Question about SanDisk Sansa e250 MP3 Player
Won't charge My mp3 will not charge. When I plug it in it says connected on the LCD and arrows are moving from the the mp3 to the computer. It's been charging all day and when I unplug it it goes dead. NOTHING....what's the deal? HELP PLEASE..... Helen
  • tenaj Mar 06, 2008
    I posted on this site yesterday didn't egt an answer back cannon charge MP3 player when plugged to computer/can't delete songs not sure how to do it lost directions help
  • 8,596 Answers
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Posted on Apr 08, 2008
How do you charge the delstar ds 821, & down load music?
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Mar 08, 2012 | Audio Players & Recorders
My SanDisk clip mp3 won't turn on at all.it only charges when plugged up to a computer
Disconnect the player from the Computer then press and hold the Reset button on it for 30 seconds to reset all the settings to the factory default.
Then, connect the player to a computer to charge it completely. Once the player is charged sufficiently then try turning it ON.
If the MP3 player still doesn't turn ON then the LCD screen is required to be replaced.
Nov 07, 2009 | SanDisk Sansa Clip MP3 Player
Battery level shows about half. Charging arrow doesn't show.
Try a different usb cable or mabey the actual usb port
Jul 09, 2009 | SanDisk Sansa e250 MP3 Player
Rizone 32gb. Only charging to 3 bars instead of 4 and this takes hours and hours. Can't find shuffle setting and can't drag and drop music. On screen it shows as gone in but when i check player music has...
To charge your player, with the player on OFF, connect it to a computer or other charging device. Then, after everyting is connected, then turn your player to ON. (For some reason, my player doesn't charge if it is already ON while being connected to the computer or other device.) It will charge.
This is the solution that I use for the music. Connect you player to the computer. Turn it ON after being connected. Go to FILE NAVIGATIONN. Copy your music there. (not in any forler, but as a separate entry in FILE NAVIGATION) Next, disconnect your player from the computer. (Use the SAFELY REMOVE HARDWARE feature for this.)
On the player, there is a PLAY button (NOT THE ONE MARKED "M", BUT THE ONE WITH THE RIGHT FACING ARROW WITH THE TWO BARS) next to the volumn button. After going into the FILE NAVIGATION menue, scroll down to the song(s) and/or music you want to move. Click the song using PLAY. You will see three options: MOVE, COPY, and DELETE. Scroll down to the MOVE option. In the main menue of FILE NAVIGATION, scroll down to MUSIC. Now click the "M" button (the one next to the button with two arrows and one bar). A screen will come up that says that the file is being moved. The song will now be in the MUSIC folder.
You could use the COPY or DELETE features for their respected funtions if you want to when these functions appear.
This is as complete as I can make it.
Jun 27, 2009 | Audio Players & Recorders
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Recharging mp3
Whenever the PD-6070 is connected to a PC, it will charge. The battery indicator on the OLED screen will slowly fill over and over as it is charging. When the charging is complete, the battery indicator will stay filled.
Jan 18, 2008 | MyMusix PD-6070 MP3 Player
Frozen screen
All you reaaly have to do is let the battery run out. Then once the mp3 is dead, charge it. The screen should be unfrozen.
Jan 06, 2008 | SanDisk Sansa e250 MP3 Player
Audiophase KZ111 MP3 players won't charge
One thing that I have found that works is that you slide the switch to the "ON" position, but don't press play to turn it on all the way. Do this BEFORE plugging it into your computer. I have had the mp3 player fro a year or two and I have charged it about 15-20 times.
Nov 01, 2007 | Audiophase MDP-1 Personal MiniDisc Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
