Question about Kenmore 22812 Bagged Canister Vacuum
No power to head of Kenmore Progressive canister vac
I have a Kenmore Progressive canister vac (model # 116.22812201). When I turn it on, it seems like it's sucking up from the head, but no lights come on and the brush doesn't roll. In other words, if I had hard wood floors, it would be great, but it doesn't do anything for the carpet. It seems like there's no power getting to the head although there is suction. Any help would be greatly appreciated! Thanks!
  • 1 more comment
  • Ben1063 Mar 06, 2008
    I have the same problem. The vacuum portion works but it seems the head is getting no power
  • jcbandari Mar 06, 2008
    Tried the reset button...nothing. I think maybe the problem is at the base of the hose. Can I replace the plastic piece that holds it in place, so should I take it to Sears? Thanks!!
  • Anonymous Mar 26, 2014
    No power to carpet attachment. No power to led light on telescopic wand
The extension wands are defective and have trouble with their plug connectors on each end. The power head has a reset button on top right but no lights mean no power which means the wand isn't connecting the power to anything.
Sears has a new replacement -- too bad it isn't recalled so you could get it for free ($106.59 + tax + shipping). 2nd sweeper -- same problem.
1st sweeper: I just took needlenose pliers and pulled connectors out a little further (Too bad I can't seem to make the 2nd sweeper work with this easily. It might be one of the connectors or the wiring harness inbetween with a break.) Can't buy the wiring harness for this or connectors, just the wand.
If anyone has a working wand you want to sell me email me at hiwhatsnew@hotmail.com. Thanks!
Posted on Jun 12, 2008
  • Scott Goldman
    Scott Goldman May 31, 2012
    The connector at the top of the extension wand has a fuse which can go bad.In my case the connector stopped working even though the fuse was intact.The replacement part # is 8191782.Not easy to disassemble wand to replace connector
  • Debbie Jan 18, 2013
    How did you disassemble wand? My husband has been unsuccessful. Thanks.
I'm NO help but maybe you can enlighten me. Where IS the reset bugtton? The manual was lost in a move OR address to request a new manual. Thx
Posted on May 28, 2008
    President:
  • 1,673 Answers
Most of the Sears power heads have a reset, did you push it? There are several reasons why the power head won't work. Switch in the handle is bad, the plug at the end of the hose is pushed in too far to make contact with the cord from the power head, if that is the case, then a plastic piece tjat holds in from doing that has broken off. Could be the cord itself or a bad motor.
Posted on Mar 06, 2008
  • Lauren Junge
    Lauren Junge Mar 06, 2008
    Unless you know how to take the hose apart, then you maybe should take it to Sears.
2 Suggested Answers
renevacdoc
  • 84 Answers
SOURCE: Kenmore Progressive Canister Vacuum -Model 116 22812200.
hello... you might want to try checking the elbow or neck of the power nozzle for blockage. Remove the wand from the head and look through it. Also look through the wands . If there is no blockage, maybe there is a problem with you nozzle. Reattach all the parts and turn on the machine, turn on the power nozzle. Can you hear the other motor start? If so, check to see if the belt is turning. If it is not, and you definitely hear the secondary motor, then you need a belt. If it doesn't make any sound then, with the machine still running, press the button on the upper part of the power nozzle, this should reset your motor. I hope these tips helped ya, let me know, by giving feedback when asked. thank you, Rene (The Vacuum Doctor)
Posted on Nov 10, 2009
My husband accidentally dislodged the belt on my kenmore canister vac. how can we disassemble the head to put the belt back on?
There should be 4-5 screws on the bottom of the brush assembly, remove them and you will see the brush and belt, remove each end of the brush assembly they should lift up and out of the housing,and either replace or reailine the belt on the motor side of the housing.
Aug 25, 2014 | Kenmore Progressive Canister Vac Cleaner...
How do I disassemble a Canister Vac Model 116.21714. extension wand ?
Sadly, there does not seem to be much help available for this. Sears wants $100++ another $30-40 shipping to have UPS take it and may be fix it. If you do not want to pay the fees, you will still have to pay $50 to get it back. Sears service shops will not fix vacuums. What the heck?!
Apr 24, 2014 | Kenmore 23913 Progressive PowerMate Bagged...
My kenmore progressive canister vacuum turns on only if the hose is attached to the floorwand. It seems that the canister motor is not working because I can't hear anything coming from the caniste
If the floor wand is powered, there may be an electrical connection that is broken when the wand is disconnected. This is part of the design, not necessarily a fault
Jan 05, 2013 | Vacuums
After using the kemore vac it shuts off depending on how I m pulling on the tube part, it seems like there's a short where. Any help Thans,Steve the canister connects to the suction tube
This is a very common problem on your series of Kenmore canister vacuums. It is the result of a part inside the handle of the hose (where you would have your hand) which has broken and no longer properly supports and keeps in place the electrical receptacle that feeds electricity from the canister to the power head. If you provide a model number, I can provide an exploded parts diagram which will show you the likely culprit.
Dave
May 14, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister vac 25614
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Feb 13, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Open power cord housing on kenmore 116 vac
You can go to the Sears Parts Direct website and type in your Model number. It will return both an exploded view and parts list, with pricing for replacement parts. You can also order from them, and they can tell you stock status as well.
Jan 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 22812 Bagged Canister Vacuum Logo
789 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
