Question about Sampo PME-42V3 42 in. Plasma Television
Relay clicks then shuts off - no picture/ no osd
This 42" tv will not power on. Manufactured in 2000, model# pme-42v3/chassis# c-42p. Please assist me with schematic or test points - tv is open now and I have verified all gme fuses are good, connections are secured tight and i have voltage to all pcb's. (tv tech:)
Nic Stevens
808-223-9358
  • blackhat212 Mar 11, 2008
    thanks for your reply. I may not have communicated properly. This is a defective pcb/component as I have already eliminated loose connections, blown fuses and signal input. What I need is test points to confirm poper voltages on all pcb's and/or the service diagram. I am a tv tech and I need some way to isolate the defective pcb so I can order the correct part. Thanks for your assistance. Please contact me as soon as possible.
    Nic Stevens
    808-223-9358
    Master:
    Sergeant:
  • 462 Answers
I too am a v mechanic, but will try to solve ur problem, have u checked for black out or burned elements in the board, also check the CRT else remove it clean the contacts and put it back. Check for continuity in the wirings. Also see if the capacitors in the power board arefine and working.
Thankyou
Posted on Mar 23, 2008
    Guru:
  • 1,894 Answers
Sir
relay click off means there some kind of short circuit in your main board.
  • dewan nafees ahmed Mar 23, 2008
    Main support number 1-888-373-4368
    Email support info@regent-usa.com
  • 818 Answers
No picture
  1. Power cord disconnected.
  2. Power not switched on.
  3. Improperly connected signal cable.
  4. Monitor in power save mode.
  1. Connect power cord.
  2. Turn the power switch on.
  3. Connect the signal properly.
  4. Press any key on computer.
Posted on Mar 05, 2008
Whats dvi in rgb in
Digital Video In and Red Green Blue in?
Dec 12, 2010 | Sampo PME-42V3 42 in. Plasma Television
Can i just hook up a dvd home entertainment center.i need instruction on how to do it
Hi, I am sure we can help, but please provide the system number and make so we can check for wiring schematic.
Dec 03, 2010 | Sampo PME-42V3 42 in. Plasma Television
Just clicks when powered on
Check for the power supply. Need to be replace.
Nov 01, 2010 | Sampo PME-42V3 42 in. Plasma Television
Need universal remote control code for maxent 42" plasma tv?
I hope that you have gotten this resolved, but if not, or if you have any other questions, here are the codes and some simple steps to run through.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
246
730
746
Becki Barned
DISH Network Customer Service
May 17, 2010 | Sampo PME-42V3 42 in. Plasma Television
Unable to hook up my ''Dish'' cable to the TV
If the cable comes from the dish,then unless you have a freesat tv that will not connect into your tv.The cable from a dish normaly connects into a sky box or cable box.You need a cable from an aerial to connect into the tv.
Nov 11, 2009 | Sampo PME-42V3 42 in. Plasma Television
Rca projection tv has sound,no picture or OSD
The 169 is an old chasis but a good one. Many chronc problems can cause these symtons. No high voltage because of bad flyback, or HV spitter defec is the most likely, but there are chonic caps that fail in the power supply as well. This problem will most likely need the assistance of a qualified service professional.
Feb 10, 2008 | Televison & Video
Got a 42 sampo plasma tc, no picture
Howzit Brother.
I had the same problem, but managed to repair it myself! There is no need to purchase a new
Power Supply! You can service the faulty PCB yourself, or give it to a Tehnician to service for you.
If you want to try service to yourself, here is how,
On the PCB marked QPWB11326-1B-4 you will need to do the following<
Replace the following Capacitor's, CS704(Most important one), CS705, CS706, CS707, CS708, CS713, CS715.
Replace the TOP210PFI IC marked ICS02
Replace the PC123 OPTO marked ICS03
Replace the TL431 Shunt Regulator marked ICS04
This solution should work! email me on engineering@elektroniktechnisch.co.za if you have any other requests!
Gavin Burger.
Jun 12, 2007 | Sampo PME-42V3 42 in. Plasma Television
Sampo PME-42V3 42 in. Plasma Television Logo
235 people viewed this question
Top Sampo Televison & Video Experts
Starnley Johnwells
Starnley Johnwells
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
