Question about HP OfficeJet d145 InkJet Printer
New printheads and cartridges but not printing only blank sheets
Message :IDS Failure, call HP
Went through the purported posted solution by HP but did not help.
How do you clean or flush the printheads?
Do it the maintenance way many times>
  • 731 Answers
IDS (Ink Delivery System) failure is not related to the print heads at all. It pertains to that delivery system that lies between the Print head and the Ink Tank. Its a Hardware Issue, some ttime it gets fixed by resetting the printer.
Follow the below steps.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER button and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Posted on Mar 06, 2008
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Will not print
get a new printer,you got 4 years out of it
May 19, 2015 | Kodak Office Equipment & Supplies
Why won't my printer print black with all new cartridges?
Remove all inks, then the printhead & sit the printhead on a soft cloth soaked in warm water - let it sit for a few minutes then reinstall, close lid then make the machine ask for the inks once the inks have then been installed it should prime the machine. If this does not work try it again & if that fails then your printhead probably needs to be replaced.
Aug 12, 2014 | HP PHOTOSMART PLUS B209A All-In-One...
Reset printer cartridges hp l7580
The failure to recognize an ink cartridge(s) could either be a possible Cartridge connectivity, PRINTHEAD* connectivity or an end-of-life PRINTHEAD issue.
We suggest you remove all the ink cartridges and thoroughly clean BOTH PRINTHEADS manually along with cartridge chip contact surfaces (located on bottom-rear side of each ink cartridge). Clean all electrical contacts, including those inside the printer which mate to the PRINTHEADS. Reinstall both PRINTHEADS and cartridges and retest. You may refer to HP's 'manual' cleaning procedures here:
Ensure an "expired ink cartridge" alert state is not causing the issue, refer to this page on how to check & bypass:
---- If you observe an "Expired xxxx ink cartridge" alert or message, this error may be bypassed by performing the following:
a. Press and HOLD the Power button.
b. Press Resume button 3 times.
c. Release the Power button
If the cartridge was refilled (i.e. at Costco or Fry's Electronics), following HP 88 cartridge chip replacement and complete cartridge/printhead/printer manual electrical contact cleaning, the cartridge alert message(s) continue, then you may have a damaged PRINTHEAD* (there are two printheads inside the printer) which may require re-priming or replacement depending on problem symptoms.
* The HP 88 ink-series printer models have two electronic PRINTHEADS (each of these electronic devices are responsible for pulling ink from the ink cartridges and then firing the ink droplets onto the paper) - both PRINTHEADS will eventually fail depending on printed content, printer duty cycle (i.e. typically rated for ~41, 500 printed pages depending on image content & frequency of printing). The average inkjet printer can typically be refilled with ~15 to 20 complete sets of ink cartridges over the life of the printhead, after which, either the Yellow/Black and/or Cyan/Magenta printhead will need to be replaced due to internal electrical failure (available at
Refer to video on how the HP PRINTHEAD functions:
When the PRINTHEAD electronically fails typically the printer will provide an alert message when this happens, but if a printhead has suffered a deprime (i.e. loss of ink/pressure which results in no printing of color), it is possible to recover the system using a 3rd party PRINTHEAD priming tool, such as this one:
For advanced HP printer diagnostics or information on ink refilling services, please visit Inkjet411:
Aug 15, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
First of all, I hate to say this but, be sure you are using a genuine HP 02 black cartridge. Refilled / re-manufactured cartridges can cause damage to the printheads because their formulas are sometimes too acidic.1) Press the SETUP button on the front panel by the display. 2) press the DOWN arrow until "Tools" is highlighted on the display and then press the OK button 3) Arrow down again until you see "Clean Printheads" and press OK again. 3) After cleaning, press Setup again.. Arrow down to "Print Report" and press OK. 4) Arrow down to "Self-test Report and hit OK again. Your printer will print out another page. If the black ink is flowing on the self-test page but yet not when u are using the computer, then there's got to be some software problem on the computer itslelf. If it still doesn't print from the black printhead the we usually have either a print head failure or an IDS (Ink Delivery System) failure.
Jul 21, 2010 | HP Photosmart C7250 All-In-One Thermal...
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
I can't get the printer to print using black ink.
I went through the troubleshooting styeps and it seems that when you leave the cartridge out too long, the printhead gets clogged and it needs to be replaced. Contact Kodak at 1-800-421-6699.
To expedite the call, provide the agent with the one of the following reference IDs - PH02 for image quality problems or BP01 for problems with blank prints.
When you get your new printhead, follow the steps in this document to replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Cannot print
K...Trust the solution. Try these steps. Open the printer, remove the ink and remove the printhead (See User's guide). Reseat the printhead and the ink cartridges. The printer will come up with an error message that requires calibration. Do the calibration and scan the sheet that prints right after by pushing the start button. In the menu options, clean the printhead. Do one basic and one deep. Print a demo sheet (another menu option) to see if the quality has gotten better. If it has not call Kodak AiO Tech support. You will need a replacement printhead.
May 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black won't print
will print blank? try to do this, remove the cartridge and the printhead, put it back again. perform a deep clean by press menu>clean printhead>deep clean
print a demo sheet by pressing menu>print demo sheet
if it fails then contact kodak..
Mar 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP OfficeJet d145 InkJet Printer Logo
120 people viewed this question
Ben Johnson
