Question about Car Audio & Video
Problems with bass when turning up radio
If I leave my radio volume low like around 10, the bass sounds fine. When I turn the volume up say around 20 or higher, the bass goes way down and it is distorted. some people said it sounds like a burnt voice coil but I am not sure
  • Anonymous May 28, 2008
    when radio is low sounds good but once you start to push the volume the woofer makes a rattle noise.
I had the same problem:
You probably have the type speaker with a dustcap that says EARTHQUAKE in big letters from left to right.
If you look on some video's on you-tube, they have a different dustcap with a kind of star-shaped shape in it.
You have the old type and if you use it in a sealed enclosure which is too small, something that is glued underneath the dustcap comes loose and starts rattling. Contact Earthquake and ask for the updated dustcap which doesn't have that glued part and repair your speaker or let them do it.
Posted on Aug 01, 2008
  • LSK_FTR Aug 01, 2008
    Another problem can be that the speaker sucked up a wood splinter or something which is sucked into the coil. Just blow some high pressured air in the bottom hole to blow it out. But if you have the dustcap with EARTHQUAKE written in the center from left to right instead of the star shape in the dustcap, most likely your speaker needs the updated dustcap.
    Scholar:
  • 52 Answers
You might have blown a speaker, or more than one. Check this first before you start trouble shooting the radio.
Keever
Posted on Mar 06, 2008
Hey! I have a problem with my sony MDR-RF81 headphones....when the bass is to loud...there volume is droping...when I listen to skirllex for example...the volume is high or low...but when the bass...
Hey there, the problem with your sony is not a hardware problem, the headphones are completely fine, its the amount of bass you are putting into the headphones, there are two solutions to this, if you're using a mobile device (Apple, android etc...), go to your app store and download an equaliser e.g poweramp, with this, you can adjust the sound going through to your headphones using the built in equalizer (usually 5-10 bands, research this if you have no knowledge of equalisers), you can use this to turn down the bass frequencies in the sound, or the only other thinkable options are if you are already have an equaliser in use, turn it down, because putting all of the bars to the top makes the sound horrible, research on some suggestions for equaliser presets (another word for equalizer settings), or just turn the volume down.
the reason this happens is because bass naturally overpowers treble, and if it is too loud, the treble and mids will be significantly quieter, headphones are a menace for this, so all you have to do is tweak the sound a little (using an equaliser) to find that perfect balance between the different elements of sound.:-) :-)
Hope this helped mate :-) :-)
Jan 10, 2013 | Sony MDR-RF810 wireless headset SONY
Amp slow to kick bass in.
it sounds like you havnt got the memory live conected on your hea duit or it is conected to an ignition live this is no good it needs to be conected to a permenent live to ensure the memory has power at all ties of it coulb be that the amp needs adjusting for low volume use
to set up a sub you turn up the volume to the required level then adjust the amp acordingly hope this helps ben
Oct 11, 2009 | Alpine MRP-M650 Car Audio Amplifier
I have a 1999 Chevrolet Suburban with the factory radio. The radio works fine but when I put in a cd and turn the volume up some, it just stops playing for about 20 sec. It will come back on at a very low...
sounds like your popping the breaker, after a while your speakers will go, theres just too much power for it to handle, take it to a car audio store and get them to test it, you may need new speakers
Jun 20, 2009 | Car Audio & Video
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Aug 28, 2008 | Sony STR-DE445 Receiver
Speakers cut off when bass goes up...
sounds like you hava a load problem.if your'e running your woofers at 1ohm,make shure your amp is 1ohm stable.....
Jul 03, 2008 | Car Audio & Video
BOOM BOOM BOOM
The Bose engineers in their "infinite" wisdom developed a $300 radio with no, that is NO, tone control. This means the only way to tune bass response is to reposition the Wave radio itself. If you put it in a corner of a room, it will produce the most bass. If it is only against one wall, not so much bass. To reduce bass response to a minimum, you would have to suspend the device from a wire in the middle of the room. Good luck. I would never buy a radio without a tone control; I literally inherited by Bose Wave Radio and use external speakers which do have tone controls.
Jun 10, 2008 | Bose Wave Radio
Bose Wave System CD 2000 FM volume much lower cd stops if volume higher.
sounds like a loose cable from the control bard to , some one will have to open up to fix, i recommend bose do that for you,
as for fm volume, the same could be the cause as the fm antenna coudl be disconnected, ( are you using an external FM antenna ?)
Feb 29, 2008 | Bose Wave Radio
it might be that your wires from your amp to your subs are too thin. since they were relatively new the first three months, they were probably undamaged, but after pushing them too much, they probably have broken wires, and can't get enough power to the subs when turned up, i suggest getting thicker wires before investing in a capacitor, it could save you money.
Mar 21, 2007 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Car Audio & Video Logo
125 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
