Question about Refrigerators
THE FREEZER IS WORKING BUT NOT THE REFRIGERATOR
MY FRIGIDAIRE REFRIGERATOR IS ACTING UP. THE FREEZER IS WORKING FINE BUT THE FRIDGE PART IS NOT GETTING ANYTHING COLD. I HAVE TO STICK EVERYTHING IN THE FREEZER. HELP!
  • Anonymous Mar 14, 2014
    I have an Electrolux mini refrigerator model# FRT04LG3DB that work good but the freezer which is seperate from the refigerator part does not freeze, what could the problem be?
  • Anonymous Mar 24, 2014
    refrigerator wont cool freezer works fine help
Your defrost system is malfunctioning un plug refrigerator for about 2 hours replug and check if it makes a difference check if fan in freezer is working , you may need atechnician .
Posted on Mar 06, 2008
MY Frigidaire Refrigerator is 2 years old, the Refrigerator is not cold, but the freezer is working fine, what is common fix?
Most will tell you the freon is bad. but i have found in most cases the freezer works but fridge doesnt.. I have found the solution to be a bad cooling fan on the fridge it self. if the fan is not cooling the fridge will not cool. You could pull the fridge out and see if you can see the fan turn it on hi and when the fridge kicks in see if the fan or fans are working.. dust can cause them to slow or stop.
Jan 06, 2015 | Frigidaire Refrigerators
Frigidaire JSI-26 refrigerator side does not keep cold. Freezer works fine...
they share the same compressor so either the fridge air demand switch is faulty or more likely you have faulty thermistors.
Jan 06, 2013 | Frigidaire FRS23KF7AB Side by Side...
Freezer works fine, fridge doesn't cool at all.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 27, 2010 | Frigidaire FRS26R4A Side by Side...
Freezer side working fine - fridge side simply not cold enough even at highest setting
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Oct 17, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire 16.5cu top mount not cooling fridge. freezer is froze
The baffle that opens to allow cooling into the refrigerator may be blocked, broken or mis wired. These units work by just cooling the freezer and then blowing some cold air into the refrigerator whenever the fridge thermostat calls for it. The fridge's thermostat is trying to cool the refrigerator but something is preventing the cool air from getting to the refrigeration part, that's why it's freezing up the freezer
Mar 13, 2010 | Frigidaire FRT17B3A Top Freezer...
Fridge side of side by side Frigidaire not working
your damper door is frozen or iced up and not opening up to let cold air in from freezer compartment,defrost it and make sure its dry,also check your door seal to make sure its sealing good and not letting in warm air that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
Refrigerator gets too warm, then too cold, back and forth...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Oct 26, 2009 | Frigidaire FRT21H8 Top Freezer...
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
465 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
