Question about DeLonghi EO1258 - Stainless Steel Toaster Oven with Convection Cooking
Toaster/oven will not come on.
My toaster/oven just stopped working. Now, it will not turn on at all.
  • 2 more comments
  • Anonymous Oct 25, 2008
    my toaster oven just won't turn on. it happened all of a sudden
  • Anonymous Nov 04, 2008
    It was on and pre-heating and then it just stopped. Is there a fuse in the oven that can be changed?
  • sigifdb Jan 13, 2009
    Mains supply tested ok
    Problem is a Sefuse: SF 169E rated at 172 C 10A 250V ID C0565
    This fuse runs from the mains input line thru the thermo control to the timer switch.
    My test shows the fuse as defective; oven has been in domestic use only not even for 3 years,
    Shame on you Delonghi!
  • Anonymous Mar 14, 2009
    worked last night and just stopped working
    Problem Solver:
  • 14 Answers
Its probably broken =[
Posted on Jul 19, 2008
  • Edythe Caldwell
    Edythe Caldwell Feb 07, 2015
    Is that your answer "its probably broken"? My 3 year old son could have answered that question..
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
My tefal avanti stopped working
something had been gone short due to the power socket.let the socket be ok but sometimes due to heavy voltage this could possibly happen.just check if somme parts is burnt ,turned black or smelling foul oudor,or when you on the machine now it passes burning fumes from some where.
Aug 11, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
The toaster oven does not toast. the oven and timer work, though
Your selector switch may be broken if the oven works on selections other than toast.
Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
Oven just stopped working
1-usually it easy proplem
2- check your electricity voltage by testsrowdriver or another good device like radiocasset or voltmeter if you can
May 31, 2009 | DeLonghi XR450 Retro Toaster Oven with...
Dead Delonghi toaster oven
Your timer switch burned out. The timer is manual and will tick even unplugged. Delonghi switches are available at The Gourmet Depot website or search "small appliance parts" for other places that sell the switches.
Mar 23, 2009 | DeLonghi EO1258 - Stainless Steel Toaster...
Delonghi AS690 toaster oven lower element won't turn on.
Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
Mar 13, 2009 | DeLonghi AS690 Airstream Stainless Steel...
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Warning tone?
Have you tried turning the function button to off? This has worked for mine.
Aug 18, 2008 | Cuisinart TOB-30 Toaster Oven with...
Toaster/oven
Could be the timer switch. They will suddenly stop working all at once or work intermittantly. Unless it's a Delonghi you may have a very hard time finding the part you need. If the switch is a DKJ/1-60 you will not find one but there is a Delonghi switch that you can use which you can find at www.thegourmetdepotco.com or www.applianceparts.com . The Delonghi part # is 5218104600 to replace a DKJ/1-60
Mar 05, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
DeLonghi EO1258 - Stainless Steel Toaster Oven with Convection Cooking Logo
444 people viewed this question
Top DeLonghi Toaster Ovens Experts
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Craig Butler
Craig Butler
Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
