Question about Sharp 32R-S50 32" TV
Adding Surround Sound to Sharp 32R-S50 32" TV
How can I connect speakers to my Sharp 32R-S50 to make a surround sound?
  • Donnie Boy Mar 06, 2008
    The Sharp 32R-S50 32" TV does not have an audio output - It does have audio/video input (red/white/yellow) recepticles in back and in front. So how does one go about passing the audio of the "TV" through a home theatre surround receiver if there is no connection from the exterior of the television to do so????
  • only_kings Dec 16, 2008
    I tried but It didn't work for me. Please help.
The sockets on the front are video input and audio output (left and right). It may not look too elegant, but you can plug your stereo lines in the front.
Posted on Jun 29, 2008
  • 61 Answers
If the tv has outputs at the back for surround speakers then you can connect it to them..else pass the audio of your TV thru a home theatre surround receiver
Posted on Mar 05, 2008
Hook mz506 surround sound to my Samsung tv
Typically surround sound is run through a receiver or stereo. The sound from the tv is carried to the receiver by cables (hdmi or Audio-Video connected to input area of receiver). Then the speakers are connected to the output area of the receiver.
If you are not using a receiver, then the speakers must be able to connect directly to the tv and you have to see what kind of cabling your tv supports.
Jan 27, 2015 | Logitech X-540 Multimedia Surround Sound...
I'm trying to connect external speakers to a Sharp Aquos LC-C3234U TV but not having any success. Can anyone help?
Apperently this tv has a history of sound board related problems. So if you are trying to connect external speakers because you have no sound from the set then you still will be sound-less. On the other habd if you just want more sound then I would suggest using a surround sound system which will readily connect to your set.
Oct 31, 2012 | Sharp Televison & Video
Can not get my surround sound system to work with Sharp LC-40F22E using usual audio cable, sound still comes through the tv speakers and can not find how to turn tv speakers of or tell the tv to use...
The way to turn off the tv speakers is to press the menu button scroll to the option category navigate to output select and choose variable. However just turning off the tv speakers will not cause the surround sound system to work with this television. Connecting the red and white composite audio cables to the television's OUTPUT will get you stereo sound. Some people opt to keep the tv's speakers turned on when doing this. In order to get the digital optical out to work between the television and the surround sound system you will have to be using input tv. You will have to be using the television's tuner with digital cable no cable box or with an over the air antenna. Did you make sure you connected the red and white cable to the surround sound aux or any composite input and choose the right function on it?
Dec 03, 2010 | Sharp Televison & Video
I cannot get sound from the tv through the surround sound, speakers all tested and work ok and dvd sound comes through ok when playing dvd, radio works fine also, worked fine 2 days ago with sharp tv, have...
Hi, You have to make sure you are using the "audio out" from the dvd/surround into the "audio in" on your TV also in some case TVs will need to change the "input" with your remote to see where you connected your dvd/sur also some TVs have a switch for "n" or "off" for internal speakers and also you could have that option in your audio menu on your TV, Hope it help, good luck. Mike
Oct 19, 2010 | JVC TH-G30 Theater System
I have succesfully connected my dynex 32" lcd hdtv 720p 60hz to my rogers digital box and my xbox but i only have room to connect my audio cables for my surround sound speakers to my tv cables there is no...
What cables are you using for the XBOX and the digital box? What surround sound system are you using (what receiver)? Which model of Dynex 32" TV do you have? Looking at the DX-L32-10A, I can connect both devices to the TV and then the audio out to the surround sound system.
If HDMI, then that will carry the audio to the TV and then you would need an audio cable from the audio out on the TV to the surround sound speakers. Similarly, if you use component video and the audio cable combination, there are 2 component video jacks and 3 audio-in jacks on the rear of the TV. Then connect another cable from the audio out of the TV to the surround sound system. (This TV has one audio out and a headphone jack.)
If you previously had the audio going from the Rogers digital box directly to the surround sound system, you need to reroute things unless there are two or more sets of audio in jacks on the surround sound system. Some surround sound system can take several HDMI in cables and then route it to the TV on a HDMI out port.
Without more information, I can't be sure of the best option for your cables.
I hope this gets you started and please provide more information for additional suggestions.
CIndy Wells
Sep 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Sharp 32R-S50 32" TV Logo
431 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
