Question about Hitachi 53SWX12B 53" Rear Projection Television
Amps and resistors
I replaced the 3 resistors and the convergance amps on the Hitchi 53 in ultravision (rear projection). But I noticed a problem when I soldered the amps in place that I bridged one of the solder joints, I plugged the tv and nothing happened so I rechecked and desoldered the bridge joint and still no picture. Are there fuses that go when this happens or is the amps no good again. ANY HELP Thanks
  • Hitachi Master
  • 8,617 Answers
The IC is no doubt bad due to powering it up with the solder bridge. may possibly need entire convergence board unless you have the service manual and troubleshoot it.
Posted on Mar 05, 2008
Hitachi ultravision rear progection converge
If the convergence is so far out that you cannot adjust with your customer access menu then You will probably need the convergence ICs replaced & possibly a fuse or resistor or 2. Then a complete convergence will be necessary & I HIGHLY recommend having a professional technician perform this task.
May 23, 2014 | Hitachi 53UDX10B 53" Rear Projection...
I have i hitachi ultravision that has a green line and makes double faces
May 23, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
Need help with Convergence board.
Sounds like the convergence has failed which is a common problem with rear projection TV sets. This video has more details on this and info on how to fix it,
Dec 28, 2011 | Hitachi 53UWX10B 53" Rear Projection...
I have a hitachi ultravision 53in fdx01b im experiencing a blue doublevision please help.......
sounds like the convergence circuit has decided to quit working..  hitachi uses convergence output i.c.'s for this in the circuit.  one is probably bad.  suggest replacing both though..
Jul 30, 2010 | Hitachi 53FDX01B 53" Rear Projection...
PT-53WX53G still shutting off-3 blinks
have you checked the 2.2 ohm 2watt resistors? If the led blinks three times the resistors will almost always have at least one that will be blown and need replacement.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Hitachi 53swx01w HD rear projection tv was fine until i ran the magic focus. now i have blue & yellow ghosts.
Ur convergence is dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all the resistors.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 17, 2010 | Hitachi 53SWX01W 53" Rear Projection...
I have a hitachi ultravision and the blue is off center.
your convergances amps ics have failed and need to be replaced alone with the 2 burnt resistors you will find then run magic focus
Nov 30, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Picture problem
the problem is convergance the amplifiers (two of them) have failed. posibly some resistors or pico fuses are bad along with them. they need to be replaced then realiegn the convegance. the cost of repair may be $200.00 to $350.00 depending on the tech you get.
Feb 08, 2008 | Hitachi 53SWX12B 53" Rear Projection...
Hitachi Tv
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 22, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53SWX12B 53" Rear Projection Television Logo
48 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
