Question about Nintendo Wii Console
Wii' power light is on but, wii dosent turn on.
  • newmara Mar 05, 2008
    wii' light power in on but wii not work.
    Sergeant:
  • 349 Answers
If you have not done so already, press the reset button , ensure your tv is set to the correct AVI channell & the disc is inserted.
good luck
Terry
Posted on Mar 06, 2008
Wii console won't turn on after a power surge. Had it plugged into a surge protector. Is there a reset button?
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that do-sent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
Aug 01, 2010 | Nintendo Wii Console
Wii wont turn on. the red light thet indicates it is off isnt on. the remotes work, and the system is all pluged in
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that do-sent work, try turning it on with one of yourwiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
Jul 21, 2010 | Nintendo Wii Console
Will not turn on. System will not turn on.
Thank you !!
Jul 20, 2010 | Nintendo Wii Console
My wii will not turn on. how can i fix this.
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that do-sent work, try turning it on with one of yourwiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work.
Thank you !!
Jun 22, 2010 | Nintendo Wii Console
I have my console plugged in.. and it worked just a few days ago. but now the lights wont even turn on.. HELP!
Thank you !!
Jun 21, 2010 | Nintendo Wii Console
Wii console is not responding
Thank you !!
Jun 18, 2010 | Nintendo Wii Console
Wii wont turn on
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that dosent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
May 20, 2010 | Nintendo Wii Console
Will not turn on
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that dosent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not syncronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work.
May 14, 2010 | Nintendo Wii Console
My wii won't turn on
May 13, 2010 | Nintendo Wii Console
My wii works but my controler dosent show up on the screen but the buttons work i need help
Usaully,
I don't know about the Wii but I know what happens with the light on the Wii
Green - The Wii Console is on
Yellow - You are connected to Wiiconnect24. It's harsh not to keep the "Yellow" light on because it could overheat the Wii Console. So if it's "Yellow", put your finger on the "Power" Button and keep it there for a long time. When you push it, it will start with Yellow then turn to Green then keep the finger there for a while then will turn to Red
Red - The Wii Console is off
Blue - You are connected to Wiiconnect24. When it turns Blue, It means you are getting a message from the Wii Console or on Standby Mode
Feb 06, 2010 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
