Question about iLO (2 GB) MP3 Player
Disc helppp Over and over have I tried to get this disk to work for me. Still, it has the upper hand. It keeps telling me that my system requires an updated version of this so-called "Easy-Install Disk", and advises that I go online for an updated disk. Well, the link it sends me to seems to have absolutely nothing to do with my problem. What do I do?
  • 8,596 Answers
Just plug it in, and let Windows XP load the drivers. You don't need the CD.
Posted on Mar 19, 2008
I bumped my 40 gb PS3 the other day kinda hard, it wasn't dropped. Now, I turn it on and it works like usual,and I have a menu screen and I have the hand-spinning clock in the upper right corner. But...
First try a different disc if you haven't already, but it sounds like you may have knocked the laser out of alignment. On older playstations and other cd or dvd driven system the laser was much less sensitive then it is on the playstation 3 since it has a bluray laser. If you system is still within warranty i would suggest contacting sony to get it repaired, or take it back to the store you bought it from. If not under warranty then i would look into replacing the bluray drive. Often these parts can be purchased on ebay or various other sites.
Jul 21, 2011 | Sony Playstation 3 (PS3) Console
Hi my mixer on the right hand side doesn't work, it keeps telling me that its an error and wont eject the disc that it has in it.
Some of the failures to eject a disk problems are due to failure or slipping of a little drive belt that moves the carriage out. Also sometimes the alignment is bad and the disk hits the front escutcheon.
Mar 15, 2011 | Music
I have my dads xbox 360 and he said i could use it and i am trying to play halo 3 buut it keeps saying disk unrecognizable please clean disc with a soft clothe and restart your console and ive done that...
take your disc to a video shop and pay them to renew it shouldn't cost much or go to a second hand shop that sells it buy it and put your disc back in and tell them it didnt work swap money back ha
Jul 18, 2010 | Microsoft Xbox 360 Console
Issue with opticaldrive and creating factory default disc
most of the time to create recovery disks you have to use about 7 cds, 2 DVDs, 1 blueray or double layer. some systems also use DVD+R, when you start the disk creation it would tell you what it requires, your best option (if compatible) would be using 2 DVDs-R. On the other hand if you inserted the cd and it turned a few revs. most likely it is ruined already so you have to use a new disk.
if it is a brand new pc you should be able to use DVD. here is a tutorial for HP and it is pretty similar for most computers
http://www.wikihow.com/Create-Recovery-Discs-for-Windows-Vista-in-HP-Recovery-Manager
if it works for you don't forget to rate me
thx
Apr 28, 2010 | Gateway Computers & Internet
Having a problem with windows media player. I put in a cd and try to get it to rip and it comes back and tells me to put in a disc. I put a disc in to play and it tells me to put in a disc. It is like it...
Does it only happen in Windows media player? If it does try gettting the updated version of media player. if it happens in other applications try changing the dics. If that doesnt work, you need to delete the lower and upper filters in the registry *Note* if you are not really comfortable in doing that then dont, Wrong move in the registry can mess up the operating system, here is the link how to delete the lower and upper filters
http://support.microsoft.com/kb/314060
if these doesnt work uninstall then reinstall the driver for the optical drive..
try also getting an update from your computer manufacturer. update for the optical drive, or BIOS
lastly, try reinstalling the operating system, if these doesnt work change the optical drive because its a hardware issue..
Mar 07, 2010 | Computers & Internet
I can't play a disc becouse the region code is incorrect on SD-4000 DVD Toshiba, how I can change the code
Hi, hmm...try this and let me know if it works^_^ Goodluck!
1. Power on the player.
2. Open the disk tray.
3. With the remote, enter the numbers 9 8 7 9 and
then press 0 (for region 0, or multiregion). A prompt
at the upper right hand corner of the start screen should tell you that the player has been set to region 0.
4. Close the disk tray.
5. Power off the player and then power it back on.
Hopefully this will work on all players of this model.
Apr 01, 2009 | Televison & Video
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
Cannot eject finalized disc
Try turnin the camera to the side where gravity will help pop open the disc and be careful not be keeping it close with your own hand. Its a thin cover and you can accidently be holding it close without knowing.
May 24, 2008 | Canon DC10 DVD Camcorder
iLO (2 GB) MP3 Player Logo
21 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
