Question about Motorola Mobility RAZR V3
V3 razr- battery
What is the battery located in the flex circuit near the earpiece speaker, should it be replaced when replacing the flex circuit and where can you get it?
    Brigadier General:
  • 7,752 Answers
You should be able to get it from a mobile service center
Posted on Mar 30, 2008
My screen is black i cant hear who im talkin to but they can hear me i cant access my speaker i have a motorola razr v3
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
On the other hand, you said you cannot hear the person you are talking to, the problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Jul 22, 2010 | Motorola Mobility RAZR V3
I cannot hear when I dial out or answer the phone unless it is on speakerphone
have your earpiece replaced, it is located at the topside along with the lcd, it is a bit tricky to replace that cos it is mounted with the lcd itself, nif it doesnt do the trick try repalcing also the flex assembly
Nov 10, 2009 | Motorola Mobility RAZR V3
Cant hear incoming voices unless i put it on speaker. Can hear rings and all phone bells and whistles though. just not earpiece volume for incoming calls unless on speaker
this sounds like a broken earpiece speaker you might be able to find a replacement one on-line and replace it or if its still under warranty send it back in and get it replaced
Sep 25, 2009 | Motorola Mobility RAZR V3
My motorola v3 razr cell has no sound thru earpiece cannot hear unless you turn on loud speaker help please
That means your earpiece speaker is out. It could either be damaged or just dirty. The easiest way is to file an insurance claim. But if you are good with electronics you can take it apart and replace the speaker. However on some of the V3 models the earpiece speaker is a part of the LCD and cannot be individually replaced.
Feb 03, 2009 | Motorola Mobility RAZR V3
Motorola razr
Most likely the small flex cable on the LCD screen in the top part of the phone needs replaced. The speaker in the earpiece must be bad and it is soldered to this flex cable. It can be repaired by a cell phone repairman.
May 30, 2008 | Motorola Mobility RAZR V3
Can't hear when the speaker is off
earpiece and speaker are separate so in that case the earpiece is broke and u sould have'it replaced to a cellphone service
Apr 21, 2008 | Motorola Mobility RAZR V3
V3 razr
take it and have it checked out.
Mar 05, 2008 | Motorola Mobility RAZR V3
Razr Ear Receiver Not Working
hi
most prob regarding that matter is lost contact in your earpiece. try opening your phone and check its connection. if connection is good then maybe your earpiece is defective.
if everything is fine then it must be the flex connector have a prob...
try it and inform me what happens...
Oct 15, 2007 | Motorola Mobility RAZR V3
Can't hear through earpiece
If the phone is under 1 yr old I suggest finding the nearest Motorola service center as it is under warranty. If its not covered you could replace the speaker yourself, although would require a small amount of soldering or replacing the entire LCD module which could be expensive. Let me know if you decide to give it a try I can help w/ disassembly. Good luck.
Sep 05, 2007 | Motorola Mobility RAZR V3
Distorted Sound on Speakerphone
you need to have the speaker replaced.
Aug 06, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
