Question about Samsung HCM4215W 42" Rear Projection Television
Samsung 42" rear projection HD tv issue
Ok man , thanks for all your great responses. after doing what you said , there is still no reset factory convergence, and the guy i talked to at samsung said this is a DLP TV and not a CRT tv.. im confused because i thought the CRT PCB attached to the bottom of that HUGE CRT tube that i changed might indicate its a CRT TV and not a DLP TV LOL....
i guess ill try and install the new board tomorrow when it gets here and hope for the best , the convergence is SO close to right even with the IC board unplugged that im "hoping" that it auto resets the convergence to factory tolerance. im at a loss i feel like i have gotten a half year one of a kind TV when the manufacturer tells me its a DLP and it is Obviously not!
i guess what i really need to know is:
1) how often are these IC/main convergence boards shipped bad.
2) does the actual convergence board that attaches to the chassis with the one screw have to be connected securly? as in does it gain ground from the chassis in any way? if so i am going to use dielectric grease and a wire brush to make better contact to the chassis.
3) how long would it take to blow the IC's before i can get the convergence set and lastly..
4) should i even use perfect focus or actually set each cross hair for each color (only has red and blue that you can change) THEN use perfect focus.
Thanks for tolerating my n00bishness and helping me out man ,
Joshua Borges
  • duncyn Mar 06, 2008
    thank you
    As i speak the TV is on and working GREAT !!!! its got some convergence issues but thats cause i messed around with the yokes out of desperation after the original BOOM. no its a TV again!
    well i wanna thank you fixya.
    the error i get now though is no sensor data for perfect focus. i guess im happy that its not a 13" TV sitting ontop of the 80" entertainment center LOL
    its wierd though cause the perfect focus worked once before i hit the Mute,1,8,3. since doing mute,1,8,3 it dosent work , but i can still use Mute,1,8,3 to do it all over
    thanks again
    Josh
    Sergeant:
  • 395 Answers
1 they are either rebuilt or a defective returned to stock accidentaly
2 yes securly attaching it helps the heatsinks keep even cooler. no you don't need heatsink grease.
3 if the tolernace is very far out of wack then it woun't take long befor they blow. once you have instaled the new board turn on the set enter mute,1,8,3 then perfect focus on the remote let it do it's thing then shut off the tv and resart the tv and press perfect focus again.
Posted on Mar 06, 2008
MY SAMSUNG TV MODEL HCM5525W 55 IN IS STUCK IN TIMER MODE AFTER IT WAS UNPLUGGED. DO YOU HAVE ANY SUGGESTIONS TO FIX THIS PROBLEM?
You need to reset the tv to factory mode by pressing a code with the tv off,,,, mute--182--power and wait to see the menu appears on screen chose *reset to factory* press ok and wait until process done, them turn it on .
Dec 18, 2010 | Samsung HCM5525W 55" Rear Projection...
pico fuses are those small on board fuses, usually soldered into place, that protect important parts of the board.
Feb 26, 2008 | Samsung HCM4215W 42" Rear Projection...
States that its HD Ready when Sky came to install HD box engineer stated that it wasnt so need the cable for it and why was I told that it was. Wouldnt have brought the t.v. if I had known. Would...
Seriously man, went to craigslist and bought 2 HD cables locally for $5 each when they're $40 in stores. people make them and sell them easily and they worked great. craigslist.org and go to your city under electronics and type in HD cables. You'll be amazed.
Oct 19, 2009 | Samsung HCM4216W 42" Rear Projection...
When I turn my rear projection television on, the
Ur power board ic converter board it dead.
U know about a little about electronic the plug
go direct to the board order that board or repair man cost part labors about $575.
Aug 13, 2009 | Samsung HCM422W 42" Rear Projection...
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
TV set shuts down
3.9 ohm 2W
They are parallel in circuit and measure around 2 ohms when ok. Check the fuse associated with that circuit. FD101S 3.5 A
easyab
Aug 23, 2008 | Samsung HCM4215W 42" Rear Projection...
How do I do a factory reset?
With the tv off, press on the remote Mute,1,8,2,Power
This enters the service menu.
The factory reset option is in there.
Aug 06, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung LCD tv
Hi Tracey! Thanks for the email! I repair DLPs I will see a man Monday who repairs Samsung LCDs and I will let you know what he says. Chat with you soon!
LeAnn
Mar 23, 2008 | Samsung HCM4215W 42" Rear Projection...
Red and Blue Lines
Hi, You cannot exactly reset the whole TV, but you can press the PMode button on your remote control a few times to cycle through all the picture modes (Dynamic, Standard, etc.) in order to factory reset each picture mode.
Oct 11, 2007 | Samsung HCN4226W 42" Rear Projection...
Black Lines
yea my 50 inch hdtv is the same. i contacted the samsung number since its still under warranty and they said i need a new engine or something for my tv that they would come out next week to fix it. i guess it happens alot. but they said once itf fixed it probably wont happen again. so u should call them
May 11, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
144 people viewed this question
Jerry Greenberg
Jerry Greenberg
