Question about Canon PowerShot SD1000 Digital Camera
Power shot 400 Naming error
Naming error when inserting a freshly emptied 1 gig card. Also deleated two "unnamed photos" which now I fear were files necessary for operation. Tried the camera with a 256 card and it works fine, How can breathe life back into the 1 gig card?
Going to Belize in the morning!
Doug
I tap on the lence and still shows naming error...I need help
  • 477 Answers
Format the card in the camera if you cant do it from a computer and make sure it has a name for the card in the format process. I just tried this on a card and it works great.
Posted on Mar 11, 2008
Why is the camera saying out of memory?
Usually it means that there is no memory card. Try to insert a fresh memory card then turn the camera back on. Most cameras only have enough memory for a couple of shots without a memory card being present. If you put in a fresh (empty) card and it says something about a card error, then use the menu to format the card, which may take a minute. If this does not work, please provide us with model of camera.
Jan 10, 2016 | Nikon Cameras
How do I recover pictures back to my power shot sd card
If your computer has a built in card reader you can put any photo back on the card from your computer by dragging and dropping the file to the drive letter that is your SD card. If you're trying to recover lost photos from a SD card Google "card recovery pro". It's a free program that will read your SD card and restore as many photo's as it can.
Sep 23, 2014 | Canon Powershot Power Shot A70 A 70 3.2 Mp...
SD Card Full
When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it.
You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
Mar 25, 2013 | Tascam DP-008 8-Track Pocketstudio
MY DIGITAL CAMERE MEMORY IS FULL, WHEN I TURN ON MY CAMER IT SAID MEMORY IS FULL. I DON'T HAVE A CARD INSERTED IN BECAUSE WHEN I PUT THE CARD IN IT WON'T COME ON AT ALL. IT ONLY COMES ON WHEN I TAKE OUT OF...
camera's onboard memory is only 8MB, maybe 1 or 2 high resolution photo. delete the photo on the camera to clear error message and use only no more than 2 gig of sd card. It does not work with higher than 2 gig which is SDHC type sd card.
May 20, 2010 | Casio Exilim EX-Z55 Digital Camera
Digital frame won't read memory cards
Did you format the card before trying to use it?
Dec 30, 2009 | Polaroid T831 Digital Camera
Format and Check SD card
Purchase an inexpensive card reader such as the Ativa, available at Staples and Office Depot for $9.95. Put your memory card with the photos on it into the reader and plug it into a USB port on your computer. Windows will recognize it as another drive and assign it a drive letter. Using any graphics program, or Windows Explorer, navigate to that drive, open the file containing the pics, click select all, and copy the pics to a file on your computer. Make sure that all the pics have transferred or copied to the new file. Replace the card back into your camera and format the card so it is empty and ready to receive new pics. FYI: Less than 1 gig memory cards are available on ebay for dirt prices. Also, go to the camera manufacturers website and see if they have a firmware update for your camera that allows larger than 1 gig cards to be used. I had to do that for my Fuji S700 so I could use 4 gig cards. It used to max out at 2 gigs. If this has solved your problem please rate it accordingly. Good luck.
Jul 05, 2009 | Samsung Digimax S800 Digital Camera
Displays file error message when trying to playback still images and video footage
Did you take the card and insert into computer/device to view photos?
Viewing photos can alter the format of the photos thereby preventing your camera from reading them.
I viewed some photos and rotated a few photos and my camera no longer recognizes the format.
good luck
May 20, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Photo capacity
Are you using a TRUE Sony Memory Stick? Or another Brand, some non-standard flash memory doesn't "erase" files correctly when told to do so, it may simply just remove the files name, or it's suffix, meaning that the stick essentially still holds all the old data, its not a faulty memory stick, it is just down to an incompatibility issue. Try using sticks made by either sony or sandisk
Oct 02, 2007 | Sony Cyber-Shot DSC-F828 Digital Camera
Canon powershot s2 Is
I just fixed mine. Put your memory card into your computer. Right click on it. Choose format. Reformat the memory card. You WILL lose all pictures stored on it.
Before putting the memory card into your camera, do the following.
Go to MENU and choose RESET ALL.
Choose reset to original settings.
When camera is done doing so, turn camera off.
Reinsert memory card after it is done being formated in your pc.
Then your camera and memory card should work great again. I just did it on my Canon Powershot A620.
Oct 24, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
104 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
