Question about Sharp R-202EW Microwave Oven
SHARP R-316F The lighted Display section on my R-316F SHARP microwave went dark today. I can still see the numbers faintly there in the black, but it's almost invisible. The interior light and all other functions seem to be working fine. Purchased 6/28/04. Any ideas? patgunderman@att.net
  • 2carrs Nov 23, 2008
    I have exactly the same problem. The display went dim and then completely out. Did the repair idea work? Was it difficult to do?
    Problem Solver:
  • 6 Answers
I had the same problem with my Sharp R-330F.  Everything worked fine except the display was very dim.  I figured out that the backlight LEDs weren't receiving any power from the microprocessor board.  (Three surface-mount LEDs on the circuit board behind the display).  I couldn't trace the problem past the microprocessor board, so in the end I manually connected the LEDs to the +15V supply on the board via a 4k7 resistor - cut the track to the microprocessor board, soldered a 4k7 resistor to it, and soldered the other end to the ground of the bridge rectifier on the board.  4k7 was a guess but the brightness is about right.
The display works fine now, but this repair isn't for the inexperienced.  Actually this is the same repair suggested by the "guest" above, but when I first read that solution I thought it was a joke.  It isn't, and it works!!
Posted on Dec 16, 2008
Easy to fix you need to cut the tracks to the led lights then solder 2 wires to the leds next use a 1k resistor on one of the wires then conect it straight to the power surply just after the bridge rectifier noteing+ and -
Posted on Mar 06, 2008
  • Everett Mounce May 02, 2013
    CAN YOU SEND ME A DIAGRAM OR PIC OF THE FIX SO I CAN SEE THE PLACE TO PUT THE WIRES emounce@accesshsd.net
Hi our microware is not working, can you help me?
I have serviced 100's of microwaves and the most common problems for microwaves not working 1)fuse blow(but display will be dark), 2)not plugged in(or house fuse blown) (microwave display is dark and other outlets would be off) 3) connections to one of the door switches is burnt out. The display is not dark but microwave will not work. The wire going to the switch looks black right at the switch.(this wire must be removed and a new connector attached to wire and then reattached to the switch
Dec 24, 2017 | Microwave Ovens
No Power
hi,
Did you try replacin the fuse.It might have blown.
Jul 03, 2008 | Sharp R-930AK Convection/Microwave Oven
Sharp Microwave diplay light not working
We regularly repair these display / control units nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 07, 2010 | Sharp Microwave Ovens
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
Sharpe Microwave R-316F Display Light
first remove the outer cover by removing the screws at the back.then u should see a screw behind the control board that holds it.remove that screw and the control board comes out.disconnect the wires from control board and remove remove the panel assly.then remove the screws that hold the control board to the panel.
Aug 18, 2009 | Sharp R-316FS Microwave Oven
Sharp microwave r610dsa - display faint - barely visible.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
We have the full service manual at our site, which contains the specific safety & disassembly information you'll need here.
If you decide to send yours in for repair, we would really need the front door panel assembly (which contains the keypad, display board and connecting cable) as well as the power board to which the cable connects, as shown in the manual.
If you prefer, you can order part number DPWBFC212WRKZ (CPU/display unit) for $73.33 plus shipping from Encompass here or you can call them toll-free at 866-779-5835.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Jul 08, 2009 | Sharp Microwave Ovens
Sharp R-630D
Hi, sorry fixya site is having some problems the experts are not recieving the emails with your response so we have to do it the long way and it takes ages going through all the posts we have helped on.
Ok then if the display is faint then the chances are its going to be the lcd display thats the problem as the display is working its just not lit up so replacing this will solve your problem but its not an easy job to do and is extremely dangerous microwaves are one of the riskiest things to work on as they give of radiation so breaking any seals can cause damage to anyone standing next to the microwavy.
The display is usually lit up showing the numbers but as you can see them faintly this tells us the circuit is okay and not shorting so its not anything drastic but replacing would be difficult.
If the inside is fine where the runners are then the chances are it would be worth getting repaired but if the paint has worn away or any rust is visible then the safest option is to replace it ok.
Let me know if you need further assistance ok
Apr 21, 2008 | Sharp R-630D Microwave Oven
Sharp R-1611 panel display, lights & touch pad not working
This is a problem with the control panel assembly, which we repair nationwide for $39.95. You can find full details on our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 11, 2007 | Sharp R-1610 Microwave Oven
Open Questions:
Sharp R-202EW Microwave Oven Logo
407 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
