the remaining solution and fill the tank with more of the Bottled Distilled Water. Operate the unit for 30 minutes and the previous solution should have been flushed out by then. I would recommend using Bottled Distilled Water all the time rather than tap water. As tap water has a lot of minerals in it that can cause calcium scale and clog the unit.
Hope this helped you.
Apr 19, 2011 | Kaz Sesame Street Elmo & Friends...
Red light not turning green
there will be a water level sensor at inside wall try to fix it .it also seem to be a power failure case well since you have just got it must in warranty or free service utilise it.
If you like my suggestion then vote for me i will be thankfull
Feb 25, 2010 | Crane EE5058 1 Gallon Humidifier
The fan is not turning to pull the water into the system but you can hear it running
brand new humidifer i can hear the fan working but the water is leaking all over the floor the water tray is filled and the tank is empty
Feb 02, 2010 | Hunter 33201 Humidifier
Continous water flow on a 1042lh humidifer
theholts220 - Sounds like they needed to install a bit larger transformer . You can also buy a A 50 Sensing relay that attaches to the wires for your motor and when you turn on the furnace it will allow the power to go to the humidistat. Very strange though they do not use a lot of power. Check and make sure the wires are not pinched or touching metal somewhere.
TLuzzo - The humidistat seems to be working when you turn it down. The wires for the solenoid should be hooked up to your furnace circuit board. The instruction manual will tell you where. If you dont have a spot on your circut board the A 50 sensing reley is they way to go. They are inexpensive
Jan 24, 2009 | General Filters 1042-LH Humidifier
Aprilaire 600: water only runs in "Emergency" Heat mode
When your unit is on normal the outside unit works and the inside only the fan runs. your heat pump does not remove any humidity when it operates so the installation cotractor did not wire it to operate then. you can change the wiring on the humidifier to operate all the time by wiring it to the fan (g) terminal then it should work just turn it all the way to the lowest humidity when you are in cooling mode.
Jan 07, 2009 | Aprilaire 600 Humidifier
Vicks v5100 need helpa to operate
Go to this link: http://www.amazon.com/Honeywell-V5100N-Ultrasonic-Humidifier/dp/B000056HL5
Scroll down to Product Details.
Download Product Manual [205kb PDF]
You will need Adobe pdf reader to view the pdf file. Do you need Adobe Reader? Download it for free at this link:
Once the pdf loads in Adobe you can print the manual.
Good luck & best wishes.
please vote...
Mar 06, 2008 | Vicks Ultrasonic V5100 Humidifier
Hunter humidifer
I dont know why your humidifier is spitting water out.
But it sounds like you need to clean the unit and install a new filter. Once the filter becomes used, the humidifier won't work as well. Less water will be used because the clogged filter can't hold as much. Once you replace the filter, your water consumption should go back up and you should feel a difference in your home again.
Good Luck.
Feb 15, 2008 | Hunter 33201 Humidifier
Vicks Ultrasonic V5100 Humidifier Logo
379 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
