Question about Compaq Presario 5000 PC Desktop
Pc cannt show bios when startup
I turn on my computer but the monitor just back bios not present please help...
  • kimhoang Mar 07, 2008
    i did but nothing happen any solution ele...thank for your help
    Novelist:
    Scholar:
  • 134 Answers
You might have to replace the bios battery, should be located on the motherboard.. it will probably be a small round silver mercury battery.. they need to be replaced every few years.. Sometimes they can just be 'slipped' out of the battery holder, some are soldered in.. But you need to remove the pc cover to get to the battery. Good Luck, Rgds,
Posted on Jun 08, 2008
  • 133 Answers
Press F2 immediatly after switching it on to access BIOs
Posted on Mar 06, 2008
Half side has vertical lines
Turn the computer OFF and just turn the monitor ON if the vertical lines are still present then the issue is your monitor, but if there are no lines on the monitor alone turn the computer ON then go into the BIOS either keep on tapping del key once you turn the computer ON or keep on tapping f1 to get into thew BIOS screen.
If the vertical lines are present in the BIOS the issue is the Monitor but if not and the lines are present in windows the issue is your video card.
Replace the video card, if you don't have a video card and you use the built in video card on the system then the motherboard needs to be replaced.
Sep 01, 2011 | LG Flatron Ez T710BH 17" CRT Monitor
Hi on my pc gt 5404 i got this message " windows boot manager File BOOT BCD STATUS 0xc000000f. what i have to do to insert the windows vista disc i cannt open it .Pleas any suggestions
Make sure your computer boots from the disc drive by going into the bios and assigning it as the first boot device. Then let it load and do a startup repair.
Mar 17, 2011 | Gateway GT5404 PC Desktop
The BIOS startup time is 5-10 minutes, showing
Either you have failing hardware attached or bios is looking for a device (probably a drive) that is not present.
May 13, 2010 | Acer Aspire E380 ASE380-UD500A PC Desktop
When I turn on my computer the monitor remains dark unit after about 10 mins then I get the windows desk top. If I shut down the computer (normal shutdown)then restart I get the normal startup...
Try connect your monitor to some other box and try if it works the same way or as a normal pc boot. If it works well with other box, the issue is with the BIOS. Get the BIOS flashed with the latest version of flash program for the Bios chipset which your board is using. If the monitor shows the same symptom on a different box too.. you may need to get your monitor repaired. Good Luck
Feb 14, 2010 | ASUS P5PE-VM Motherboard
Im trying to install agp...how do i disable the on board vga
Hi there.
Remember that if you are swapping from on-board graphics to a card you have to go into the BIOS and tell the machine that the primary graphics adapter is AGP/PCI Express.
Plug the VGA cable into the on-board graphics port, start the computer and enter the BIOS, tell the computer to use the AGP/PCI card as primary, press F10, save the changes and exit the bios.
The computer will try and restart so let it boot to post and turn it off, then put in your card and try to boot again.
Please post back if you need more help or advice.
Good luck and thanks for choosing FixYa!!
Jun 04, 2009 | HP Compaq Motherboard
Will not display output from Computer
Probably the video resolution or the monitor Refresh Rate (eg: 50/60/75 Hertz) is set too high in the operating system, which over-drives the monitor electronics and it is unable to display anything.
If you restart the computer manually (hold in the power button for 5 seconds, the computer will shut off, turn it back on again) you will see the normal BIOS and Windows startup display on the monitor, but then as Windows completes it's startup it returns to the error message you see.
To fix this, restart the computer manually and start the computer in Safe Mode. To do this press F8 just before the computer starts to load Windows, and choose Safe Mode. Once in Safe Mode, you should see the monitor working correctly.
Now restart the computer in Normal Mode and everything should be fine.
Dec 23, 2008 | Westinghouse LCM-19v1 Monitor
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Nov 27, 2008 | Dell Dimension B110 PC Desktop
Princeton VL1715 startup problem
Have you disabled your onboard video in the BIOS? Boot your machine with the vga cord to the motherboard. You need to get into the BIOS. Depending on the make of your machine you need you will need to hit the del key, f2, or even f1. Go to the periphrial setup and disable your onboard video. Save the BIOS turnoff the computer and plug the monitor into you vga card. That should do it. To change it back to your motherboards vga just reverse the instructions. Let me know what happens. Good Luck, Tim
Feb 15, 2007 | Princeton Digital VL17151 17" Flat Panel...
Startup problem
This could be a corrupt bios or a low cmos battery, follow instructions. Take the right hand side panel off the pc. Look for a disc shaped 3V watch type battery and replace (Very cheap) Look on the motherboard and reset the bios at the 'JBAT1' terminal put jumper(little plastic cap) from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. Restart pc and enter bios when prompted(or press F2 or DEL on startup) to set time and date, save settings and Exit bios. It should now boot ok.
Jan 25, 2007 | Systemax AOL Optimized PC (100607) PC...
Compaq Presario 5000 PC Desktop Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
