Question about Garmin Nuvi 660 GPS Receiver
My nuvi 660 does not start
It just show the first picture, and stays in picture mode.
    Sergeant:
  • 300 Answers
Have you tried resetting it?
  1. Disconnect from the external power source.
  2. Flip up the GPS antenna.
  3. Press the Reset button.
  4. Connect it to the power source. The unit should turn on.
Posted on Mar 05, 2008
Garmin nuvi 50lm only shows garmin screen and just a bit of green on the bottom. sometimes it shows the green register bar all the way accross
Garmin nuvi 50LM Boot problem ' POI Factory
www.poi-factory.com > Garmin talk
Aug 11, 2012 - Why won't my nuvi 30, 40, or 50 go past the Garmin logo screen when I turn it on? .... Just wanted to say thanks to Muell9K for the hard reset solution. ... get the Nuvi to start up with the screen that shows the picture of a Garmin ...
Crap... White Screen (nuvi 350)
May 11, 2008
garmin frozen?? (how do I reset?)
May 11, 2008
More results from www.poi-factory.com
How to Reset the Garmin nuvi 30, 40 and 50 with GPS City ...
? 0:51
https://www.youtube.com/watch?v=mujdSP-fM98
Jul 31, 2012 - Uploaded by GPSCity
In this video learn how to RESET the Garmin nuvi 30, 40, and 50GPS back to factory default settings. Back up all ... With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit ... Show more. Show less.
Jan 05, 2016 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
My Garmin nuvi 660 only stays on the "Loading Maps" when I turn it on. Tried resetting and holding down the On button until the Pre-boot mode setting goes off, still stays on "Loading...
This is caused by a corrupted file on the Nuvi. To fix this issue, a special version of firmware has to be flashed on the unit, telling it to not look for the corrupted files. The unit will boot normally, then using the PC, the corrupted files need to be replaced and then finally the special firmware needs to be replaced (reflashed) with a standard firmware.
I have done this numerouse times.
- Jim
SHARCNET-USA
Mar 20, 2011 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi works as a stand alone, but plug her in to computer or car power and all you get is a screen showing garmin logo and a picture of it connected to a computer.
Hi
You will need to reset your Nuvi as it is locked into computer mode. To reset it - depending on your version see below.
On some Nuvis there is a recessed master reset button on the body of the unit which you need to access with a nib of a pen or bent paper clip.
For Nuvi 660/680 series
Power off Garmin unit. Press and hold the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
For nuvi 200, 250, 360 750, 760 series
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and while holding it power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
If the above fails it is likely that the problem is not with the Nuvi but the charging unit which is not signalling the unit properly and the Nuvi is recognising it as a USB cable instead of a charger.
Hope this helps. Please remember to rate my answer. Many Thanks.
Jul 19, 2009 | Garmin GPS
Nuvi 660
my nuvi was working great til last week when for some reason it would not load maps, get stuck on the first screen and then just shut down.
Jan 22, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 MP3 files
No program , your 660 read only MP3 , but did you try with WINDOWS it should work nicely.
Contatc GARMIN and mentionned if you can transfert with MAC.
Best regards
Jan 01, 2008 | Garmin Nuvi 660 GPS Receiver
Getting started with new Garmin nuvi660
Plug your 660 with usb into the usb port, computer must not set on sleeping mode (screensaver).
It will take 3-4 hours to be full charge
Dec 18, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
60 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
