Question about Kitchen Ranges
MAYTAG STOVE PROBLEM...NEED HELP
Maytag electric stove approximately 8 years old. Today while using the oven (Bake setting), after about 20 minutes the stove displayed F1, beeped, shut off the bake element, but entergized the broiler element. I tried canceling all indicators but eh over would not respond, or turn off the broiler. I switched off the breaker, waited 30 minutes and turned on the breaker. The clock came back on but the broiler started heating up.
Is this a control panel issue or possibly a sensor?
  • 6 more comments
  • dovergrants Mar 07, 2008
    Yes the broiler came on automatically during the F1 error and beeping. Like I said. Thanks for suggesting the wires, I checked all wires and they seem fine. No it does not say Broiler or anything, the broiler just starts up. Tried it again today (after 24 hours) same thing, the broiler comes on and will not shut off unless you shut off the breaker. Could the touch pad be shorted? or one of the pads in the touch pad stuck? This is an excellent stove so I would rather repir than replace (If possible).
  • jd_bee Apr 10, 2008
    My "cancel off" switch will not work. I just replaced the oven control assembly (clock) and everything works just fine except the Cancel Off switch does not work now. I have a new relay board (downdraft) on order now, too, but I doubt it will fix this problem. The Cancel Off switch was working fine until I replaced the oven control assembly, which was necessary because other controls were not working. A new front panel costs $286 from Sears, so I would prefer to fix this switch somehow, if possible.
  • Anonymous Jul 31, 2008
    Broiler comes on automatically while oven is on. I have to shut off the breaker to get stove to cut off.
  • lpstudio7147 Aug 05, 2008
    The baking element will not shut off. I started by turning bake on then when I turned broil on the baking element went off until I turned broil off then the baking element came back on and won't shut off.
  • crwcjwidw Aug 14, 2008
    I have a frigidaire duel fuel range and tonight when I went to bake the broiler came on and would not shut off until I shut the breaker off. F1 and F3 appeared and would not go away after hitting cancel.
  • Anonymous Mar 17, 2014
    elements checks out ok, but will not turn on
  • Anonymous Mar 20, 2014
    baking element at high temp
  • Anonymous Mar 22, 2014
    the fan has a red circle around it and a red line,(conv) normal bake it switches back and forth between top and bottom red line, it does not reach higher that 200 temp
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
The broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Posted on Mar 06, 2008
Did a oven clean and tryed the oven,.. my oven will not come on i tryed the braker reset and click back to panel display F1..tryed waiting a hour.. but reset and click" back to F!..will not heat up the oven elements...can u tell me what to do
Posted on Feb 11, 2009
Mgr8775 keeps shutting off during bake
mine does the same, the sears tech investigated today and was told by the tech support that it is a known issue and the ignitor module and burner need replaced. I'm mad at getting a replacement range [for another maytag failure under warranty] with a known issue that leaves us without a reliable oven for a month!
Jan 24, 2013 | Maytag MGR8775AS Stainless Steel 30 " Free...
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Oven won't work. Maytag Performa Stove. Broiler and burners work.
sounds like your bake element is gone
but the model number would help a great deal
pul out the stove unplug it, take off the back, and inspect the connections on the bottom element
if its gas its probably your ignitor
take out the racks
take out the bottom
set to bake
you should see a very bright light within a minute
if you dont thats the ignitor
anyway both parts are available
and both are a pretty starigt forward repair
Oct 09, 2009 | Maytag Performa PAV2200
When I press BAKE to preheat the oven or CLOCK to set the time the display goes blank, then the number 30 appears, and then the clock time resets itself. I can still use the oven to preheat or bake, but...
I have the same problem. I bought it new in the fall of 2007. They replaced the control panel but that didn't help. Next they replaced the whole range with a new one, same model, still the same problem. They told me it was a problem with my electric in my house. Then they said it was a strange electro-magnetic field in my neighborhood and I would have to buy a different brand?
One time with the original stove the oven quit working and I had to re-set the breaker. Everything still works but the clock is always wrong.
We bought all Maytag stuff, including fridge, stove, microwave, dishwasher, washing machine, and dryer. The kitchen stuff is 4 years old. The washer and dryer are 3 years old. We have had this issue with the stove, the washing machine broke and they had to replace the whole drum assembly, and last week my refrigerator broke. Very disappointed with Maytag stuff.
So has anyone found a solution?
May 17, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
Maytag gas Stove MGR5710 bake oven does not work. boiler works
Usually I always find it's the ignightor. They are not to hard to replace. It's #5 on this looooong link
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MGR5710ADW&productCategoryId=0124002&brandId=3048&modelName=GAS-RANGE&diagramPageId=00005&componentDescription=GAS%20CONTROLS&documentId=X2906551&backToLink=Return%20to%20Sub%20Components%20list
Or go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
enter your model number and it'll kind of show you how to get it apart. Good luck.
Scott
Jan 23, 2009 | Thermador REF30 Electric Kitchen Range
How do i get to the fuse on the maytag stove
your stove doesnt have any internal fuses. if you are not getting "any" of the units to get fully hot, then you might have a house fuse that has blown or a breaker that has tripped. it is also possible that the cord has a burnt connection at the rear of the unit where it connects to the units block.
if you only have no heat in the oven, then you may have just a burnt out bake element.
Dec 21, 2008 | Maytag MER5775Q Electric Kitchen Range
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
866 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
