Question about OKI C3400n Laser Printer
No connection I installed my printer as per instructions for network. Everything installs okay. status monitor says network or power cable not connected. Everythings hooked up. I run windows xpsp2 with AVG, snappy fax and a d-link wireless router. It does the same thing trying to use a usb cable. Any ideas???
    Sergeant:
    Champion:
  • 277 Answers
Try to manipulate device manager if you see a auknown device remove it, and restart your computer
Posted on Mar 06, 2008
How to troubleshoot HP Printer not found during network driver setup issue in Windows Operating system?
Download the full feature software from the HP website or on the software disc and setup your printer for wired or wireless network connection.
There might be one of the following errors if the installer does not detect your printer after setting the connection type.
1.Printer not found
2.Devices not found
3.Unable to find the printer
During the Hp printer network setup, there may be some troubleshooting issues,
Step 1: Reset or restart your computer, HP Officejet printer and the router
1.Disconnect the power cord outlet from the router.
5465_install_1a-ur23imwvkexuk45mistkg3hp-5-0.gif 2.Close all the tabs running on your computer and shut down your computer.
3.Then turn off the HP Officejet 4650 printer.
4.After few minutes reconnect the power cord outlet to the printer and wait till the connected status light blinks to normal.
5.Then turn on the printer and computer.
6.Again install the HP driver and software.
Step 2: Check the status between the printer and the network connection.
Before the setup confirm that your printer is ready.
1.Wireless Network: On the printer, open the wireless network connection settings menu and check whether the wireless signal is turned on.
2.Wired Network: Check that cable is connected to the printer Ethernet port.
Note: The green light should be in steady status and the orange link should blink when the cable is connected and make sure that your HP printer is not connected to a guest or host network.
1.Set the band to 2.4GHz if it is dual band router else the printer cannot connect to the network.
2.Check the network name and status of the connection in the notification bar.
3.If it is a different network then reconnect your network to complete the setup.
4.Move the computer and HP Officejet 4650 printer closer to the router if the signal is weak.
5.Slide the Airplane mode to off if it is on.
6.And again try installing the software and driver.
Step 3: Run the HP Print and Scan Doctor:
1.HP provides a free tool called HP Print and Scan Doctor to resolve the scanning and printing issues.
2.Download the HP print and scan doctor software to resolve all the troubleshooting issues.
3.After the installation on the Welcome screen click start.
4.A new menu box appears on the screen with the printer list. If your printer is not listed then turn on the printer again and connect it.
hpscanprinter-ur23imwvkexuk45mistkg3hp-5-2.png 5.Click the option my product is not listed and then select retry.
6.After that, your printers display and select it.
Step 4: Temporarily disable firewall software.
If the firewall software is installed on the computer that will help you to block the threats that found on your computer.
Use the print and scan doctor to identify and temporarily disable firewall software on your computer.
1.Click network on the print and scan doctor window.
2.A drop down box appears in that select the option troubleshooting firewalls.
3.Click the firewall software to disable it.
4.And install the HP driver and software.
If the HP driver is successfully installed then consult the firewall software support to change the settings as security level, trusted zones. After changing the settings re-enable the firewall software.
If the HP driver is not installed then there is no issue in firewall software and re-enable it.
Step 5: Uninstall and reinstall the HP drivers and software.
1.Disconnect the cable if your HP Officejet 4650 printer is connected to the USB cable.
2.Click programs and features in the search windows.
3.A list of installed programs will be displayed click your printer name and uninstall it.
4.Then follow the on-screen instruction to complete the process and restart your computer and reinstall the software from the official site.
If you still have doubts regarding this setup you can call us @1-800-836-3987 or visit us 123 hp setup oj 4650
Jul 06, 2017 | HP Office Equipment & Supplies
My printer will not pring
1. Please check if the ink cartridge is empty or not. If empty or nearly empty, better to change a brand new cartridge as per instructions;
2. Please check if the printer driver installed in the PC is still damaged or not. Suggest to re-install the printer driver once again;
3. Please check if the printer cable (USB/Network cable) is connected firmly from the PC to the printer. If found loosen, please connect it firmly;
4. If you found the printer led light is not turned on even you have plugged the power cable correctly, please change another power cable for testing; or may be the power bar is not working properly;
5. After you tried all these steps and the printer still couldn't work, please disconnect it and send it to the Canon repair center for proper repair and maintenance. Please do not open the chasis of the printer by yourselves.
Jul 23, 2014 | Canon Pixma MP600 Printer
WHY DOES MY DOCUMENTS ARE ALWAYS IN PENDING STATUS WITH MY hp psc 1310. wHAT DOES IT MEAN WHEN THERE IS OFFLINE STATUS OF THE PRINTER?
It means your printer is not connect correctly to your computer. Can be various problems.
1) Make sure when you print that you select that specific printer as more than printer can be installed on your computer. 2) Go to control panel and set that specific printer as default if there is more that one printer installed on your computer (3) Make sure your printer is power on (4) make sure the USB cable if you use use cable is well connected - sometime they tend to pull out a bit without you seeing it, just push it back in (5) Try another port on your computer (6) re-install the software (7) if you are using a network printer this becomes another ball game - please confirm if you are using a local printer plugged into your computer or if you are printing over a network. Cheers!
Jun 14, 2014 | HP psc 1310 series
Idle printer status
If your computer is USB connected make sure that the cable is connected and that the printer is powered up. If you are connected to the printer over your network through wifi or ethernet, make sure that each device (computer and printer) is connected.
If all of these are in order and the printer still shows offline, try re-installing the software that came with the printer. Sometimes the software needs to be re-installed due to corrupted files.
Nov 24, 2013 | HP Computers & Internet
Directly connected to laptop, wont print!
Just insert the CD and DO an Add A Device which will be there in the menu
Follow the instructions
Select the option of installing through the network and it will be done
Take a Network configuration Page and get the IP of the Printer
It would be like -169.254.xxx.xxx
Open the internet brower
put in the IP address of the printer in the browser
if the printer page opens its okay or else check your connection
check your firewall settings
you can also check the ports tap in the printer icon properties in the control panel and check whether TCP/IP port is selected or not
if yes check the IP assinged to that port
Oct 14, 2009 | HP Photosmart C6280 Printer
Recent lightning strike in area, lost two tv's two dvd players, phone service, modem. power strip that computer and printer were using was affected. computer appears okay. printer not so good. HPPhotosmart...
Usually the instructions say to NOT have the USB cable plugged in BEFORE the software has been installed... Maybe you had it connected before??? If so, uninstall and unplug the USB cable and reinstall per directions.
Aug 09, 2009 | HP Office Equipment & Supplies
Connected it to a network but it will not print
enable file and printer sharing from the network properties on the other computers. on the first one, make the printer a shared printer and try to install in into the other computers as a network printer
Jul 14, 2009 | Office Equipment & Supplies
Help
DOWNLOAD
Please follow the steps below to download the necessary drivers:
1. Go to the website http://support.epson.com
2. Under the ALL-IN-ONES heading select FLATBED and then your printer model.
3. Under the Drivers & Downloads section select WINDOWS. Download the most current version of the Printer Driver and Scanner TWAIN Drivers to your DESKTOP for your Windows operating system. You can also download the Status Monitor, if listed.
DOWNLOADED DRIVER INSTALLATION.
Scanner Installation
1) Before beginning, ensure the cable for the printer is disconnected and the printer is turned off.
2) Locate and double click on the downloaded Twain driver installation file.
3) Click on OK at the first WinZip screen.
4) Click on UNZIP at the second WinZip screen.
5) Click on OK when WinZip is finished extracting files.
6) Follow the prompts to complete the installation.
Printer Installation
1) Locate and double click on the downloaded Printer Driver installation file on your DESKTOP.
2) Click on OK at the first WinZip screen.
3) Click on UNZIP at the second WinZip screen.
4) Click on OK when WinZip is finished extracting files.
5) At the PRINTER UTILITY SETUP screen, click on OK.
6) The installer will now copy files to the computer. When this step is complete, it will tell you to attach the cable and power on the printer. Please connect the USB cable and turn on the printer.
7) The computer will install the new hardware.
8) Click on OK when the driver installation is completed.
Status Monitor 3 Installation (optional)
1) DOUBLE-CLICK on the downloaded file.
2) Make sure the STATUS MONITOR is highlighted and then click on OK. The installer will now copy the necessary files to your computer.
3) When finished click OK and restart your computer.
Aug 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Lost my installation disk
Aug 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Minolta 2300w
color light has nothing to do with this, first try once more to reinstall drivers, if still shows wrong printer, then you have to upgrade firmware, because if you installed the correct mc2300w drivers and status monitor tell you wrong printer there can be 2 things. firmware is broken or printer/computer usb port is broken. so if you can use another usb port or another computer try it or LPT cable. and as a laast thing update firmware.
May 17, 2008 | Minolta magicolor 2300W Laser Printer
OKI C3400n Laser Printer Logo
144 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
