Question about Acer Aspire™ T180 PC Desktop
Erecovery management I am trying to create an initial backup - 6 cds or 1 dvd. However will not recognize my blank cds or dvds ..... error message 3.
  • MiniEmma Apr 08, 2008
    I have the same problem. It is the eRecovery software that is giving the error code 3. I have spoken to Acer and they say the eRecovery software needs reinstalling and the only way to do that is restore the whole PC to factory defaults by pressing Alt+F10 at start up.
    I am not prepared to do that as it has taken me weeks to get the PC exactly how i want it.
    The PC did NOT prompt me to make recovery discs on initial start up. Mine is an Acer Aspire M5100.
  • Anonymous Aug 26, 2008
    acer TravelMate 2490
    Problem Solver:
  • 18 Answers
Acer has inbuilt data recovery managemt ..use that tool to create backup ...Try to use some other brand DVD/CD
this will solve the problem
Posted on Mar 08, 2008
How to factory reset without recovery disk
When you need to recover part or all of the files on your Acer Veriton M460 desktop computer, Acer makes it easy to do by offering a built-in recovery program called eRecovery Management.
This option uses clean operating system files, usually stored on a separate partition of your hard drive, to correct errors or return the system to its original factory settings.
You can also use this program to write separate hard copies of the eRecovery program onto CDs or DVDs in case of hard drive failure.
Create Backup Disks
If your M460 did not come with separate recovery disks, and many machines don't in recent years, you can create your own through "Acer's eRecovery Management" program located under the "Start" menu.
Click on "Backup," select "Create Factory Default Disk" and follow the on-screen directions.
The program will inform you of the number of CDs or DVDs you need and help you through their creation.
Recovery with Disks
To use your created disks for recovery, place the first disk in the optical drive and reboot the system. As it boots, hold the "ALT" key and tap "F10" repeatedly until the computer boots and you see a screen titled "Starting Acer eRecovery."
You will see three options for recovery: to factory default, from user backup or from CD/DVD. Choose the option you desire and follow the on-screen directions to initiate the recovery sequence.
Recovery from the Hard Drive
Since Acer places the eRecovery Management program directly onto the computer, you can run the recovery option while in your desktop.
Open the "Acer eRecovery Management" program under the "Start" menu and click "Restore." You can choose to restore the computer to factory defaults and lose all the personal data stored on the hard drive or only restore the operating system and leave your data intact.
Select "Yes" on the confirmation screen and then "OK" to start the program.
Recovery Vs. Restore
When performing computer problem solving, the term "recovery" is often used interchangeably with the word "restore."
In some cases, "recovery" can mean to simply correct problems, such as replacing corrupted operating system files with good ones.
The term can also refer to "recovering" the system to its fresh-from-the-factory state, which is what "restore" means as well.
Restore Drivers or Applications
Acer's eRecovery Management program also offers the option to reinstall drivers or applications, which could become corrupted or damaged over time.
This option allows you to replace the current drivers for your Windows operating system with the ones originally installed on your system.
Under the "Restore" tab of the "Acer eRecovery Management" program, click "Reinstall Drivers or Applications" to see the content list and select the files you'd like to recover.
http://supportforacer.iyogi.com/veriton/factory-settings-6.html
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq40.shtml
http://support.acer.com/product/default.aspx?modelId=477
Aug 26, 2013 | Acer Veriton Z290G Desktop Computer
I WOULD LIKE TO RESTORE TO FACTORY SETTINGS TY
You will loose all data you have put on the computer. When you turn it on right at the beginning there is a black screen and there are a few f key options.
They will flash up with the option when you turned it on, before windows kicks in. Take a look at the user manual to find out for sure.
Press the correct f key before windows starts up, then go through the menus in setup (it will look all crappy and dos like) and find restore factory settings (or something like that) and click yes.
It's a great feature, and will completely kill any virus or **** problems you have had and couldn't get rid of.
Hope this helps. I would appreciate your feed back as I do this for fun not pay.
Oct 01, 2011 | Acer Aspire One PC Notebook
I cannot get the acer erecovery management page to give me the option of making a DVD recovery disk
Hi!
You can try the following steps:
1. Click on "Start" and then click on "Control Panel."
2. Double-click on "Backup and Restore Center" if you are using Windows Vista. If you are using Windows 7, click on "System and Maintenance" and then click on "Backup and Restore."
3. Click on the "Create a system repair disc" button in the pane on the left-hand side of the window. A new dialog box will open.
4. Insert a blank DVD (or CD if you do not have a DVD, but you may need to use several CDs, so a DVD is better).
5. Click on the drop-down menu in the dialog box and select the DVD that you inserted into your DVD drive.
6. Click on "Create disc." Wait for the green progress bar to fill while the disc is written. When this is done, a new box will open with a message telling you how to label the disc.
7. Label the disc according to the name in this message and then click on the "Close" button to close the box.
8.
Click on "OK" to close the next box and then close the Control Panel.
9. Remove the recovery disc from your computer and put it somewhere safe until you need it.
Hope this helps. Thanks.
Apr 25, 2011 | Acer Aspire 5100 Notebook
My HP notebook does not play DVD's.
Does it play CDs perfectly fine ?
Did you check with other good (branded) DVDs ?
If possible, remove this dvd-drive, connect it with another laptop, and check.
If problem started after you installed anything, try undoing it through System Restore (All Programs - Accessories - System Restore).
Boot the computer in safe mode (tap F1 or F11, select Safe Mode), log in as Administrator.
Check if it reads DVDs here or not.
Create a new user account (Control Panel - User Accounts). Restart computer normally, and log in using this new account. Now check if DVDs work or not.
If still not working, backup your important data (write on blank CDs, or copy in USB pen drives), and then format the hard drive. (Restart the computer, and tap F10 to initiate recovery from hard drive partition.)
You may also use the Recovery Disk you got with this notebook. (Insert disk 1 in the drive, and restart the computer, and just follow the instructions).
If still no progress, chances are the DVD-drive lens has gone for a toss. Buy a new dvd-drive.
Hope this solution helps you.
Nov 15, 2010 | Computers & Internet
How do I do a full recovery with the disc
Turn your computer on.
Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
Change the boot device order to: CD-ROM, HDD in that order.
Save changes and restart the computer.
The Recovery Disk would boot up and a wizard will guide you through the recovery process.
Follow the instructions to recover your computer.
Apr 03, 2010 | Acer Aspire 3050-1733 Notebook
I have an Acer Aspire 5720, ive had it for a year now and it is starting to slow down. I have lost the booklet to it and i need to do a master reset on it. Ive already backed everything up im just finding...
This was taken straight out of the manual for your model, which can be found here.
Acer eRecovery Management is a tool to quickly backup and restore the system.
You can create and save a backup of the current system configuration to hard
disk, CD or DVD. You can also backup/restore the factory default image, and
reinstall applications and drivers.
Acer eRecovery Management consists of the following functions:
1 Create backup
2 Burn backup disc
3 Restore and recovery
This chapter will guide you through each process.
Note: This feature is only available on certain models. For systems
that do not have a built-in optical disc burner, plug in an external
optical disc burner before entering Acer eRecovery Management
for optical disc-related tasks.
When using Acer eRecovery Management, you may be prompted to enter the
Empowering Technology password to proceed. The Empowering Technology
password is set using the Empowering Technology toolbar or when first running
Acer eLock Management or Acer eRecovery Management.
Create backup
You can easily create full and fast (incremental) backup images of your system
configuration to hard disk from the main Acer eRecovery Management screen.
Note: Fast (incremental) Backup is only available after a Full
Backup is made.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 In the Acer eRecovery Management window, select the type of backup you
want to create using Full or Fast.
3 Follow the instructions on screen to complete the process.
83
English
Burn backup disc
Using the Burn Disc page of Acer eRecovery Management, you can burn the
factory default image, a user backup image, the current system configuration,
or an application backup image to CD or DVD.
2 Switch to the Burn Disc page by selecting the Burn Disc button.
3 Select the type of backup (factory default, user, current system,
application) you would like to burn to disc. Choosing to burn a user backup
will burn your most recently created backup image to disc.
4 Follow the instructions on screen to complete the process.
Note: Create a factory default image when you want to burn a
bootable disc that contains your computer's entire operating
system as it was delivered to you from the factory. If you wish to
have a disc that will allow you to browse the contents and install
selected drivers and applications, create an application backup
image instead — this disc will not be bootable.
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
Dec 20, 2009 | Acer Aspire 5720 Notebook
Error: 0XC000000C; What's the solution?
My 0xc000000c problem seemed to result from disk surface damage on the restore DVD. I burned a new copy of the restore DVD and the restore then proceeded normally.
Using a DVD copy program that provides an aggressive read method to extract data from damaged disks might help you the most.
Nov 08, 2009 | Acer Aspire 5100 Notebook
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
1 Boot to Windows XP
2 Press Alt + F10 to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
Cdrom doesnt recognise blank dvd. error message
Its only cd writer burner and can only that it can read dvd disc also. That is why its called combo. But burning blank dvd it can't. But if you want buy some dvdburner too.
Apr 19, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
use an external usb cd or dvd burner
Mar 08, 2009 | Acer Aspire 5720 Notebook
Acer Aspire™ T180 PC Desktop Logo
279 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
