Question about Apple iPod nano
Database is missing or currupted !!
Please help me ive tried reseting the dam thing and alsohacking into its data info and is just not working ! what can i do ? when connected to itunes it shows the reset button and i do the reseting but is just not syncronising the music only photos!
  • 31 Answers
The only solution I can think of is to use i-tunes to update your iPod, this should then repair the corrupt data in the iPod's memory.
Posted on Mar 06, 2008
Creating a new database using an MDF file
An MDF file isn't a backup file isn't the main data file (or master data file depending on who you ask) hence the file extension MDF. You can attach the MDF to the database by right clicking on the databases folder in Enterprise Manager (SQL 2000) or Management Studio (SQL 2005) then selecting all tasks and then Attach Database.
When you do this you will get an error about the log file missing. This shouldn't matter as SQL Server will simply create a new log file for you.
This will only work if the SQL Server was stopped when you copied the MDF file from the old SQL Server. If you copied the file while the SQL Server was running this file probably will not attach either and you will need to get a valid backup of the database.
Download help tool for sql database - SQL Server Restore Toolbox.
http://www.sqlserver.restoretools.com/
You can read up more on SQL Server here.
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/498-creating-a-new-database-using-an-mdf-file?_=1416149856104/
Nov 16, 2014 | Microsoft SQL Server 2000 Standard Edition...
Fecbook acct says having trouble gettinf data 32665
Your PC and mobile still have the old password in their respective databases. You will need to reset the relevant databases to erase the old password and register the new one. Please consult the help and support documents for your particular software for how to do this.
Feb 05, 2014 | Computers & Internet
HOW TO SOLVE VFP FILE CURRUPT WHEN POWER FAILURE
At times, you may view that your MS Visual FoxPro 9.0 database is behaving abnormally. Some of the abnormal symptoms could be an error message while opening any database table, invalid characters in place of pre-defined values, and and more. The main reason for abnormal behavior of the database is its corruption due some logical crash. Few common reasons for corruption of MS Visual FoxPro 9.0 database are abnormal termination, faulty network devices, simultaneous modifications, conflicting third-party software, and incompatible service packs.
To overcome such database corruption scenarios, the user can use an up-to-date backup and perform restoration. However, restoration fails in cases where the user either forgets to create a database or the database backup itself gets damaged. In such cases, the database users can use a third-party DBF File Repair application to repair his/her corrupted database.
To illustrate the above case, consider a real-time scenario wherein you execute a query to modify your MS Visual FoxPro 9.0 database. While the query was performing the modification, the system shutdown due to power failure. However, the next time you tried to mount the database, you encountered an error message that did not allow you to access the database records. Moreover, the same error message appears every time you try to access the database.
Cause:
The root cause for the error message is MS Visual FoxPro 9.0 database corruption due to improper system shutdown.
Resolution:
The database corruption error message can be surmounted by following the below steps:
Use a complete database backup and perform restoration. However, in case of database backup unavailability, you will need to search for a commercial DBF File Repair utility.
A third-party DBF Repair application uses effective repair techniques to repair logically damaged MS Visual FoxPro 9.0 database and restore it at a new and safe location. The original database during the repair process remains intact. The tool is easy-to-understand and allows even a non-technical person to perform repair.
DBF Recovery Software is a comprehensive solution to repair databases created in MS Visual FoxPro 9.0, MS Visual FoxPro 8.0, and MS Visual FoxPro 7.0. The tool also repairs databases built in dBase III, dBase IV, and dBase V. Supported by Windows 7, Vista, 2003, XP, and 2000, the DBF Repair tool creates a new repaired file that can be attached to existing database.
Tanvi Sharma is a self employed Internet entrepreneur and product reviewer. This DBF Repair utility is extremely useful when the dBase and Foxpro database gets corrupted due to internal program errors, hardware malfunctioning, accidental deletion of data and more. This DBF Repair software repairs all types of database components including table name, column name, column data type, indexes and primary keys.
May 31, 2010 | Microsoft Visual FoxPro Professional...
I need drivers my laptop currupted i can't open it anymore
Without the cd there isn't much you can do. Unless you can find one you'll have to hope your laptop has a system restore option but you would also risk losing all your data doing so.
I doubt you can get to safe mode, but give try safe mode with command prompt and type chkdsk in the cmd window.
Mar 23, 2009 | Toshiba Satellite 1955-S801 Notebook
Convert my database from dpf to mdb
Use access to import external data. It can read dbf and create mdb
Jan 06, 2009 | Microsoft Visual FoxPro Professional...
Sansa e250 blue screen
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Nov 03, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Apple iPod nano Logo
22 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
