Question about Motorola Mobility RAZR V3
V3 razr I have nothing working on the flip except the screens, no smart buttons or earpiece speaker. I just put in a new flex circuit and all connections are tight.
    Brigadier General:
  • 7,752 Answers
Take it and have it checked out.
Posted on Mar 30, 2008
My screen is black i cant hear who im talkin to but they can hear me i cant access my speaker i have a motorola razr v3
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
On the other hand, you said you cannot hear the person you are talking to, the problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Jul 22, 2010 | Motorola Mobility RAZR V3
Black screen on RAZR V3
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jul 02, 2010 | Motorola Mobility RAZR V3
My phone pad doesn't respond??? The only button
Your motorola RAZR V3 cellular phones has a solution,Most V3 versions of phones have one specific problem.which is flex problem.when ever your using your phone and your keypads does not respond,No that is the flex cause the flex is connected from the screen to the keyboard.so you can change the flex of your phone.
Jan 11, 2010 | Motorola Mobility RAZR V3
Motorola razr
Most likely the small flex cable on the LCD screen in the top part of the phone needs replaced. The speaker in the earpiece must be bad and it is soldered to this flex cable. It can be repaired by a cell phone repairman.
May 30, 2008 | Motorola Mobility RAZR V3
V3 never registers when I close it, battery is being wasted!
You forgot to replace a small magnet that goes in the upper right corner of the cover (when closed) next to the screen. Try to put a magnet in the circular hole.
Apr 24, 2008 | Motorola Mobility RAZR V3
V3 razr- battery
you should be able to get it from a mobile service center
Mar 05, 2008 | Motorola Mobility RAZR V3
Front cover buttons not working
has this area been wet at any stage?
Nov 01, 2007 | Motorola Mobility RAZR V3
Razr Ear Receiver Not Working
hi
most prob regarding that matter is lost contact in your earpiece. try opening your phone and check its connection. if connection is good then maybe your earpiece is defective.
if everything is fine then it must be the flex connector have a prob...
try it and inform me what happens...
Oct 15, 2007 | Motorola Mobility RAZR V3
Blank Screens
try reflash the phone or replacing the lcd
Sep 12, 2007 | Motorola Mobility RAZR V3
V3 x problem
the problem is the flex cable.Take it to a technician and for about $15 is will be fix. this is a common problem on v3.
Jul 10, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
