Question about HP Pavilion 533w (P9859AR#ABA) PC Desktop
Hp pavilion 533x wont boot up
My computer wont boot up it goes to a blue screen and sayes theire is a conflic on the computer
  • Anonymous Mar 28, 2014
    computer only shows blue screen when turned on
    Genius:
  • 1,226 Answers
Hello!
REinstall the windows operating system, don't forget to install the driver after installing the OS>
melnavz
Posted on Mar 06, 2008
My HP Pavilion is stuck on the blue screen
While your system is still booting from start, keep hitting F11 to get past that point then proceed with the system recovery.
Nov 12, 2013 | HP Pavilion a6110n PC Desktop
I turned on my modem, an all that is displayed on my monitor is the blue hp screen. In the botton left hand corner it says <F10=Setup> and <Esc = Boot Menu> and in the right bottom corner, it...
what modem, who's and where, ?
or is modem , monitor?
which blue HP screen there are many,
you left out what it says...
i can not watch you boot, and what is displayed, is key to the cause.
NO OS stated, is this XP?
when you boot, it always prompts in text ,hit ESC key to enter setup"
this is the BIOS hot key prompt that some times shows
a cute small HP icon this too is BIOS created.
then the PC boots and goes to OS, there many OS offered
Windows is XP is one? is it?
or Vista.,w7,/8/10 or PS/2 or linux. HP has many offered OS.
as do Refurb companies endless.
if windows?, the windows log in screen is next.
so my guess is the PC goes to BLUE screen that, before that.
stating (presenting)
startup file failed?
or , HP recover failed.?
or any of 50 other windows blue screens of *****.?
why not post a photo of the screen?
one screen is the XP BSOD , crash screen.
seen here.
one other blue screen is "windows is doing updates" so let it??
one modern HP W10 screen 1 of 50
this is most times below a bad video card driver used on PC.
not matching card to OS. and bam crash.
Aug 28, 2017 | HP Hewlett Packard Pavilion Slimline...
Hp pavilion a1330n stuck on invent screen if I keep tapping escape key on boot up it says loading boot menu but just hangs on this screen . Also when turning on it shows my nivia grapghic card memory...
Hi.
This sounds like your bios has gotten "stuck".
This procedure may or may not work, but it has worked for other hp/compaq computers in the past.
First, if you are connected with an ethernet cable disconnect it from the computer.
Next, disconnect the power cord, so that there is no power at all going into your pc.
Now, while it is unplugged, press and hold the power button, and hold it for at LEAST 45 seconds, this causes the capacitors to discharge their loads, and returns the motherboard to a "ready" state.
Make sure that you hold it for at least 45 seconds, as it takes that long for a full discharge to occur.
Now, after that, reconnect the power cord.
Now try to turn on your computer.
If all goes as planned, then your computer should now boot up for you.
If it does boot up, then you can reconnect the ethernet cable.
If it doesn't boot, then either your hard drive, power supply, or drive controller portion of the motherboard has failed.
If that is the case, then I guess you will have to get replacement parts, and put in new for old.
I hope it's not the hard drive, because that would mean all your data would be lost.
Hopefully, this does work though.
After all, it is an official cold reset of the motherboard for HP computers.
I know the steps by heart, that's why it's so easy for me to tell you how to do it.
Good luck to you, and hopefully you'll be up and running in a matter of minutes!
Jun 16, 2011 | HP Pavilion Media Center a1330n - AMD...
My hp Pavilion a450n wont boot it shows the screen where it says Window XP and it shut down and for maybe 1 second shows a blue screen with some info and it goes back to asking to start window normally...
It sounds like your windows OS installation has been corrupted. Your computer might have a recovery partition like many HP models do.
Try hitting F11 when you first turn on the computer (watch the screen in the corners. It may say something like hit "F2 to go to BIOS or F12 to choose a boot device/ etc. Each computer is different in this regard).
If you can get into the recovery partition you may be able to do a windows repair. Alternatively, if you have your windows disc you can boot off the cd and run the windows repair tool like that.
I would HIGHLY recommend manually backing up any and all important files first. If you have a USB enclosure use that to pull the drive out and hook it up to another computer. If you dont then I would run a bootalbe version of linux or something and transfer your files to a USB drive or burn to a cd. See here to download ubuntu.
Mar 01, 2011 | HP Pavilion a450n PC Desktop
Hp pavilion a305w won't boot up all the way screen
hi, for select the boot option press F8 on your keyboard.. if your computer have a problem it will pause then it will restart mybe it might have a software or memory problem.. To fix the software problem you only put your recovery disk then start recover.. if the problem still their then you have the hardware problem to fix it you must remove your old memory in the computer then buy a new one...
regards...
Mar 04, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Jun 08, 2009 | HP Pavilion TX1320US Tablet PC
Hp pavilion zx5000 windows will not start, goes to blue screen
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
Jan 21, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Blue screen during booting
Yes, unmountable boot volume usually means you need a new hard drive. However, if you have a windows xp cd, you can boot to the recovery console (press R at the first prompt) and try running a chkdsk /f command. Sometimes that will help. Thanks and good luck! Oh and if you could remember to give this solution a rating of fixya. Thanks!
Jan 18, 2009 | HP Pavilion ze2000 Notebook
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Frozen screen
try to log in safe mode when the laptop is booting by pressing F8 key, you will see many option select boot in safe mode, if you can boot in safe mode then reboot normally. if the problem remains then you have to repair or reinstall your operating system.
Dec 15, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion 533w (P9859AR#ABA) PC Desktop Logo
147 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
