Question about Belkin (F5D7230-4) Router (587009)
Belkin F5D9230-4 router with xbox live
I've been able to play xbox live in the past with just my modem but then i got a new belkin F5D9230-4 router.Every time i can connect to xbox live but within diffrent times it'll either kick me out of games or kick me out of chat. i looked everywere for info and ive open the ports 88 udp, udp 3074 and tcp 3074. i even used the dmz and it didn't work. the connections fine and i have upnp enabled.is there anyhting else i can do?
  • 1 more comment
  • dograven Mar 06, 2008
    o sorry wrong system post. sorry my first.
  • suedevarrica Oct 30, 2008
    Hi, i have the exact same problem and i have done what you have tryed it had no result for me. my brother has the same problrm he bought a recomended router and it is now fine. seems like its xbox live that should be fixing it for us!!!!
  • ak_kt Apr 07, 2009
    How do you turn off the NAT?
I was having troubles with a belkin router as well. i called belkin tech support and they never helped as they would not accept that the router was the problem. i found i could connect the xbox directly to a modem and it would work fine but when i connected it through the router it would always disconnect from games or not allow me to join a game, only host them, with no one else joining. no matter if i forwarded the appropriate ports, put the specific ip address into the dmz or even turn upnp on (i've tried different combos of each, all on at same time, to even setting up manually) and nothing would change. I found that the router had an option to turn off NAT which belkin told me would render the router useless.  I decided to go against them, turned it off and set the ip and dns to go with the modem. Now everything works fine as the router just acts as an expensive multi plug and wireless system. all the computers in the house can connect to the internet at the same time and access eachothers hard drives and i can access xbox live fine with no problems. there is also no lag when playing gtaIV multiplayer with 15 other players.  i hate belkin tech support and i will not pay for another expensive multi plug connector from belkin... ever.
Posted on May 18, 2008
    Genius:
  • 1,269 Answers
Try to reduce the MTU on your router. If you're on DSL, set the MTU size to 1492 and save the settings. Power cycle your modem and router then check if it does the same problem.
Posted on May 17, 2008
2 Suggested Answers
SOURCE: Belkin F5D9230-4 router with xbox live
the solution is as such, first log into your router by typing the routers IP (192.168.2.1) into your browser.
The first thing you want to do is set UPnP to be enabled.
Forget about the 88 UDP thing, it's bogus.
Just set the TCP and the UDP to 3074 in virtual server.
I swear to god it will work.
Posted on Aug 15, 2008
I have just bought a Belkin Wireless G Plus MIMO Router and have got a disk but the problem is can i8 get on xbox live or do i need a modem aswell or is it modem and router together
you have to ring belkin and they will talk you through opening the releveant ports to access x box live. If you dont have a microsoft wireless adaptor (which they say you need) you can use a hard wired connection from another computer by creating a network bridge. either way you have to open the ports on your router.
Jul 25, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a belkin n modem router and it keeps kicking the xbox off line. is it the xbox live or my new router
it is the problem with router....the firewall built-in in the router will not allow certain gaming devices to go online...for this purpose you need to forward certain ports in the belkin router...for the list of port numbers to be forwarded, contact xbox vendor....once you got those port numbers, you can call 24x7 toll free belkin tech support(1800-2-235546)(1800-2-belkin) and ask them to assist u to forward ports... or you can can connect a computer to one of the wired ports(1 to 4) and open internet explorer and type 192.168.2.1 in address bar and hit "enter key". you ll see belkin router setup page...on the left side you ll find "virtual servers"...open that link(if it asks password, leave it blank and click submit) fill the IP address of your xbox in that form and type the port numbers and select appropriate (tcp/udp)... also click on"firewall" in left and disable it.... also click on DMZ in left and type your xbox ip address there and enable it... thats it.... you are done with that...
Apr 13, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Xbox live
Some modem have built in router.So in my case i have hughesnet hn 9000 modem so what i did is connect my modem to a switch and from your switch connect to your xbox live. so buy a switch.
Feb 14, 2010 | Belkin (F5D7230-4) Router (587009)
I'm trying too get connected to xbox live but it's
This mainly depends on your internet modem, I use linksys when I play xbox live. Also I use wireless adapter, sometimes an ethernet cable as well to plug straight from my xbox to my modem. Make sure your modem is connected to the internet, and that if your xbox has a signal, or properly connected to it.
Hope this helps a little. Good Luck!
Jan 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can not connect Xbox and computer to be online at the same time
is this a new belkin router... I suspect that the belkin has a firewall. or the windows box is trying to take the XBOX over...I am sure we can get through this
Aug 05, 2009 | Dynex Enhanced-G Wireless Broadband Router
How to change NAT type on sierra wireless 595u aircard?
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Feb 15, 2009 | Belkin N1 Vision Wireless-N Wireless...
Help deciding about xbox live please
doing it the way ur talking bout u should not have any problems
Dec 18, 2008 | Belkin (F5D7230-4) Router (587009)
Xbox Live Can't Connect to Friends
Hi akemccarthy
you may need to open the ports for the linksys Router aswell
because the linksys links the belkin to the internet there using a shared connection
once youve fowarded the ports properly check to see if you have enabled the UPNP on both of the routers if they have any
heres a website showing how to port forward the ports you need opening
http://portforward.com/routers.htm
Dec 18, 2008 | Microsoft Xbox 360 Console
Mar 06, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D7230-4) Router (587009) Logo
2,695 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
