Question about Actiontec (5GE583000-01) Router
Router MI424WR-D I just had FIOS installed. My problem is my printer is plugged into my laptop (into a USB Port). The printer is a Lexmark Z600 series. Does anyone know if this printer can be hooked into the router, so that the printer is wireless? Any help would be greatly appreciated.
    Novelist:
  • 173 Answers
Hi Steven,
You will not be able to setup this printer wirelessly to your router as it is because the printer has no networking capabilities(ethernet or wi-fi). If you want to share the printer throughout the network you need a wireless/wired print server or just enable file and printer sharing on the computer where the lexmark printer is connected the only downside with the second setup is the computer where the printer is connected must stay powered on all the time in order for the rest of the computers ion your network to print compared to the 1st setup with the a print server which is stand alone.
Posted on Dec 25, 2008
My DHCP is not assigning a dynamic address to one of my seven wired devices. I've had to switch over to a stati
On the second router just plug a port cable in from your main routers port into the wan port and then be sure to change the second routers gateway and IP address to a different number. Say that your main router IP is 198.18.1.1 and for your second router IP you could use 10.10.10.1 or what ever combo you want and then you should be able to use both routers together. Is this what you are trying to do?
Linksys routers as well as all routers with DHCP enabled should be able to handle up to 255 separate IP address's for a LAN network. Is the firmware of the Linksys the latest? If not, down load the latest firmware and flash the router to update it. Or, check out third party firmwares like Tomato to flash that tired Linksys and turn it into a real router.
Apr 14, 2017 | Actiontec Verizon Fios Mi424wr Modem...
I unplugged my 645z lexmark printer for two days and now my hp computer says it needs a driver but that doesn't work.what happened!
It seems that the computer is not able to detect your printer properly. You can switch the USB port connection meaning just try to unplug the usb cable of printer and connect to other spare usb port on your computer. Also you can uninstall the whole driver set and re-install it.
Cheers!
Mar 30, 2010 | Lexmark Z600 InkJet Printer
Whilst still installing the Lexmark Z600 software, it give a report 'remoteinstallation not successsful because the printer is not communicating'.
Hi. Check if printer is on. Make sure it's plugged in to a known working power outlet. Check if the USB cable you're using is still ok - no physical defects. Or you can try using a different USB installation cable. Once you connect printer via usb cable to pc, it should recognize it even if you're not trying to run the software yet. Hope this helps.
Mar 12, 2010 | Lexmark Z600 InkJet Printer
Lexmark Z600 printer, get an unable to cimmunicate with the printer, I get a power light and have checked the usb cable same msg. repeats
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Feb 21, 2009 | Lexmark Inkjet Z517 Photo Printer
CAN'T INSTALL LEXMARK Z600 PRINTER ON ACER LAPTOP
If the disk does not work, you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Jan 25, 2009 | Lexmark Z600 InkJet Printer
u have to change your printer port
go to settings control panel printer then its properties
then go to port check mark on usb port rmeove check form print to file youur problem is solved
Sep 13, 2008 | Lexmark Z600 InkJet Printer
Lexmark Z617
download LexmarkZ615 software
Apr 20, 2008 | Lexmark Z600 InkJet Printer
Can't print
Try going into your device manger, and see if you have a exclamation mark by your ports.. Check and make sure you have the usb cable plugged into the correct port. Good Luck! :)
Feb 07, 2008 | Lexmark Z600 InkJet Printer
Unable to print
sounds like a dogy usb cable try a nother usb cable before you give up
Actiontec (5GE583000-01) Router Logo
585 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
