RIM BlackBerry  Pearl  8100
Problem for RIM BlackBerry Pearl 8100
Missing text messages in blackberry pearl
By question_kat on Mar 06, 2008
On my blackberry my text messages will be erased from time to time. At first I thought it was just because I had used up all my memory, but it is happening more and more. Any help?
Clarification Request
Posted by akojim on May 10, 2009
Solution link . . . . http://www.IMBlackBerryPearl8100.com.
Same Problem
Apr 25, 2009
-   it deletes it-   Guest
Mar 13, 2009
-   I too have been experiencing that...
My text messages are erased...items I have sent and received...
And My Phone log...wiped...luckily
not my contact list nor emails...but...what is going on????
-   Guest
Feb 17, 2009
-   I just got my blackberry pearl a week ago and i am having to take the battery out and reset it up to 3 times a day it deletes my text msg and i cannot recive msgs also???? -   jorbritt
Feb 04, 2009
-   It happens to me all the time. I have to reset 5 or 6 times a day. It makes me almost want to switch phones. -   Guest
Jan 22, 2009
-   its probably is the memory thing, mine didn't show to be at zero file space left but when i got rid of old pictures the problem went away. -   Guest
Best Solution
posted on Jul 11, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
your dumb!!!!!!!!!!!!
Solution #2
posted on Mar 06, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Check this: Go to messages. Select the menu button (left of the roller ball). Scroll down to Options (near bottom). Select General Options. The last entry is "Keep Messages". You can select from 30 days to Forever. Hope that does it!
Solution #3
posted on Jun 03, 2008
Somewhat Helpful)
Concordium
Rank: Apprentice
Rating: 79%, 3 votes
1. Go to your main menu
2. Click on the "Options" icon
3. Scroll down to "Status"
4. If the field labeled "File Free:" has a value of 0 Bytes then any unsaved text messages will be erased from your inbox. Along with this, any new text messages you receive will automatically be erased as well.
I managed to free up space by only keeping messages for 30 days as well as deleting unnecessary applications. The apps take a lot of memory and will free up quite a bit of space for your new text messages. However, it eventually goes back down to 0 Bytes. I ended up running out of things to delete for the sake of freeing up storage space. I have a 2GB memory card in my phone but I can't seem to find a way to switch the SMS storage from my handheld memory to my media card memory.
BTW, Nigel you might want to look at your memory card and see if it is an HC media card. I'm not sure if the Blackberry is capable of reading HC media cards as I have found many similar "Smart Phones" can read a 4GB SD card but not a 4GB HC SD card. Hope all this helps.
- Shane #2
Comments:
Jun 03, 2008
- By the way, I just found this link after posting my previous "solution." I recommend everyone check it out because it is extremely helpful.
Click Here For Solution
Another Complete Blackberry Help Site
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Feb 09, 2009
Very Helpful)
lowboybrian
Rank: Apprentice
Rating: 100%, 4 votes
I also have had this problem with my Blackberry Pearl. It has nothing to do with your SD memory card. First and foremost, blackberry shortchanged the pearl when it came to onboard memory size. You'll find this out when all of a sudden your call logs, text messages (SMS & MMS) and emails are deleted. When you receive a call it shows in your call log for only about a half hour and gets deleted again. To verify that it is a memory issue, go to options and click on status. If your file free is at 0, you need to free up some memory.
If you text message alot, this can happen quite frequently. Especially with MMS messages which use up alot more memory. Open your messages folder, click the menu key and click General Options. Make sure your phone is set to keep messages for either 15 days or 30 days. Also another thing is to make sure in your Camera options is that all pictures get saved to your memory card. If your pictures get saved to the phones memory, you will always have this problem until they are deleted or moved to your memory card. If you downloaded any games or applications to your phone, this can also be the problem. They make plenty of games and apps for the Pearl but didn't give the phone enough memory to use it all without eventually locking up the phone. This was my problem. I had a few games and a couple applications like Yahoo Go and Sudoku that I deleted and it helped out alot with my memory issues.
There are alot of other things you can do to help free up some memory but it would best if you just call blackberry tech support for your service provider and let them talk you thru all the steps. I've been very happy with T-Mobiles Blackberry tech support because they are separate from the normal customer service line. I've hardly ever had to wait to speak to a tech unlike the regular customer service which can take FOREVER!
I like the Pearl but these issues can certainly frustrate anyone that doesn't know how to deal with them.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #5
posted on May 10, 2009
Not Rated)
dujinw
Rank: Master
Rating: 78%, 39 votes
Try this link . . . www.blackberry.com/RimBlackberryPearl8100
For find a best solution.
22
Was this helpful?
Yes
No
Solution #6
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The blac
Solution #7
posted on May 19, 2008
Not Rated)
nigel h
Rank: Apprentice
Rating: 0%, 0 votes
Hi Sntee- i have a 8GB memory card in the BB and it still does not solve the problem
Was this helpful?
Yes
No
Solution #8
Not Rated)
Sntee
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem and setting the "Keep Messages" option didn't help.
The issue did go away though when I installed a 1gb SD Memory Card.
I guess the BB must utilise the Mem Card as some kind of overflow memory..... who knows?
Was this helpful?
Yes
No
Popular Solutions for RIM BlackBerry Pearl 8100
Questions and Unsolved Problems for RIM BlackBerry Pearl 8100
Do you recommend RIM BlackBerry Pearl 8100?
Answer
Answer
how do i stop my blackberry from deleting contacts and messages?
Answer
my blackberry pearl wont stop taking pictures over an over again..no matter what button you press it... (More)
Answer
How do you shut of blackberry chat? Does it always have to be on or can I log off of it? I do not... (More)
Answer
i want to unlock my blackberry 8100 to use for alltel but the phone is not on
Answer
I have a blackberry curve and on the screen it says jvm error 513 so how can i fix it ?
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 08, 2008
Comment by nigel h, posted on May 18, 2008
yeah i  have the same problem with a blackberry pearl 8120! it does not delete the old ones either- it deletes the ones from today and previous days. i am relatively new to blackberry and i dont think it is the memory being full either. can anyone assist
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDAs Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
