Question about Motorola Televison & Video
Tv remote src350a motorola
I have a next level gateway DSL tv system I have a tv remote motorola src350A remote control I want to change the tv input station. from 13 to 11. I also need to get the remote to control the tvthat it is working with. different modles. How to program the remote to the gateway. keys to punch for the remote. thank you d stark
Turn on tv press and hold the select button and mute. Hold until LED button lights up. Press up arrow, release, press and release. The light will blink each time you hold the button. When tv turns off press select to store the code. Changeing the stream press and hold mute and select release when light comes on. Press and release the A key. Enter 0 ro run stream one enter 1 for stream 2 and 2 for stream 3
Posted on Jul 09, 2008
Sylvania 32 inch LC320ssx
It seems that the set itself changes inputs. Place it remote control away from the vicinity of the tV. and check. If it does the same, do a hard reset next. To make it a hard reset, unplug the TV from AC mains wall socket, and replug it back after 10 minutes or so. If these do not help you, be sure that the main system control memory IC to it is faulty and should be replaced.
Jun 05, 2013 | Televison & Video
How can i change the video input on my rca truflat tv 27F520T without the remote
As there is no Menu button on its front panel. you can't select inputs to this TV without a remote control.
Jun 05, 2012 | RCA TruFlat 27F520T 27" TV
Tv remote code.need the code to work my gateway T.V. with motorola rem,ote control
It's better to specify the particular model so i can easy help you find codes on your remote control,any way,i'll give you this link and just look for the right model of your TV and download it's manual or code.
CLICK ME
Good Luck...
Sep 22, 2011 | Motorola Televison & Video
Dont have remote to model 26gt625 and are wondering how to change to video 1 or 2
I have this same TV and the input cannot be changed with the remote control. Some older universal remote controls can be used with TV. With the newer remoter controls the GE codes do not work and one must use the code scan search and hope that one of the other generic TV codes works (they usually don't). The motorola DRC800 universal remote that comes with some cableboxs will work with this TV when performing the universal code search. Good Luck. I'm junking this old TV and getting a new one as soon as I can afford it. (I bought new in 1994).
Sep 13, 2010 | GE Televison & Video
When I switch from watching movie to watch TV on my Harmony 700 I get a picture on the TV that looks like the menu for the AV receiver and can't get back to a TV picture although I do have sound. I...
Hi, I would like you to try changing the input selection method for your TV. I suspect that some of the commands are incorrect.
1. In the software, click 'Settings' next to the icon for your TV.
2. Click 'Adjust Inputs'.
Make sure you select the method that best describes how the original remote changes inputs. Dont pay attention to the brand names. Also, make sure that the input list is EXACTLY the same in the software as on the TV itself.
Once you have done all of the input setup, update the remote and try it out again.
Let me know if that helps :)
Feb 01, 2010 | Logitech Harmony 700 LCD Remote Control
TV input
it is likely that your tv is interpreting a random button on your remote as a signal sent for it to change inputs, next time this happens turn the tv off and back on and note what comes up on the screen, for example video 1,
Aug 04, 2008 | DISH Network IR Remote Control
Tuner problem
your problem is in the system control section of your tv. please check 1 supply to systemcontrol ic or loose contact. 2 supply or loose contact in tunning ckt of tuner (33v zener line) 3 aft ckt loose or defrctive. 4 loose button on remote &front panel of tv. 5 memory ic. 6 system contro ic. I think this will help. good luck . 4 system
Sep 28, 2007 | Sharp 32F640 32" TV
Tuner problem
your problem is in the system control section of your tv. please check 1 supply to systemcontrol ic or loose contact. 2 supply or loose contact in tunning ckt of tuner (33v zener line) 3 aft ckt loose or defrctive. 4 loose button on remote &front panel of tv. 5 memory ic. 6 system contro ic. 7 check for loose contact in tuner. I think this will help. good luck .
Sep 28, 2007 | Televison & Video
How to set a static IP address in Windows behind a Linksys Router
Windows 2000/XP 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window appears, input control ncpa.cpl into the ?Open? field. 3. After the ?Network and Dial up Connections? or ?Network Connections? window opens, right click on the Local Area Connection or Wireless Network Connection which controls the connection to the router. 4. After the ?Local Area Connection Properties? or the ?Windows Network Connection Properties? window appears, click on Internet Protocol (TCP/IP) then click on the Properties button. 5. Once the ?Internet Protocol (TCP/IP) Properties? window opens, change the option from ?Obtain an IP address automatically? to Use the following IP address. Set the options under ?Use the following IP address? and ?Use the following DNS server addresses? to the following: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 * Default Gateway: 192.168.1.1 * Preferred DNS server: 192.168.1.1 6. Click OK then OK or Close. Windows 98/ME 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window opens, input control netcpl.cpl into the ?Open? field, then click on the OK button. 3. When the ?Network? window opens, locate the TCP/IP for the Wireless or Ethernet adapter in the PC, and click on it. Once it?s highlighted, click on the Properties button. 4. Change option from Obtain Automatically to Specify and input: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 5. Click on the Gateway tab, and input 192.168.1.1 into the ?Default Gateway? field and click the Add button. 6. Click on the DNS Configuration tab, then go to the ?Host Name? field and input Computer, then go to the ?DNS Server Search Order? field and input 192.168.1.1 then click the Add button. 7. Click OK then OK once more, then windows will prompt for a restart.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Televison & Video Logo
2,076 people viewed this question
Top Motorola Televison & Video Experts
Jaime Hernandez
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
