Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Mitsubishi heavy industries a\c srk20zcx-s
How often should i run my mitsubishi a\c on clean mode
    Problem Solver:
  • 15 Answers
Most of the time once every season so once a year same time you clean the filters. But being thats its the cheaper chinese made heavy industries and not the better quality japanese made mitsubishi electric i would say once every 3-6 months
Posted on Mar 16, 2008
Mitsubishi Heavy Industries - FDC180HA outdoor, FDT180HA Indoor- The inside unit is installed on the ceiling. The unit is working great. However, water is leaking from the inside of the ceiling unit.
Sounds like the filter or coil is dirty, therefore fan amount up and hindering drainage. Vacuum drain, clean coil, change filter.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 20, 2017 | Mitsubishi Heating & Cooling
Hi I need manual for mitsabishi heavy industries model no src7zea-s
Mitsubishi Link HERE:....https://www.mhi-mth.co.jp/en/products/detail/air-conditioner_users_manual.html
May 11, 2017 | Sewing Machines
Can you sew with rabbit hide on these machines? Thanks!
You didn't say what machine you have. You'd probably want a heavy-duty (industrial) machine. Domestic home machines are probably not recommended for sewing heavy leather. They may be able to but in the long run it may damage the machine.
Apr 14, 2015 | Sewing Machines
Mitsubishi Heavy Industries Cassette Out Door Model: FDC506HES. What is the BTU size?
1 ton of ac is 12000 btu. you should probably call mitsubishi they have a tech support that will help you with this. the number is usually in the paperwork that came with the unit. you may find it on the tag where you got the model number
Oct 15, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
I purchased a big boss 350 with the oil injection disconnected and running on mixed gas. Is this o.k. and what ratio mix should I use.
40-1 ratio will work fine for a clean burn. Under heavy loads and dry hot conditions use 32:1 Team X
Oct 03, 2010 | Polaris ATV
I have 3 aircndition mitsubishi heavy industry one
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Aug 09, 2010 | Whirlwind FH-778 Air Conditioner
No Mitsubishi Air Con Manual
ok heres the problem. The a/c filter is clogged or the evaporator coil is clogged. These systems have a metering device that measures the amount of air flow over the coil. If this air flow is obstructed the filter light will flash. If the filter in the unit is clean then the coil has some type of obstruction. This will mean having to clean the coil before the light will go off. An a/c tech should be able to clean this for you and it not be a huge cost. They have the chemicals to get the job done fast and clean.
Change your filter first.
Good Luck hope this helped you some
Dave
Jan 12, 2010 | Mitsubishi MS15TN Air Conditioner
Error code E39 for Mitsubishi Heavy Industry Ceiling cassett type
E39 Fault is thermister, Mitsubishi way of saying im not going to start because there is something wrong. Generlly it is compressor fault or short of gas. Im guessing if you turned the power out. Waited twenty seconds, turn it back on. Now if you go to the outdoor part. Wait exactly 3 mins. If you hear the compressor try to start and fail then it would more then likely be your compressor if you dont hear anything and the unit faults out it will either be a board or short of gas.
Either way If the unit is under five years old get a warrenty agent out to look at it.
Sorry I couldnt tell you for sure but MHI are very vague when it comes to fault codes
Mar 03, 2009 | Mitsubishi Heating & Cooling
Mitsubishi electric or Mitsubishi Heavy Industries
as an refrigeration engineer dealing whit them every day my advise is: mitsi heavy industry away much more reliable and better performing.
Jan 29, 2009 | Mitsubishi MS15TN Air Conditioner
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
245 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
