Question about DeLonghi EO1258 - Stainless Steel Toaster Oven with Convection Cooking
Toaster/oven My toaster/oven will not turn on. One day it worked fine, and the next? Nothing! This literally happened. It worked fine on Monday and then would not work at all on Tuesday.
  • 1 more comment
  • Anonymous Apr 23, 2008
    First day, the toaster wouldn't work. Second day, none of the heating components worked.
    Didn't know how to do anything. If it's a fuse, where does one get that? or if it's a heating element, where does one get that?
    I believe instructions are available but what about the parts? Mine is a De Longhi toaster oven with broiler. Not a convection toaster oven.
    janlake@pacbell.net
  • Anonymous Jan 24, 2009
    I loved this toaster/convection oven, had it for about 3-4 yrs. and one day it didn't work! Don't know if I should buy another one since it was pricey, or go for a cheaper toaster/oven and replace when it fizzles out.
  • Anonymous Apr 27, 2009
    Same problem.  Less than 3 years old and just stopped working.   They don't make it easy to take this thing apart either.   Ridiculous.   Will try fixing a little more (fuse perhaps) otherwise off to goodwill.
    Scholar:
  • 53 Answers
Could be the timer switch. They will suddenly stop working all at once or work intermittantly. Unless it's a Delonghi you may have a very hard time finding the part you need. If the switch is a DKJ/1-60 you will not find one but there is a Delonghi switch that you can use which you can find at www.thegourmetdepotco.com or www.applianceparts.com . The Delonghi part # is 5218104600 to replace a DKJ/1-60
Posted on Jun 08, 2010
  • Jose Pizarro Aug 20, 2013
    mY TOASTER OVEN TURN ON AND WORKS IN THE OTHER BUTTONS EXCEPT ON ROSTISSIERE
How can I troubleshoot my kitchenAid toaster oven? The timer works but the light will not go on, and it will not heat up on any setting.
The heating element went bad. The manufacturer makes it impossible to open the unit and doesn't sell parts - the lawyers told them it is too risky to let consumers repair toaster ovens.
Sorry.
Feb 25, 2015 | KitchenAid KCO222OB Countertop Oven
My tefal avanti stopped working
something had been gone short due to the power socket.let the socket be ok but sometimes due to heavy voltage this could possibly happen.just check if somme parts is burnt ,turned black or smelling foul oudor,or when you on the machine now it passes burning fumes from some where.
Aug 11, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
Black & Decker toaster oven won't work
We've had many of these over the years...they seem to run along just fine, and then, one day, they quit. There is no fuse, but if it's the only thing plugged into that wall outlet, the one thing you might check is the circuit breaker on that line. To be sure, plug a lamp into the socket just to make sure you're getting electricity out of the wall.
Sorry to say, it may be time to purchase a new unit.
Sep 14, 2017 | Applica CTO6301 Toaster Oven
I have an Oster toaster oven 6260. Looks very clean. My son got it at a garage sale. Day 1 worked fine. Day 2 plugged in doesn't go on no matter what knobs are turned. Tried different outlets. ...
It is possible that the controller switch or the trigger is absent so that the coils do not get the power from the mains circuit. it will be best if you can remove the mains plug and start tracing with a multimeter in continuity range( ohms) so that the connection is confirmed.
Once it is found that the switch does not switch on the power or has lost the connection even when it is put to the ON position then you can salvage the swittch from the older toaster to be fixed on.
If the coils have opened it can also be checked with the meter , specially since you have one top element working.
So using the inventory of the two toasters you can get one working.
Jun 17, 2011 | Toaster Ovens
I need the Easy Installation Step-by-step mounting instructions and Pre-sized mounting template for Black & Decker TROS1000 SpaceMaker Digital Toaster Oven. Thanks
For a manual you can go to blackanddeckerappliances.com. Then under the Customer Care tab click manual and follow with info needed for your SpaceMaker. That won't give you the template so try the phone numbers here for Black and Decker to ask them.
Phone Number: 800-738-0245
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
1-800-231-9786 Monday - Friday 8:30 AM - 8:00 PM ET
Mar 25, 2011 | Applica TROS1000 Toaster Oven
The knob for the oven temp control broke and needs to be replaced
www.bizrate.com/toasterovens/toastmaster-cool-wall-357-toaster-oven
Mar 15, 2009 | Toaster Ovens
Krups fbc2 toaster oven cuts off while toasting
returned it to vendor and asked for exchange.  decided no way I should fix it after less than 5 days of use.  Curious if others have encountered a similar problem.
Sep 27, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Light and oven does not turn on.
:-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
Oct 29, 2007 | DeLonghi EO1238 Toaster Oven with...
DeLonghi EO1258 - Stainless Steel Toaster Oven with Convection Cooking Logo
745 people viewed this question
Top DeLonghi Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Craig Butler
Craig Butler
Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
