Question about Sony Ericsson K510i Cellular Phone
Error message when try to charge
I get this message when try to charge my phone using the wall
"charging error, stop charging!"
but if i use the usb cable im able to charge it
    President:
  • 1,944 Answers
I suspect that your charger has malfunctioned. You will need to get a new one.
Posted on Mar 17, 2008
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
My SE w595 appeared 'Serious error. stop charging. stop using the phone. Contact Sony Erisccsion call center' message15 minutes after I start charging the phone. It also can't receive SMS since this error...
The phone told you what to do. Don't charge it, don't use it, and call their support center. 1 866 766 9374 (Toll Free) - 1-877-7XPERIA (1-877-797-3742) should get you moving in the correct direction.
Apr 11, 2011 | Sony Ericsson W595
Dear Sir, I own K 790i, whenever i put for charing i get an error message stop charging error, i have tried charging through differenct sockets still error message continues but when i charge through my...
If its charging on your computer,then the problem is the charger itself.
The first thing to do is try to check you charger and its terminal,pins might not in align or corroded,otherwise buy original sony ericsson charger.Also check the charging terminal of your phone. you can clean it using brush or a pin and scratch each portion so that the power voltage will some it.
Apr 04, 2011 | Sony Ericsson K790i Cellular Phone
I am not able to access my cell because of stop using, stop ncharging error..
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 11, 2010 | Sony Ericsson W350i Cell Phone
My daughter dropped her phone
I would take it to an appple store and have them take a look, they won't charge you just to check it out. If under warranty they are pretty good about replacing it right there.
Jun 07, 2010 | Apple iPhone 3GS Black (16 GB)
Charging P168 with USB cord
i have heard someone say that the charger goes in both ways on your model, and that one way it charges and the other way it detects headphones. try flipping your charger upside down vice-versa.
Jan 29, 2009 | Dual Electronics CECT P168 Cellular Phone
Battery Charging Error - Disconnect Now error message
Most new phones allow charging with the USB cable. With some phones, you also have the option to select whether you want to allow USB charging. If you're trying to charge with USB, make sure that your phone supports USB charging and that the option is switched on. please check ur settings..All the best
Happy to help
Have a nice day!
tc
May 30, 2008 | Sony Ericsson W850i Cellular Phone
Motorola W370 will not charge
Motorola provides a USB driver for just charging the W370. I installed it using the installation instructions from the Motorola website, but it just wouldn't work. The USB driver would install but would not activate (error Type 10). The W370 said that it could not charge. I recommend not bothering with this device driver, at least not with Windows XP.
However, I did figure out how to get the W370 charging from a USB port by trial and error. It's a pretty simple process.
1. Before plugging in the USB cable, turn on the W370 and wait for it to fully boot.
2. Connect the phone to the USB port of the computer.
3. When the phone asks "Connect phone as storage Device?", press the phone's left soft key, choosing "YES".
4. The phone will say "Please Wait...... Connecting Phone as Storage Device"
5. Eventually, the phone will display a white screen with the message, "In storage mode, no regular phone activities can be done."
6. Flip the phone closed. The yellow battery indicator will be lit. The phone is charging.
You'll note that the computer will see the W370 as a storage device with around 512 Megabytes of free memory, with empty "picture" and "sound" directories. The W370 appears to be a generic mass storage device to the computer. No special device driver is needed to charge the W370!
Mar 02, 2008 | Cell Phones
Charge by usb cable
When we connect the phone to PC it automatically start charging but after 5 mins it stops its because we do not take any kind of action i.e. if you will send some files to phone or will operate phone from PC it will keep charging otherwise as you have said it will stop.
Jan 17, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Sony Ericsson K510i Cellular Phone Logo
204 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
