Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
I have a Bissell powersteamer proheat. The problem is that the unit will no longer spray water/cleaner out of the bottom of the unit.
    President:
  • 1,673 Answers
Check to see if water will squirt out of the hose, if it does, then take the handle apart, the heater may be clogged. Once you get to the heater, take off the 2 water lines, dig out the clog, try to blow thru the heater to make sure it is open, then put back together. Otherwise it could be the belt, pump, seal not in place on the bottom of the tank or a clogged water line.
Posted on Mar 06, 2008
Bissell PROheat 2X No longer sprays water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Oct 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water won't spray out of the cleaner
If it won't dispense water then that means that the pump belt needs to be replaced. Here is the belt you need:
Bissell Proheat Pump Belt
May 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Bissell Proheat Powersteamer Plus isn't dispensing the cleaner or water, what's the solution/
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Apr 15, 2010 | Bissell 1699 ProHeat Clear View Upright...
Not spraying or picking up water
heatman101
bmv,
Feb 02, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Feb 25, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1698 Powersteamer no spray
If it seems like the tank does not fit in securely, the round gasket that goes around the valve at the bottom of the tank may have come off and actually be in the hole in the bottom of the vacuum base. It looks like it belongs there but you can pull it out with some needle nosed pliers. After you remove it, put it around the valve on the bottom of the tank, then it will fit into the hole again and everything should seal correctly. Mine was not spraying and would not suction well. figured this out and now it works great again.
Apr 16, 2006 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
227 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
