Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Water valve Where is the water valve everyone is telling me to replace and is it an easy job? How much does it cost and which one do I order. The whirlpool website parts guide does not show the part and it list several different sizes. Thanks for your help. Michael
    President:
  • Whirlpool Master
  • 2,651 Answers
Order the water inlet valve model specific. its located behind refrig where he wateline is hooked into
Posted on Mar 06, 2008
Maytag regrigerator MSD2651KES
Changing the 67006531 Water Inlet Valve is quite simple. If after
watching this short video you have questions please let me know If you want a service manual for this model let me know HERE. I can't post the manuals for everyone to copy. Thanks Sea Breeze
Video Here=> Refrigerator Repair - Replacing the Water Inlet Valve (Whirlpool Part# 4389177)
Nov 24, 2012 | Refrigerators
Cold Water fills VERY VERY slowly (i.e 2 hrs to do a load)
It is an easy job, as the valve and solenoid mechanism are what the cold and hot water hoses connect to (at the back of the machine) and tilting the machine forward, and maybe removing a cover you'll have easy access to the switching valve (at least on most of the washers I've worked on the valves where easily accessible),
You can tilt the washer forward and take a look for yourself before you decide to proceed.
Good luck and happy DIY.
Aug 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
Tip
How to service water valves
If the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
- Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
- Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
- Tap the solenoids with a screwdriver. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
on Jan 16, 2010 | Washing Machines
Why is there only hot water going in the washing machine?
the cold water valve is stuck shut inside washer.
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
I have a ge washer wpsr3120w0aa that leaks water when rinsing
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Troubleshooting Water Leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 29, 2009 | Washing Machines
Water does not shut off. Water flows constantly
Aug 29, 2009 | GE WBVH6240F Front Load Washer
The cold water will not run.
Aug 24, 2009 | Maytag MHWE300VW Washer
DISPLAYS LF (LONG FILL) ERROR CODE WHEN HOT WATER is involved.
This is a faulty water valve Assembly. you can order this online and it is shipped with easy to read instructions on how to attach as well. it quite the novice job.
May 21, 2009 | Whirlpool Washing Machines
Ice Maker Water Supply Hose Freezes
Justin, the cause is a failed water inlet valve (behind the fridge, near the floor). The solution is to replace the valve.
The part number of your valve is 4389177 and it lists for ~$65.00. You can find one at a local appliance parts outlet or order it online. (actually, the valve kit comes with instructions =) )
Easy to replace. Pull out the fridge, unplug it and turn the water off at the wall. Now use a 1/4" socket or nut driver and remove all the screws holding that cardboard cover in place. Now remove the water hose from the valve and remove the 2 screws that mount the valve to the fridge. Pull the valve out and notice how it's wired and how the plumbing is done. Then simply wire in and put the tubing on the new valve and rebuild everything.
Job time? About half an hour. Good luck and don't sweat it, this repair is a snap.
Nov 04, 2008 | Whirlpool ED5FHEXMQ Side by Side...
GE WHRE5260E1CC NO HOT WATER
hi If the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
Sep 13, 2008 | GE WHRE5260E Top Load Washer
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
66 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
