Question about Maytag PER5705 Performa Electric Kitchen Range
Oven will not unlock
The oven door locked. I tried to unlock it by pressing the "cancel" button and "Cook and Hold" button; it was effective.
  • 552 Answers
Fault Codes
“Bake” or “Lock” may flash rapidly in the display to alert you if
there is an error or a problem. If “Bake” or “Lock” flash in the
display, press CANCEL pad. If “Bake” or “Lock” continue to
flash, disconnect power to the appliance. Wait a few minutes,
and then reconnect power. If the flashing still continues,
disconnect power to the appliance and call an authorized
servicer.
If this does not work let me know please.
Posted on Mar 06, 2008
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
Maytag double oven is locked and won't open
Hi. Has a fault code been displayed and a continuous beeps? press and hold the cancel & cook & hold buttons together for about 3seconds then door should open.
Hope this helps.
David
Sep 13, 2017 | Maytag MEW6630D Stainless Steel Electric...
I accidently put the lock on my oven.Now the lock will not come off. Please help
Hi
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above.
To lock the control panel and both oven doors:
  1. Press and release Cancel.
  2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Please see this link for more information as how to disengage the lock on your Jenn Air Oven---
Door Lock On Oven
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
How do I clear error beeping (F9) on my Amana gas range
try to hold in on the oven light switch plunger that the door would hit if it was closed properly. what you probably did was to pull the door open while it was trying to lock. once you hold the plunger in, then hit the clean cycle again and then push to cancel button to get the door latch to unlock the door. it may take a minute or two but that should clear up the error code and let you use the oven again.
next time if you push the clean by mistake, just let it go and then when it says "locked" just push the cancel button. it will unlock and be ready to use.
Jan 27, 2009 | Maytag MER6772 Gemini Electric Kitchen...
My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
  1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Dec 22, 2008 | Jenn-Air Electric Double Oven
Jen air locked latch after cleaning
I finally got my oven to work properly by shutting off the breaker and resetting the main clock. Cured the always locked problem as well as the beep twice when self cleaning.
Have to repeat this every few months since the problem seems to come back.
Feb 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Self cleaning
Maryann, try shutting the breaker off for 5 minutes and see if the door unlocks. Im assuming the oven has cooled down. If that doesn't work try holding the cancel and broil pads for 3 seconds. This will put it into the quik test mode. Once in this mode press the clean button. This should toggle between lock and unlock. Don't know if this will work for you but it's worth a try..Catriver...post back.
Oct 12, 2006 | Jenn-Air JJW9330D Electric Single Oven
Oven and clock inop
You might have a problem with the circuit breaker - reset it by pressing the switch ocated on he lower edge of the backguard (in Canadian models). There are several things that could cause the oven not to operate, but generally you would get a message on the display - "Lock", "Sabbath" etc. Just in case your display is damaged and that's why you don't see any message, try to press and hold the "cancel" and "cook and hold" pads for three seconds (to unlock the oven in case it is locked), and then check to see if the oven works. if not, repeat this procedure (to make sure that you didn't lock it just now), and then press and hold the "clock" pad for three seconds (to unlock the oven in case it is in "sabbath mode"). If it still doesn't work, you might need to replace a fuse.
Apr 05, 2006 | Amana AER5515QA Electric Kitchen Range
Maytag PER5705 Performa Electric Kitchen Range Logo
269 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
